Startech 15 ft. Coax SVGA Monitor Cable HDDB15M/M
#249
4.6
based on 5 reviews
from $14.00 - $29.99
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Durable (3)
  • Highly compatible (2)
  • Improves performance (2)
  • Consistent performance (1)
  • Good length (1)
  • Strong connection points (1)
See less See more
Best Uses
  • Computer equipment (2)
Provided by Buzzillions.com
MODEL- MXT105MMHQ VENDOR- STARTECH.COM LTD FEATURES- Coax SVGA Monitor Extension Cable HDDB15M/M- 15 ft. The Coaxial VGA Video Extension Cables are designed to provide thehighest video quality possible. StarTech coaxial VGA cables eliminate picture ghosting and fuzzy images inherent to non- coaxial cables and provide superior EMI interference protection by using ferrite cores near the connector ends.Extends VGA/SVGA monitor cable or Connects PC's VGA port to a StarView. * Ideal for high resolution monitors (1024x768 and above). * Triple-coaxial + twisted-pair wire for crystal clear display. * Impedance matched at 75 Ohms for full brightness and vibrant picture color. * Ferrite core eliminates EMI interference. * Molded connector ends with strain relief. CONNECTORs- High Density DB15 Male High Density DB15 Male
Specification Description
Model 10273676, MXT105MMHQ
UPC 065030778787
Accessory Indicator Yes
Benefits Includes a ferrite core that eliminates EMI interferenceIndependence matched at 75 ohms for full brightness and vibrant picture color
Cable Length 13-15 ft.
Cable Type Monitor
Capacity UOM mAh
Color Black
Country Of Origin China
Description Header Get a clear connection.
Display Catalog Number 55007939
Impedance 75 ohms
Interface Supported SVGA
Left Connector(s) 1 x high-density DB15 - male
Manufacturer Labor Warranty 90
Manufacturer Part Number MXT105MMHQ
Manufacturer Parts Warranty 90
MAP Price 0.0
Model MXT105MMHQ
Operating Temperature UOM ° F
Product Type Monitor
Right Connector(s) 1 x high-density DB15 - male
Supported Languages English
Technology Features Triple-coaxial plus twisted-pair wire
Startech 15 ft. Coax SVGA Monitor Cable HDDB15M/M Questions
Questions and Answers
Where to Buy
$21.99
$29.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$14.00
Show all 15 stores
_
Product Reviews
Last update: Jun 2, 2009
Startech 15 ft. Coax SVGA Monitor Cable HDDB15M/M Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Great cable, Great price.
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
    Cons
  • None
    Best Uses
  • Computer Equipment
"We used this cable on a tv monitor that shows our security cameras. Picture clarity is excellent. "
Was this Computer Cable & Connection review on the Startech 15 ft. Coax SVGA Monitor Cable HDDB15M/M helpful to you?
Jun 2 2009
John
King Of prussia, PA.
I am:
  • Quality Oriented
Reviewed at:
Price: $29.99
Good Product
5.0
"Pros
Easy to connect my 26' Flat Panel LCD to my laptop. Works great.
Cons
T.V. automatically switches from HDMI to the computer when the computer boots up. Also switch from the T.V. to the computer if the computer is in "sleep" mode and then boots up by itself running Vista. "
Feb 4 2009
radmanwb
Green Cove Springs, FL
Reviewed at:
Price: $21.99
Works Great
5.0
    Pros
  • Consistent Performance
  • Good Length
    Cons
  • None
    Best Uses
  • None
"Just plugged in to my hd tv and use it as a full room monitor! Works great! "
Apr 28 2009
Fly by night
Mukilteo Wa
I am:
  • Enthusiast
Reviewed at:
Price: $29.99
Laptop to TV viewing
4.0
    Pros
  • Strong Connection Points
    Cons
  • None
    Best Uses
"Nice way to watch TV from a Laptop capture card. "
Feb 7 2009
Joe
Mount Carmel, PA
I am:
  • Quality Oriented
Reviewed at:
Price: $29.99
cable
4.0
    Pros
  • Highly Compatible
    Cons
  • None
    Best Uses
  • None
"good "
Feb 13 2009
levi
carbondale,il
I am:
  • Value Oriented
Reviewed at:
Price: $29.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
