Staples Floor Cable Concealer, Gray
3.3
based on 0 reviews
Ratings Distribution
5 star
9
4 star
18
3 star
10
2 star
2
1 star
10
Category Average
4.0
Pros
  • Durable (29)
  • Reliable (16)
  • Easy to use (15)
  • Fast (12)
  • Compact (7)
  • Highly compatible (3)
  • Improves performance (2)
  • No more tripping (1)
  • Rugged construction (1)
See less See more
Cons
  • Unreliable (5)
  • Poor quality (4)
  • Bulky/heavy (3)
  • Not durable (3)
  • Flimsy (2)
  • Hard to install (2)
  • Channels are small (1)
  • Deformed-no quality contr (1)
  • Does not lay flat easily (1)
  • Hard to flatten out (1)
Best Uses
  • Home or business (20)
  • Computer equipment (11)
  • Anywhere (5)
  • Networking (4)
  • Covers wires on floor (1)
  • Electrical equipment (1)
Provided by Staples
6' long Easy to cut and fit to any desired length Gray Includes double-sided adhesive tape Hide cords up to 3/4" in width that run across the floor or counter.
Staples Floor Cable Concealer, Gray Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Floor Cable Concealer, Gray
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 3, 2009
Staples Floor Cable Concealer, Gray Reviews
Most helpful positive review
Most helpful negative review
4.0
Do not use the tape!
"Used this runner in a conference room in a high traffic area, worked very well until I tried to remove it and half of the double sided taped stayed stuck to the carpet. Just buy some 3M doublesided tape and it will be fine. Another thing about theses runners, lay them out flat in the sun or warm area for a while before applying, makes installation much easier...." Read Full Review »
Sep 13, 2009 by IT Guy
See more positive Staples Floor Cable Concealer, Gray reviews
3.0
Well-made but with a permanent roll
"The product comes rolled up in its box. It will not unroll and, when taped down pulls loose at the ends because of the roll. We used it to pass speaker and computer wire across several doorways. With the doors closed, the product is held flat. Open the doors and both ends of the strip pull away from the carpet and form humps: disappointing. My recommendation would be either to heat the strip with a hair drier to..." Read Full Review »
May 28, 2009 by Barefoot Les
See more negative Staples Floor Cable Concealer, Gray reviews
Displaying 1 - 0 of 0 Reviews
Show
Sort by
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
