Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder
#3
4.1
based on 150 reviews
Ratings Distribution
5 star
77
4 star
44
3 star
11
2 star
1
1 star
17
Category Average
4.1
Low Price:
$179.94 at pcRUSH
$238.99 at Super Warehouse
Find it at Amazon
$179.94 - $238.99
from 2 stores
More Images
Pros
  • Attractive design (42)
  • Simple controls (42)
  • Fast setup (41)
  • Easy setup (37)
  • Fast recording (25)
  • Easy to use (23)
  • Consistent performance (19)
  • High quality picture (18)
  • Consistent burns (15)
  • Quiet (13)
See less See more
Cons
  • Not enough connection options (4)
  • Poor chapter publishing (4)
  • Discs load slowly (3)
  • Reliability (3)
  • No audio monitoring (2)
  • Sony support (2)
  • Confusing set up (1)
  • Difficult to set up (1)
  • Difficult to use (1)
Best Uses
  • Home (44)
  • Movies (25)
  • Office (19)
  • Storage (18)
  • Video files (13)
  • Professional (10)
  • Archiving tv shows (9)
  • Back-up (5)
  • High volume usage (5)
  • Audio files (3)
Provided by Beach Audio
The Sony VRD-MC5 lets you transfer standard-definition and high-definition home video to DVD quickly and easily without using a computer. Simply connect a camcorder, VCR, or other source to make real-time video recordings on durable DVD discs. And if you have a Sony Handycam hard disk drive camcorder, you can create DVD recordings of your home movies at up to 6X speed.Make copies of your high-definition home moviesIf you've got a Sony hard drive or Memory Stick camcorder that uses the AVCHD recording format, use the 'MC5 to burn copies of your high-def footage to standard DVDs. You can play these high-def discs on AVCHD-compatible Blu-ray Disc players. Preview your videos using the built-in 2-1/2" LCD screen, and capture only those scenes you like.Details:
  • records high-definition video to DVD from select Sony AVCHD hard drive and Memory Stick camcorders
  • playback of high-definition recordings requires an AVCHD-compatible Blu-ray Disc player not possible on a standard DVD player
  • records from Sony hard disk drive Handycam camcorders at up to 6X speed
  • records to the following types of discs: - DVD-R, DVD-RW, DVD+R, DVD+R DL, and DVD+RW (DV or analog source) - DVD-R, DVD-RW, and DVD+R (USB source)
  • records digital photos to DVD from Memory Stick, Memory Stick Duo, SD Memory Card, xD Picture Card, and CompactFlash memory cards
  • 2-1/2" LCD screen for previewing digital photos and video
  • high-speed USB interface (USB cable included)
  • i.LINK (IEEE 1394) input for camcorder connection only
  • 1 set of audio/video inputs (composite video, S-video)
  • 7-5/8"W x 2-11/16"H x 8-3/4"D
  • Specification Description
    Model 1937706, VRD-MC5, VRDMC5
    UPC 027242718852
    Aspect Ratio 16:9
    Aspect Ratio 4:3
    Card Slot Compact Flash (type I)
    Card Slot Memory Stick Pro
    Card Slot Memory Stick Pro Duo
    Card Slot SDHC
    Card Slot Secure Digital
    Card Slot xD-Picture Card
    Compatible Formats MPEG2
    IEEE 1394 (Mini) Yes
    Recordable Media Type DVD+R
    Recordable Media Type DVD+R DL
    Recordable Media Type DVD+RW
    Recordable Media Type DVD-R
    Recordable Media Type DVD-RW
    Select DVD Recorders
    Type of DVD Unit DVD Recorder Duplicator
    Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 26, 2009
    Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder Reviews
    Most helpful positive review
    [14 of 14 customers found this review helpful]
    Most helpful negative review
    [5 of 6 customers found this review helpful]
    4.0
    You won't be disappointed!
    "I have been doing video recording since my first child was born - 17 years ago! I had over 40 8mm video camcorder tapes with "precious moments" of my 3 children's lives with no easy way to transfer them to DVD's. I had heard about the Sony DVDirect but was hesitant to purchase it, not knowing if it really worked. Then a friend told me he had bought one and had used it without any problems. So I did alot of r..." Read Full Review »
    Jun 18, 2008 by Photoholic mom of 3
    See more positive Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder reviews
    1.0
    Broke 2 Weeks Out of Warranty
    "Yikes. Used the unit 10 times at NCAA events. When it worked - about 50% of the time - it was great. Two weeks out of warranty it went kaput, and Sony told me to pound sand. Back at you Sony. I own Sony broadcast video products and am very disappointed that they chose not to stand behind this product...." Read Full Review »
    Mar 06, 2009 by pro video
    See more negative Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder reviews
    Displaying 1 - 5 of 150 Reviews
    Show
    Sort by
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Storage
    • Transfer Hi8 to dvd
    "I have been doing video recording since my first child was born - 17 years ago! I had over 40 8mm video camcorder tapes with "precious moments" of my 3 children's lives with no easy way to transfer them to DVD's. I had heard about the Sony DVDirect but was hesitant to purchase it, not knowing if i …"  Read Full Review »
    Was this External Computer DVD Burner review on the Sony VRD-MC5 DVDirect MC5 Multi-Function DVD Recorder helpful to you?
     Report Abuse  (14)  (0)  0 comments
    Jun 18 2008
    Photoholic mom of 3
    West Palm Beach, FL
    I am:
    • Practical
    Reviewed at:
    [71 of 73 customers found this review helpful]
    Simple Device, Well Executed
    5.0
    "I bought one of these to get old video tapes onto DVD before something happens to them and we loose the family memories. It works like a champ. There's nothing fancy about it but it does what it's supposed to do and even my wife can operate it.
    If you want to edit your movies you'll need a computer …"  Read Full Review »
     Report Abuse  (71)  (2)  0 comments
    Nov 28 2008
    Arisdad
    San Diego, CA
    Reviewed at:
    [6 of 6 customers found this review helpful]
    Worth Every Penny
    5.0
      Pros
    • Attractive Design
    • Fast Recording
    • Fast Setup
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    "In a very short time, I have put ALL (dozens) of my VHS tapes onto DVDs, a project I had put off for years when I thought about recording my tapes from my VCR through my digital video camera into the computer using Adobe Premier Elements 2.0 to record on the hard drive and then burning them onto a D …"  Read Full Review »
     Report Abuse  (6)  (0)  0 comments
    Jun 22 2008
    Physics Man
    Woodstock, IL
    I am:
    • Practical
    Reviewed at:
    [3 of 3 customers found this review helpful]
    My search has ended!
    4.0
    Super Informative
    Super Informative
      Pros
    • Attractive Design
    • Fast Recording
    • Fast Setup
    • Simple Controls
      Cons
    • Preview not full-screen
      Best Uses
    • Archiving TV Shows
    • Home
    "For several years I've been looking for a way to easily, quickly, and without much thought or planning--transfer a large number of VHS tapes that have collected themselves into my closet. I love my computer, but I don't want to tie it up with hundreds of hours of video transferring. I must confess I …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Aug 25 2008
    Tony the guy who works for a living
    Durham, NC
    I am:
    • Gearhead
    Reviewed at:
    [30 of 33 customers found this review helpful]
    EASY! EASY! EASY!!
    4.0
    "OMG! This is the BEST way to save your home movies. So easy! I tried to do the very time consuming computer way and all kinds of other DVD recorders with no luck. I have home movies on Sony Beta from 25 years ago and on VHS tapes that turned out beautifully!
    Two things I wish this had is audio as yo …"  Read Full Review »
     Report Abuse  (30)  (3)  0 comments
    Nov 26 2008
    TerrieG
    Mansfield, OHIO
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
