Startech 6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter
#525
4.5
based on 4 reviews
from $3.99 - $19.99
Ratings Distribution
5 star
2
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$3.99 at PC Mall
 Trusted:
$4.99 at MacMall
$4.99 at ClubMac
see all stores
More Images
Provided by MacMall
6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter Adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply Just because your motherboard has a 24-pin ATX connector, it doesnt mean you have to pay for an expensive 24-pin ATX power supply. This adapter cable turns your power supplys 20-pin male ATX connector into the 24-pin male ATX connector needed by high-end motherboards.The StarTech.com Advantage Eiminates the need to purchase an expensive power supply with 24-pin power connector to replace your existing 20-pin power supply StarTech.coms adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply
Specification Description
Model ATX2024FM, ATX2024MF
UPC 065030803304
Accessory Indicator Yes
Benefits Converts standard 20-pin ATX power supply to 24-pin ATX power supplyEliminates the need for an expensive power supply to replace your
Benefits Converts standard 24-pin ATX power supply to 20-pin ATX Power SupplyEliminates the need for an expensive power supply to replace your
Cable Compliant Standards North America FCC
Cable Length Under 1 ft.
Cable Type Adapter
Cable Type Power
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Change is good for your motherboard.
Description Header Set your motherboard free with this adapter.
Display Catalog Number 55010868
Display Catalog Number 55010869
Left Connector(s) Connector A 1 - ATX 20 pin Male
Left Connector(s) Connector A 1 - ATX 24 pin Male
Manufacturer Labor Warranty 1
Manufacturer Part Number ATX2024FM
Manufacturer Part Number ATX2024MF
Manufacturer Parts Warranty 1
MAP Price 0.0
Model ATX2024FM
Model ATX2024MF
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Length 6
Product Type Adapter
Product Type Power
Product Weight 0.11
Product Weight 0.13
Product Weight UOM pounds
Right Connector(s) Connector B 1 - ATX 20 pin Female
Right Connector(s) Connector B 1 - ATX 24 pin Female
Supported Languages English
Startech 6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Dec 22, 2008
Startech 6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Save me some bucks
5.0
"I've changed recently from a AMD athlon XP to a AMD 64, my new motherboard needed a 24 pin power supply connector but I didn't want to change my actual power supply (it only has 20 pin), with this product I solved my problem, it's very easy to use, just plug the adapter and it's done, you need no mo …"  Read Full Review »
Was this Computer Cable & Connection review on the Startech 6" 20 pin ATX Power Supply to 24 pin Motherboard Adapter helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 23 2006
R. Mendoza
Cbba - BO
Reviewed at:
Price: $19.99
It Works
4.0
"I recently purchased the StarTech.com 6IN 20 TO 24 PIN F/M ATX (ATX2024FM) as I have an older motherboard that will only use a 20-pin power cable from the power supply, and the power cable from my modular power supply is a 24-pin. Once I lined up the pins, it was a snap to install and the computer …"  Read Full Review »
Dec 8 2008
J. Wood
Lake City, FL
Reviewed at:
Price: $19.99
It Just Works
5.0
"Did what it was supposed to do: allows me to power my new 24-pin motherboard using my old 20-pin power supply. "
Jul 5 2007
Imaginos
Amazon
Reviewed at:
Price: $19.99
good for the work that has to do ..im please
4.0
"good did what it had to do no complications at all ....good power suply addapter .... "
Dec 22 2008
Larach
Amazon
Reviewed at:
Price: $19.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
