Startech 250-Watt Professional ATX Power Supply with 20 to 24 ATX PSU Pin Adapter
#173
5.0
based on 3 reviews
from $29.00 - $46.99
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
More Images
Provided by PC Mall
250 Watt Professional ATX Power Supply with 20 to 24 ATX PSU Pin Adapter Replace that older or non-functioning power supply in your server or PC with the ultimate power supply for power-hungry systems. Guaranteed compatible with Pentium and AMD processors. This 250 Watt, heavy-duty power supply is guaranteed compatible with Pentium and AMD processors and constructed from the highest quality components to ensure an extra long-life. The ATXPOW250PRO provides the optimum power required for today’s demanding 3D video, multi-CPU applications and additional drives. A dual ball-bearing, automatic temperature control fan blows hot air away from sensitive components and a superior EMI/RFI power filtration system is used to ensure system components receive clean, stable power. Low noise/ripple as well as short circuit protection (MTBF ratings in excess of 100K at 25 degrees Celsius) are additional reasons why the ATXPOW250PRO is the ultimate power supply for system stability.Features• ATX version 2.03 & ATX12V compliant• Dual Ball Bearing in the cooling fan motor provide increased reliability, air flow and longer life• Enclosure is constructed with an attractive nickel plated casing• High quality connectors provide minimal resistance and enhanced electric conductivity• High-Flow fan provides efficient cooling for the system and power supply• Provides a maximum output power of 250 Watts• Quad Protection Plus: Short Circuit Protection, Over Voltage Protection, Over Load Protection, Over Current Protection, and No Load Operation.• Superior EMI/RFI power filtration system provide low noise/ripple for super clean and stable power to all system componentsSpecifications• Connector Types:&nbsp&nbsp&nbsp&nbsp4 - LP4 Female&nbsp&nbsp&nbsp&nbsp1 - SP4 Female&nbsp&nbsp&nbsp&nbsp1 - ATX 20 pin Female• Input Voltage 120 AC• Fans 1 - 80 mm
Specification Description
Model 10273676, ATXPOW250PRO
UPC 065030787635
Accessory Indicator Yes
Benefits Provides 250W of power for connection to vital components120-240VAC input voltageConveniently ATX version 2.03 and ATX12V co
Capacity UOM mAh
Country Of Origin China
Description Header Plug in and power up.
Display Catalog Number 55006854
Features High-flow, dual ball bearing fan with automatic temperature control cools componentsQuad Protection Plus prevents short circuits, ove
Manufacturer Labor Warranty 3
Manufacturer Part Number ATXPOW250PRO
Manufacturer Parts Warranty 3
MAP Price 0.0
Model ATXPOW250PRO
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 3.35
Product Length 5.91
Product Type 200-300W
Product Weight 3.45
Product Weight UOM pounds
Product Width 5.51
Supported Languages English
Startech 250-Watt Professional ATX Power Supply with 20 to 24 ATX PSU Pin Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 24, 2008
Startech 250-Watt Professional ATX Power Supply with 20 to 24 ATX PSU Pin Adapter Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[4 of 4 customers found this review helpful]
Plug and play...like parts and peripherals are *supposed* to be
5.0
"I was on the hunt for an affordable 250watt power supply to replace the one that had burned out in an old PC I had. The PC is a 500MHz with an AMD processor running Windows XP, a printer, and a CDRW. It's just used by my preschooler to run a handful of games. It's hard to find a 250watt power sup …"  Read Full Review »
Was this Surge Protector review on the Startech 250-Watt Professional ATX Power Supply with 20 to 24 ATX PSU Pin Adapter helpful to you?
 Report Abuse  (4)  (0)  0 comments
Jan 20 2008
AMM
TX United States
Reviewed at:
Price: $46.99
so far,so good
5.0
"Since I bought this item through amazon which they saved me shipping,
this power supply has been strong and pretty quiet,... the cost was very
affordable and worth the purchase since its been just a little over a
month when I purchase it.... running really good as of the month of
October.... …"  Read Full Review »
Oct 24 2008
Hawaiian Boy
O'ahu,Hawai'i
Reviewed at:
Price: $46.99
[1 of 1 customers found this review helpful]
Power To Go
5.0
"This replacement power supply did the trick. Easy to install and very quiet. No problems with the 250 watt Long Life ATX PC Computer Power Supply. "
 Report Abuse  (1)  (0)  0 comments
Feb 26 2008
Dave
Maryland
Reviewed at:
Price: $46.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
