#414
based on 272 reviews
Ratings Distribution
| 5 star |
122 |
| 4 star |
103 |
| 3 star |
31 |
| 2 star |
13 |
| 1 star |
3 |
Category Average
$16.95
from 1 storePros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
Product Reviews
[5 of 5 customers found this review helpful]
[2 of 2 customers found this review helpful]
"These brackets are great! I bought two brackets to use with my light stands and Nikon speedlights. I plan to add softboxes soon. The brackets should work equally well with dedicated studio stobes and softboxes. My light stands have standard 5/8-inch diameter tops, so I removed the bottom removable studs that came with the brackets and mounted the brackets directly on the light stands. This is nice, because fewe..." Read Full Review »
Apr 30, 2008 by GeorgeJ
"Pro: The bracket it-self is machined very well of a heavy duty plastic and holds an umbrella nice and secure. No drifting backward or forward from extra weight. The bracket locks securely in place. Con:The shoe mount needs to be replaced with a better one because of its poor design its hard to lock down the flash tight enough. I had my SB800 slide out of the bracket only to hit the floor. I'm looking to repla..." Read Full Review »
Jun 30, 2008 by Buffalo Ray
Displaying 1 - 5 of 272 Reviews
SP-Systems Multi-Bracket Review
Super Informative
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
"I purchased this to use an umbrella / speed light set up on my tri pod since I have an extra 3/8" quick release head and it fits it fine. The umbrella hole is OK but the screw used for securing the umbrella is quite THIN and you have to get it dead center or it isn't as secure as I would like it. An …" Read Full Review »
Pros
Cons
Best Uses
"Great product, does what its supposed to do. I bought this ahead of the Manfrotto mainly because of the difference in weight. The plastic parts hold up to the weight of the umbrella and flash attached, haven't found problems so far. "
Pros
Cons
Best Uses
"the firs thing to know about this bracket is that it comes shipped with the studs inserted into the wrong ends - so at first it can be confusing if you don't know this. Take the studs out of the ends and swap them around and it's just fine. Build quality is decent for an inexpensive bracket, and t …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
