#317
based on 6 reviews
Ratings Distribution
| 5 star |
1 |
| 4 star |
2 |
| 3 star |
1 |
| 2 star |
1 |
| 1 star |
1 |
Category Average
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
Product Reviews
Displaying 1 - 5 of 6 Reviews
[1 of 1 customers found this review helpful]
SP-Systems Umbrella Flash Clamp Review
Pros
Cons
Best Uses
"used to support my speedlites which are hotshoed to my cactus triggers. clamps are hard to adjust and wont stay inplace unless i crank em super tight. the top part of the clamp which is a blank hotshoe does not secure the cactus trigger securely at all. it is so loose that i fear loosing my strob …" Read Full Review »
Pros
Cons
Best Uses
"I use this clamp with my Nikon SB600 flash on a light stand. It fit perfectly on the stand and the flash locks in tight. The clamp adjusts smoothly. Umbrella stays secured in place. "
"Good clamp, holds well, but my SB-900 will not slot into the flash holder (which pretty much defeats the purpose of a flash clamp!). Will need to file down the metal lip so that the flash can slide in. "
Pros
Cons
Best Uses
"Does what it says. Misses 5 stars only because the umbrella holding screw is small and fiddly. "
Pros
Cons
Best Uses
"I wanted to use my flashes with my umbrellas, and this adapter worked great. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
