SOUND ISOLATION EARBUDS
2.1
based on 32 reviews
from
Ratings Distribution
5 star
4
4 star
2
3 star
5
2 star
2
1 star
17
Category Average
3.9
Pros
  • Compact (16)
  • Comfortable (14)
  • Lightweight (11)
  • Powerful bass (8)
  • Great sound quality (7)
  • Durable (2)
  • Good value (2)
  • Highly compatible (2)
  • Stylish (2)
  • Easy to carry (1)
See less See more
Cons
  • Flimsy (17)
  • Falls off/out of ear (11)
  • Cord too short (7)
  • Poor sound quality (6)
  • Uncomfortable (4)
  • Poor value (3)
  • Cord retractor too heavy (1)
  • Cord tangles easily (1)
  • No clip (1)
  • Not durable (1)
Best Uses
  • Portable devices (16)
  • Travel (8)
  • Working out (6)
  • Music (5)
  • With my computer (5)
  • Any sort of travel (1)
  • Home audio (1)
  • Office (1)
  • Relaxing (1)
  • Running (1)
Provided by Brookstone
For better sound and less outside noise, our Sound-Isolating Earbuds are just right. The comfortable, in-ear design blocks unwanted noise, while delivering rich, full-bodied sound for music and movies. Three included sizes of earbuds ensure a snug, custom fit. Also includes a retractable, tangle-free cable, dual-pin airplane adapter and t-splitter for sharing.
Rich sound, less outside noise.
The snug in-ear design delivers remarkably rich, full-bodied sound, while blocking unwanted noise.
Comfortable, custom fit.
Our Sound-Isolating Earbuds come with three sizes of buds, so you can enjoy a fit that's comfortable for extended periods and all types of activity--from travel and exercise, to work or just relaxing.
Perfect for travel.
The compact design, combined with a retractable, tangle-free cable, dual-pin airplane adapter and t-splitter for sharing, make our Sound-Isolating Earbuds ideal for travel.
SOUND ISOLATION EARBUDS Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SOUND ISOLATION EARBUDS
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 5, 2009
SOUND ISOLATION EARBUDS Reviews
Most helpful positive review
Most helpful negative review
4.0
Great for the price
"When I went to Europe with my band I remembered to bring everything except my headphones. Went to the brookstone store in the airport and bought these expecting them to be really bad. They blocked out background noise great on the plane and are the most comfortable pair of in-ear headphones i've ever worn. I can even fall asleep in bed with these in my ears. I don't even use my other in-ears anymore(which cost m..." Read Full Review »
May 21, 2009 by Evan
See more positive SOUND ISOLATION EARBUDS reviews
1.0
If you purchase this, KEEP YOUR RECEIPT
"I loved this earbud set until the rubber earbud cover popped off and was lost. The covers pop off readily, which would be nice for the sake of cleaning but they come off very easily, usually stuck in my ear. Brookstone does not have replacements and if you don't have a receipt or the set is more than a year old....well then you are out of luck. I was very willing to "pa" for a replacement product but was told th..." Read Full Review »
Oct 13, 2009 by Disappointed Customer
See more negative SOUND ISOLATION EARBUDS reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
Best I've found!
5.0
    Pros
  • Comfortable
  • Compact
  • Durable
  • Good Bass
  • Good Value
  • More »
    Cons
  • None
    Best Uses
  • Portable Devices
"I've had trouble finding gel earbuds that actually fit, and don't fall out. These fit perfectly and easily into the ear canal without having to force them or constantly re-adjust them ... especially when I go for my daily walk where other earbuds want to work their way loose. These isolate the sound …"  Read Full Review »
Was this Headphones review on the SOUND ISOLATION EARBUDS helpful to you?
Nov 21 2009
TrendSmart
Orange County, CA
I am:
  • Regular person
Reviewed at:
1.0
    Pros
  • Comfortable
  • Compact
  • Lightweight
    Cons
  • Cord Too Short
  • Flimsy Construction
    Best Uses
  • None
"I loved this earbud set until the rubber earbud cover popped off and was lost. The covers pop off readily, which would be nice for the sake of cleaning but they come off very easily, usually stuck in my ear. Brookstone does not have replacements and if you don't have a receipt or the set is more tha …"  Read Full Review »
Oct 13 2009
Mobile, AL
Great but earbuds fall off
3.0
    Pros
  • Comfortable
  • Compact
  • Good Bass
  • Good Value
  • Great Sound
  • More »
    Cons
  • None
    Best Uses
  • Portable Devices
  • Working Out
"Within days of buying my set of sound isolation earphones, I bought two more sets as gifts. That was before the buds fell off. Each friend for whom I bought the earphones has had the same problem. I have run out of earbuds now. What to do? Do I buy a new set of earphones? Great item, poor earbud des …"  Read Full Review »
Oct 22 2009
whysee
New York CIty
I am:
  • Audiophile
  • Frequent Traveler
Reviewed at:
need to be fixed
1.0
    Pros
  • Compact
    Cons
  • Poor Value
    Best Uses
  • None
"The headphones have a mind of their own. one moment they work fine, next only the right bud works. using an iPhone if that helps "
Nov 22 2009
Santa Monica
I am:
  • Teenager
Reviewed at:
I would not buy this again
1.0
    Pros
  • Great Sound
    Cons
  • Poor Value
    Best Uses
  • Portable Devices
"I bought this for the ability to retract. This is a flimsy cord, too thin, gets tangled in the retractor. Knots up quite frequently.
This comes with 3 sizes of earpieces which fall off easily. Good sound but so are alot other earphones out there. "
Nov 5 2009
Kate
Chicago IL
I am:
  • Frequent Traveler
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
