Startech .com USB 2.0 to Audio Adapter
#142
4.3
based on 20 reviews
Ratings Distribution
5 star
11
4 star
7
3 star
0
2 star
1
1 star
1
Category Average
4.1
Low Price:
$13.00 at www.sayera.com
 Trusted:
$14.99 at TigerDirect
Find it at Amazon
$13.00 - $59.99
from 10 stores
More Images
Pros
  • Reliable (3)
  • Highly compatible (2)
  • Improves performance (2)
  • Durable (1)
  • Strong connection points (1)
See less See more
Cons
  • Size (1)
Best Uses
  • Computer equipment (4)
Provided by PC Mall
USB to Stereo Audio Adapter Converter - Sound card - stereo - Hi-Speed USB This USB to Stereo Audio Adapter Converter lets you add headsets and microphones to your computer without the need to unplug other devices! Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any ... This USB to Stereo Audio Adapter Converter lets you add headsets and microphones to your computer without the need to unplug other devices! Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any simpler to install. Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the USB Audio Adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
Specification Description
Model ICUSBAUDIO
UPC 065030819183
Accessory Indicator Yes
Benefits Compliant with USB audio device class specification 1.0USB 2.0 and USB 1.1 compliant1/8" (3.5mm) line-in/microphone input (p
Cable Compliant Standards USB
Cable Type Adapter
Capacity UOM mAh
Color White
Country Of Origin Taiwan
Description Header Running out of audio jacks?
Display Catalog Number 55026988
Enclosure Color White
Included in the Box USB 2.0 to Audio Adapter
Included Qty x Type USB to two female 1/8" phone plugs
Inputs 1 x USB(USB), 1 x Phone 1/8"(Microphone in/Line in)
Jacket Material ABS plastic
Left Connector(s) U
Manufacturer Labor Warranty 12
Manufacturer Part Number ICUSBAUDIO
Manufacturer Parts Warranty 12
MAP Price 0.0
Model ICUSBAUDIO
Operating Temperature UOM ° F
Outputs 1 x USB(USB), 1 x Phone 1/8"(Headphone/Line out)
Product Depth 3.15
Product Dimensions UOM inches
Product Height 0.59
Product Type Adapter
Product Weight 1.89
Product Weight UOM ounces
Product Width 1.57
Supported Languages English
Startech .com USB 2.0 to Audio Adapter Questions
Questions and Answers
Where to Buy
$14.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$22.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$13.00
Show all 10 stores
Product Reviews
Last update: Sep 12, 2009
Startech .com USB 2.0 to Audio Adapter Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
outstanding solution to various problems
"got a laptop with a not-responding left- or right- audio channel? buy one of these, then plug in your speakers or headphones, and IMMEDIATELY, you are back to enjoying your music library in stereo instead of hearing everything through only one speaker or thru a single earphone bud.apple said it would be hundreds of dollars to fix this missing channel audio problem in my otherwise-perfect G4 laptop. this produc..." Read Full Review »
Jul 18, 2008 by grundycenterboy
See more positive Startech .com USB 2.0 to Audio Adapter reviews
1.0
I bought two after ...
"I bought two after reading the manual and examining the data sheet for the included IC. When I hooked one up and connected it to my board, Audacity said that the noise level was -30 dB. I switched adapters and the other was -35 dB. Five or six bits worth. D*8 OK, I turned on my mikes and looked at the result. I found that while both left and right appeared at Audacity, only the left input was digitized. It appea..." Read Full Review »
Sep 12, 2009 by Bill
See more negative Startech .com USB 2.0 to Audio Adapter reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
5.0
    Pros
  • Highly Compatible
  • Improves Performance
  • Reliable
    Cons
  • None
    Best Uses
  • Computer Equipment
"got a laptop with a not-responding left- or right- audio channel? buy one of these, then plug in your speakers or headphones, and IMMEDIATELY, you are back to enjoying your music library in stereo instead of hearing everything through only one speaker or thru a single earphone bud.apple said it woul …"  Read Full Review »
Was this Sound & Video Card review on the Startech .com USB 2.0 to Audio Adapter helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jul 18 2008
grundycenterboy
webster groves, mo
I am:
  • Quality Oriented
Reviewed at:
Price: $22.99
Resolves new laptop stream recording
4.0
    Pros
    Cons
  • Size
    Best Uses
"This is great for overcoming the limitations of some new PCs. Many new PCs have disabled the ability of recording streaming music. The USB audio adapter restores this functionality!
Just install the adapter and associates SW, open your favorite recorder, make sure stereo mixer is selected and you …"  Read Full Review »
Jul 28 2008
Take that!
CO
I am:
  • Value Oriented
Reviewed at:
Price: $22.99
1.0
"I bought two after reading the manual and examining the data sheet for the included IC. When I hooked one up and connected it to my board, Audacity said that the noise level was -30 dB. I switched adapters and the other was -35 dB. Five or six bits worth. D*8 OK, I turned on my mikes and looked at t …"  Read Full Review »
Sep 12 2009
Bill
Undisclosed
Reviewed at:
Price: $14.99
The thing doesn't look ...
4.0
"The thing doesn't look like much and the fact is there is nothing fancy about it but if you want a sound card that works well consistently I doubt anything will top it in this price range. I have been giving it a good pounding with music and voice chatting on Skype and nobody can tell that I am not …"  Read Full Review »
Sep 8 2009
David
Undisclosed
Reviewed at:
Price: $14.99
I purchased this product ...
5.0
"I purchased this product for a Vista machine to restore functionality to my headphone jacks. A power surge took out my mic jack on the motherboard and I did not want to replace the whole thing just for VoIP! For about $20 I got a handly little device to return my ability to use Skype and VoIP applic …"  Read Full Review »
Jun 15 2009
Average Jo
Undisclosed
Reviewed at:
Price: $14.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
