Sony USM-16GL 16GB Micro Vault Click USB Flash Drive
#18
4.7
based on 6 reviews
Ratings Distribution
5 star
15
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.3
$49.99 - $64.99
from 5 stores
More Images
Pros
  • Easy to use (13)
  • Large capacity / good size (13)
  • Fast (12)
  • Easy setup (11)
  • Portable (11)
  • Reliable (11)
See less See more
Best Uses
  • Back-up (9)
  • Additional storage (8)
  • File transfer (8)
  • Music (5)
  • Video (5)
  • Picures (1)
Provided by Staples
Click to open or close just like a ballpoint pen with a single push. This enables a simple connection to the PC and with the convenient one piece design, you don’t have to worry about losing the cap. Emboss processing makes it easy to use the device with ut leaving any fingerprints on the surface of the product. Click to open or close just like a ballpoint pen with a single push Micro Vault USM-L supports Windows ReadyBoost. Hi-Speed USB (USB 2.0) Sony Micro Vault USB Click Flash Drives
Specification Description
Model USM-16GL, USM16GL
UPC 027242737167
Computer Compatibility PC and Macintosh
Connection External
Drive Capacity 16GB
Port Compatibility USB
Storage Capacity 16 GB
Type of Drive Flash Pocket Drive Duplicator
Sony USM-16GL 16GB Micro Vault Click USB Flash Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 10, 2009
Sony USM-16GL 16GB Micro Vault Click USB Flash Drive Reviews
Most helpful positive review
[5 of 6 customers found this review helpful]
Most helpful negative review
4.0
No Lost Caps!
"Sony has done a great job at designing a flash drive without a cap; it automatically retracts when withdrawn from a USB port. It's very thin and light weight; I can barely feel it hanging around my neck. This drive also works great with Vista's Ready Boost. The only bad thing I have to say about this flash drive is that the price is higher than comparable flash drives and THE LIGHT IS NOT PURPLE!..." Read Full Review »
Dec 04, 2008 by CMayhem
See more positive Sony USM-16GL 16GB Micro Vault Click USB Flash Drive reviews
3.0
Works Great, But Feels Cheap
"I've used a few 16GB jump drives, and this has been the fastest, and more reliable so far. However, the whole thing feels cheap, and I'm always worried that it is going to crack. The whole device is spring-loaded, and I hope that doesn't break, and make the whole thing useless...." Read Full Review »
Sep 12, 2009 by Shadowhawk
See more negative Sony USM-16GL 16GB Micro Vault Click USB Flash Drive reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
No Lost Caps!
4.0
"Sony has done a great job at designing a flash drive without a cap; it automatically retracts when withdrawn from a USB port. It's very thin and light weight; I can barely feel it hanging around my neck. This drive also works great with Vista's Ready Boost. The only bad thing I have to say about thi …"  Read Full Review »
Was this Flash Stick review on the Sony USM-16GL 16GB Micro Vault Click USB Flash Drive helpful to you?
 Report Abuse  (5)  (1)  0 comments
Dec 4 2008
CMayhem
Dallas,TX USA
Reviewed at:
Price: $64.99
[3 of 3 customers found this review helpful]
Awesome
5.0
"Best flash drive I've ever owned. Very fast. I would recommend to anyone.
I had the Sandisk 16GB Cruzer, It does't compare to this. (I returned the Sandisk and bought this instead) "
 Report Abuse  (3)  (0)  0 comments
Feb 23 2009
Brandon P. Chojnacki
Gaylord, MI
Reviewed at:
Price: $64.99
Great price holds plenty of pictures
5.0
    Pros
  • Easy To Setup
  • Easy To Use
  • Fast
  • High Capacity
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • Backup
  • File Transfer
  • Music
  • Video
"used to transfer pictures from one computer to another "
Oct 10 2009
jprompt
holland, mi
I am:
  • Casual user
Reviewed at:
Price: $49.99
[5 of 10 customers found this review helpful]
Works Fine with Vista
5.0
"So far so good. It was easy to install. There is a web site to download software if you need help. With this one you have to move your (pictures,music,Docs, whatever) to the drive that the "Sony Micro vault" is using, it will tell which when you put it in your USB port and then you can just delete w …"  Read Full Review »
 Report Abuse  (5)  (5)  0 comments
Oct 17 2008
K. MacDonald
Colorado
Reviewed at:
Price: $64.99
Great Product!
5.0
"Great product and quite tiny. As always, Sony makes a reliable product. Probably the most convenient size for a 16GB flash drive. "
Jul 30 2009
Mary Starkey
Independence, MO USA
Reviewed at:
Price: $64.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
