Startech - PCI2S550 Serial Adapter
#2
5.0
based on 4 reviews
from $26.99 - $43.52
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.7
Low Price:
$26.99 at ClubMac
 Trusted:
$34.58 at Techloops.com
$26.99 at OnSale
see all stores
More Images
Pros
  • Good value (1)
  • High quality (1)
  • Low profile card (1)
See less See more
Best Uses
  • Serial port expansion (1)
Provided by MacMall
2 Port Serial PCI Card Easy-to-install and use with full step-by-step instructions StarTech.com’s PCI2S550 adds 2 additional serial ports to a PC, allowing users to connect hardware with serial interfaces such as modems, PDAs, digital cameras, serial printers, digitizer tablets, label printers and ISDN terminal adapters to their PC.The PCI2S550 is guaranteed to work with any PC (drivers for Windows XP, ME, 2000, 98, 95, 3.1, NT, Linux and DOS are included). It is easy to install and use thanks to its step-by-step instruction manual and Plug-and-Play connectivity. IRQ sharing feature also eliminates IRQ conflicts.Two high-speed 16550 UART 9-pin serial ports transfer data at up to 920 Kbps baud rate, ensuring that connected hardware runs at peak performance. Also, built-in 16 byte FIFO buffers work to increase data speeds when multitasking. On top of this, all StarTech.com I/O cards feature a lifetime warranty that ensures continued operation as long as you need it.Features:• Guaranteed compatibility with any PC running Windows, DOS or Linux• Ultra-fast data transfer speed (up to 920 Kbps) allowing connected hardware to run at peak performance
Specification Description
Model 10273676, 493035, PCI2S550
UPC 065030784061
Accessory Indicator Yes
Benefits Installation is a breeze with support for Windows® XP, Server 2003, 2000, ME, 98, NT4, DOS® and moreIRQ sharing and a PCI plu
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Not in your cereal box.
Display Catalog Number 55010164
Features 16-byte FIFO buffer ensures fast data transfer while multitaskingSupports the RS-232 serial interface
Manufacturer Labor Warranty 1
Manufacturer Part Number PCI2S550
Manufacturer Parts Warranty 1
MAP Price 0.0
Model PCI2S550
Operating Temperature UOM ° F
Product Type Serial
Required to function Windows® 3.x/NT4/95/98/ME/2000/XP/2003, DOS and Linux
Supported Languages English
Startech - PCI2S550 Serial Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 14, 2009
Startech - PCI2S550 Serial Adapter Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Viable solution for non-USB serial
5.0
    Pros
  • Good Value
  • High Quality
  • Low profile card
    Cons
  • None
    Best Uses
"Used three cards in low profile case for six additional RS-232 db9 ports to support several legacy serial peripherals without introducing USB-to-serial adapter eccentricities. Cards came up immediately in Windows XP envionment in multiple port rates and settings needed. Had to fabricate low profil …"  Read Full Review »
Was this Network Security review on the Startech - PCI2S550 Serial Adapter helpful to you?
Dec 11 2007
K7BC
Springfield, VA
Reviewed at:
I have purchased several ...
5.0
"I have purchased several items from this company. Everything I have purchased has been delivered usally in a faster time frame than expected. I have found that everything was as advertized and have not had to return one item for any reason. I recommend to anyone that is purchasing anything that this …"  Read Full Review »
May 20 2009
Treedog 19
Undisclosed
I bought this card after ...
5.0
"I bought this card after a USB/Serial cable that was supposedly Vista compliant repeatedly crashed the computer. Installed as it should (easily) and works just fine. Don't be put off by the box which doesn't list Vista as a supported OS. The driver is on the disk. "
Jul 14 2009
Freeman
Undisclosed
I had some initial issues ...
5.0
"I had some initial issues with the product - though I believe it to be my own fault. Their technical support was excellent and I had a response from them through email and via phone in record times. The product works excellent and I highly recommend it! "
Jun 3 2009
Coalesce
Undisclosed
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
