Speeze CPU Fan
#230
4.1
based on 20 reviews
Ratings Distribution
5 star
8
4 star
7
3 star
2
2 star
1
1 star
1
Category Average
4.3
Low Price:
$4.99 at CompUSA
 Trusted:
$4.99 at TigerDirect
Find it at Amazon
$4.99
from 2 stores
Provided by TigerDirect
Masscool - Socket A Cooling Fan For Duron / Athlon / Celeron / Pentium III CPUs
Speeze CPU Fan Questions
Questions and Answers
Where to Buy
Speeze CPU Fan
Product Reviews
Last update: Oct 14, 2009
Speeze CPU Fan Reviews
Most helpful positive review
Most helpful negative review
5.0
The original heatsink and ...
"The original heatsink and fan on my Dell Dimension 2100 Celeron 900Mhz processor was slowing down and vibrating with a loud hum. So I bought this to replace it. It works great. I do not find it noisy like the other reviewer does. My PC has a new lease on life! Just one surprise: The bottom pad on this unit, where it sits on the CPU, is covered with a fine layer of lithium grease. Maybe it helps with the co..." Read Full Review »
Jan 15, 2005 by scribe
See more positive Speeze CPU Fan reviews
1.0
I installed this fan on ...
"I installed this fan on an Athlon 2200 1.8ghz CPU. Fired it up it ran 2 seconds and powered down. Thought the fan might be not running at enough RPM or something. Installed on my second machine (Same setup) and got same results. Turned out the clip was putting to much pressure and both Non replaceable CPU's were fried. Got a sorry tuff luck from both Tiger and The fan maker. Not even an offer to help in some way..." Read Full Review »
Feb 28, 2008 by Anonymous
See more negative Speeze CPU Fan reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
1.0
"I installed this fan on an Athlon 2200 1.8ghz CPU. Fired it up it ran 2 seconds and powered down. Thought the fan might be not running at enough RPM or something. Installed on my second machine (Same setup) and got same results. Turned out the clip was putting to much pressure and both Non replaceab …"  Read Full Review »
Feb 28 2008
Undisclosed
5.0
"The original heatsink and fan on my Dell Dimension 2100 Celeron 900Mhz processor was slowing down and vibrating with a loud hum. So I bought this to replace it. It works great. I do not find it noisy like the other reviewer does. My PC has a new lease on life! Just one surprise: The bottom pad …"  Read Full Review »
Jan 15 2005
scribe
Undisclosed
I purchased this item to ...
5.0
"I purchased this item to replace the OEM heatsink/fan on a P3 system (45Watt cpu). This product is superior because it has a metal clip instead of the plastic cam-lock that breaks after being exposed to heat for several years. I wouldn't recommend a heatsink/fan this small for a much larger cpu. "
Aug 6 2009
dank
Undisclosed
although hard to find ...
5.0
"although hard to find amongst all of the choices out there, this product has fired up on first try and has yet to show any signs of fatigue or failure. loaded on an aging hp pavillion of 5 -6 years old it was an easy replacement of original, although a little tighter squeeze to clip on; cant compla …"  Read Full Review »
Jun 22 2009
joseph
Undisclosed
I swapped this fan (kept ...
3.0
"I swapped this fan (kept my old heatsink) in for a dying cpu fan on my Athlon 750. Athlons tend to run pretty hot (even though I don't overclock) but even this tiny 50mm fan seems to keep it cool enough to stay healthy. It's quietness is mediocre, but then again, I bought this to be a quick replac …"  Read Full Review »
Apr 19 2005
Boof
Undisclosed
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Speeze CPU Fan
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
