Startech 10-ft. DVI-D Dual Link Digital Video Monitor Cable (Male to Male)
#631
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$12.33 - $26.00
from 15 stores
More Images
Provided by OnSale
10ft DVI Dual - Link Cable Male/Male These quality cables provide a stronger, faster signal to keep the resolution on your panel display, digital projector, or HDTV crystal clear. OverviewMake a high-speed DVI-D connection with StarTech.coms DVI-D dual-link cables. These quality cables provide a stronger, faster signal to keep the resolution on your panel display, digital projector, or HDTV crystal clear.These cables allow high-speed data transmission up to 9.9 Gbits/sec.Advantage: Backed by StarTech.coms Lifetime Warranty Dual link cable provides high speed digital transmission of up to 9.9 Gbits/sec Signal attenuation is stronger and faster than a standard monitor cable Works with all Digital Flat Panels and Liquid Crystal Displays Features: Compatible with PC and Mac computer systems Compliant with DVI DDWG Standards Dual link digital signalling allows high speed digital data transmission DVI-D Dual Link Display Cable supports digital displays only High speed digital transmission rate of up to 9.9 Gbits/sec Supports hot plugging of DVI display devices Applications: Compatible with Flat Panel Displays, Digital CRT Displays, Projectors and HDTV Easily connect your PC to a HDTV, Projector and CRT Displays
Specification Description
Model DVIDDMM10
UPC 065030802796
Accessory Indicator Yes
Benefits Compatible with PC and Mac computer systemsCompliant with DVI DDWG StandardsDual-link digital signaling allows high-speed di
Cable Compliant Standards DVI DDWG Standard
Cable Length 10 ft
Cable Type DVI cable
Capacity UOM mAh
Color Black
Country Of Origin China
Description Header The best cable for the best signal.
Display Catalog Number 55028239
Enclosure Color Black
Interface Supported DVI
Left Connector(s) 24-pin digital DVI (Dual-Link) male
Manufacturer Labor Warranty 1
Manufacturer Part Number DVIDDMM10
Manufacturer Parts Warranty 1
MAP Price 0.0
Model DVIDDMM10
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Length 10
Product Type DVI cable
Right Connector(s) 24-pin digital DVI (Dual-Link) male
Supported Languages English
Startech 10-ft. DVI-D Dual Link Digital Video Monitor Cable (Male to Male) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 28, 2008
Startech 10-ft. DVI-D Dual Link Digital Video Monitor Cable (Male to Male) Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Excellent quality cable
5.0
"I needed a longer DVI cable from my computer to monitor and this one works perfectly. This is a high quality cable, much thicker and more rubust that the one Dell supplied with my computer, with quality connections and fittings at both ends. Image quality to my monitor is great, no compatability …"  Read Full Review »
Was this Computer Cable & Connection review on the Startech 10-ft. DVI-D Dual Link Digital Video Monitor Cable (Male to Male) helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 28 2008
jimagain
NJ
Reviewed at:
Price: $26.00
Flawless product, incorrect description
5.0
"One usually uses the term "extension cable" to refer to a cable with a male connector at one end and a female connector at the other. This cable has a male connector at both ends, as shown in the diagrams. So it's not an extension cable.
I bought this cable after another one I had bought turned o …"  Read Full Review »
Oct 18 2007
Andrew Koenig
New Jersey, USA
Reviewed at:
Price: $26.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
