Sony XDR-S10HDiP HD Radio with iPod Dock
#80
4.0
based on 37 reviews
Ratings Distribution
5 star
15
4 star
15
3 star
3
2 star
1
1 star
3
Category Average
4.0
$129.00 - $159.99
from 10 stores
More Images
Pros
  • Easy setup (26)
  • Nice sound (21)
  • Accurate controls (19)
  • Clear signal (19)
  • Compact (13)
  • Beat my expectations (1)
  • Clear treble and midrange (1)
  • Durable (1)
  • Fully integrated remote (1)
  • Ipod dock work great (1)
See less See more
Cons
  • Heavy / bulky (4)
  • Poor reception / weak antenna (2)
  • At night (1)
  • Display a little bright (1)
  • Few hd stations available (1)
  • Ipod compatibility (1)
  • No hd signals after storm (1)
  • No support for sony's own (1)
  • Poor bass response (1)
  • Transformer (1)
Best Uses
  • Smaller rooms / apartments (17)
  • Basic systems (12)
  • Large rooms (7)
  • Home (5)
  • Audiophiles (3)
  • Office (3)
  • Also good in rec room (1)
  • Good in bedroom (1)
Provided by OneCall
Combining high fidelity HD Radio technology and an iPod docking station, Sony`s XDR-S10HDiP HD Radio with iPod compatibility is the first tabletop radio of its kind from Sony. Perhaps the most exciting feature is its iTunes® Tagging capability, enabling the user to save song information with the touch of a button while listening to an HD Radio station. The iPod can later be hooked up to the user`s computer where the information will be downloaded, and purchase choices can then be made using iTunes®.
Designed to work with most iPod models, the unit`s sleek design includes a wireless remote with full access to the iPod player menu, as well as to radio tuning and volume functions. The unit also charges the iPod while it is docked and provides clock radio functionality.
Specification Description
Model XDR-S10HDiP, XDRS10HDIP, XDRS10HDiP
UPC 027242730328
Alarm 2 Alarm
iPod Dock Connector Top Input
MP3 Player Dock for optional iPod
Tuning AM/FM and HD AM/FM
Sony XDR-S10HDiP HD Radio with iPod Dock Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Sony XDR-S10HDiP HD Radio with iPod Dock Reviews
Most helpful positive review
[22 of 22 customers found this review helpful]
Most helpful negative review
4.0
Almost great
"I am really impressed with hd radio which does suprise me. I got this mainly because it is ipod touch compatible. The one real negative is that it has no battery backup and looses all the stored stations in memory and even the time with just a blip type power outage-what a dissappointment in an otherwise stellar product. I can not believe the engineers overlooked this in the design...." Read Full Review »
Dec 06, 2008 by bleep
See more positive Sony XDR-S10HDiP HD Radio with iPod Dock reviews
3.0
Hits and Misses
"We were eager to get this unit, as a particularly beloved radio show in our market (Minneapolis/St Paul) has moved off of FM to HD Radio only. So it was great to plug this unit in and hear the music that we enjoy. It's in the kitchen on the counter and serves a very utilitarian function. The reception is clear. That's a definite upside. That said, there are two downfalls to the unit. The converter that is p..." Read Full Review »
Jan 26, 2009 by Brian
See more negative Sony XDR-S10HDiP HD Radio with iPod Dock reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
Almost great
4.0
"I am really impressed with hd radio which does suprise me. I got this mainly because it is ipod touch compatible. The one real negative is that it has no battery backup and looses all the stored stations in memory and even the time with just a blip type power outage-what a dissappointment in an othe …"  Read Full Review »
Was this MP3 Player / iPod Dock & Charger review on the Sony XDR-S10HDiP HD Radio with iPod Dock helpful to you?
 Report Abuse  (22)  (0)  0 comments
Dec 6 2008
bleep
Atlanta
Reviewed at:
Price: $159.99
[23 of 24 customers found this review helpful]
Sony HD Radio
4.0
"I just got my HD/ Ipod player yesterday. The sound is crystal clear once you hook up the antenna that comes with it. It can be compared to a Bose sound system. The only downside is that if you are going to use it in different places you should know that the preset radio stations and the time reset e …"  Read Full Review »
 Report Abuse  (23)  (1)  0 comments
Dec 11 2008
Undisclosed
Reviewed at:
Price: $159.99
[2 of 2 customers found this review helpful]
Works with SOME iPods
4.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Easy To Set Up
  • Good Sound
    Cons
  • IPod compatibility
    Best Uses
  • Basic Systems
"Product info says the "iPod Classic" is among the models supported with the dock. They don't tell you that you have to first obtain the right dock adapter for your iPod model (cheap and fast, but slight delay for an order to the Apple store). After I got the adapter, it refused to recognize my iPod, …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 22 2008
Logres
Marysville, PA
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $138.88
[13 of 14 customers found this review helpful]
Right on the money
5.0
"One of the better Sony purchases I've made. This radio fulfills two of my greatest needs: 1. Beautiful clear radio sound in my dental operatory to sooth my patients 2. The ability to choose my Ipod sound to suit the mood of my patients. I think I've already sold a couple more of these to people in t …"  Read Full Review »
 Report Abuse  (13)  (1)  0 comments
Nov 28 2008
Toothdoc
Atlanta, Ga.
Reviewed at:
Price: $159.99
Didn't power on
2.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Home
"After doing quite a bit of research, going to stores like [...] and after trying so many models, I decided on this one. After that it was a nobrainer to come to this website - it was the lowest price out of the door. Finally when it arrived, didn't power on. [...] I had to order again. [...] "
Nov 9 2009
Raghu G
Cupertino, CA
I am:
  • Audiophile
Reviewed at:
Price: $149.32
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
