Square Perfect SP3700 Complete Premium Portrait Studio Kit - 3 Studio Flash/Strobe, 2 softboxes, 3 backdrops, wireless
4.1
based on 9 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
1
2 star
0
1 star
1
Category Average
4.2
Pros
  • Good value (7)
  • Durable (5)
  • High quality (4)
  • Cheap (1)
  • Great for home use (1)
  • Inclusive (1)
  • Value (1)
See less See more
Cons
  • Flash out varies sometime (1)
  • Had to buy brighter bulbs (1)
  • Junk (1)
  • Low power output (1)
  • Poor quality (1)
  • Speedring fit and finish (1)
  • Wrong instructions (1)
Best Uses
  • Portraits (3)
  • Artistic photography (1)
  • Head shots (1)
  • Home theater (1)
  • Learining lighting (1)
  • Product shots (1)
Provided by Discount Tommy
This kit gives you all the power you will need to get perfect photos. These are 110 volt lights that plug into any household outlet. Dare to compare. . . .you will not find anything in this price range at this quality anywhere.
Two (2) Professional Studio Strobes: SP150S (at 150 Watt-Second each), each with their own 100-watt modeling light. The SP150S produces a superb warm light that will bathe your subjects in soft light. They are perfect for commercial studios, location photographers as well as advanced amateurs. You can use this strobe for a main light, fill light, back light, or hair light. Similar strobes strobe sell in professional camera stores for over $399 each.
One (1) Synch Flash B (45-Watt/Second)Includes A/C screw socket with umbrella holder.This unit is typically used for back lighting or fill light. When used with the included gold umbrella, it will provide a soft glow to the subject. As with the strobes, the synch flash will fire automatically when any of the other strobes fire.
Three (3) Professional Duty Aluminum Light Stands. (2) Light Stands extend from 37 to 84 and the other extends from 18 to 39. Square perfect utilizes reinforced brace supports, and heavy-duty, riveted joints, to help ensure maximum stability and security. The three stands are light-weight and extremely portable they fold down for easy transport.
One (1) Backdrop Support System with Carry case and backdrops.
Backdrops:
  • 100% cotton to absorb the light and help eliminate reflection.
  • 4 rod pocket at one end allow for easy setup - no more confusion about which side is top. Beware of cheap alternatives that need to be attached with clamps or counterweights - this product is directly threaded to the cross bar.
  • Dyed with the best quality dye.
  • Machine washable
  • Crimped along the edges to prevent tears
SPECIFICATIONS:
  • Super fast set-uptakes one man less than 5 minutes.
  • Holds canvas, muslin or paper
  • Telescopic cross bar extends to 10'
  • Stands extend up to 8'6""
  • Stands compact down to 4'
  • Extra wide footprint for added stability
  • One year factory warranty
  • Excellent for field jobs and studio shoots
Also includes:
2 softboxes, radio trigger, receiver and sync cord, reflectors, barn door, gels, honeycomb filters, snoot and sync cords, carry case and gold reflecting umbrella.
Square Perfect SP3700 Complete Premium Portrait Studio Kit - 3 Studio Flash/Strobe, 2 softboxes, 3 backdrops, wireless Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SP3700 Complete Premium Portrait Studio Kit - 3 Studio Flash/Strobe, 2 softboxes, 3 backdrops, wireless
See all eBay results
  at eBay.com
Product Reviews
Last update: May 25, 2009
Square Perfect SP3700 Complete Premium Portrait Studio Kit - 3 Studio Flash/Strobe, 2 softboxes, 3 backdrops, wireless Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great bang for your buck
4.0
    Pros
  • Inclusive
  • value
    Cons
    Best Uses
  • Home Studio
"Great starter kit. You don't need powerful strobes to get great shots in a home studio people. Cons were wrong assembly instructions for softboxes but SP sent them to me by email quickly. They're easier to assemble than the ones in the instructions would have been! Softbox speedrings don't fit easil …"  Read Full Review »
Was this Light Kit review on the Square Perfect SP3700 Complete Premium Portrait Studio Kit - 3 Studio Flash/Strobe, 2 softboxes, 3 backdrops, wireless helpful to you?
 Report Abuse  (1)  (0)  0 comments
May 25 2009
Joe2PointOh
Independence, Mo
Reviewed at:
Price: $429.95
Great Lighting Kit
5.0
    Pros
  • Good Value
    Cons
  • None
    Best Uses
  • Artistic Photography
  • Learining Lighting
  • Portraits
"So far I haven't found anything I dislike about the kit. This was my first lighting kit purchase. I wanted something I could afford, While still being able to produce good quality portraits. So I decided to give this kit a try.
I can't compare to other kits, but for me especially just starting o …"  Read Full Review »
Dec 15 2008
KYMike
Hyden, KY
Reviewed at:
Price: $429.95
Forget the rest DISCOUNT TOMMY is BEST!!
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"I wanted to get into studio photography lighting. Researching I found the SP3700 from Discount Tommy.
The kit is PERFECT for what I wanted to do. The equipment works GREAT and everyone I have spoken to at Discount Tommy have been fantastic. I have recommended them to all of my fellow photographers …"  Read Full Review »
Dec 15 2008
KelvinH
New Mexico
Reviewed at:
Price: $429.95
Awsome product
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"Product is an awsome starter kit for the studio. I want more pieces now and can't wait to get my husbands studio complete. Really this is probably all you need, but for him it's only the best. And occaisionally, more is even better. "
Dec 15 2008
Missy
Arlington, WA
Reviewed at:
Price: $429.95
decent product
3.0
    Pros
  • Durable
  • Good Value
    Cons
    Best Uses
  • Portraits
"this is actually a pretty decent system. comes with everything i need. the only draw back is the flash output varies sometimes, only about a half a stop. "
Dec 15 2008
clayton
winnipeg, MB
Reviewed at:
Price: $429.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
