Sony STR-DH500 A/V Receiver
#294
4.2
based on 33 reviews
from $149.99 - $199.99
Ratings Distribution
5 star
10
4 star
19
3 star
3
2 star
1
1 star
0
Category Average
4.3
More Images
Pros
  • Great sound quality (13)
  • Accurate controls (11)
  • Easy setup (11)
  • Good power output (11)
  • Durable (6)
  • Awesome (1)
  • Good value (1)
See less See more
Cons
  • Limited functions (5)
  • Confusing / bad remote control (1)
  • Difficult to set up (1)
Best Uses
  • Home theater (13)
  • Basic systems (12)
  • Large rooms (8)
  • Smaller rooms / apartments (8)
  • Audiophiles (2)
Provided by OneCall
5 HD Inputs compatible with HD video
The STR-DH500 has ample HD connections compatible with various HD signals. Being the central hub of your audio and video sources, the STR-DH500 ensures seamless compatibility with today’s demanding HD sources.
HD Film Quality with 24p TRUE CINEMA
Most of all Hollywood movies are shot at 24 frames per second, and Blu-ray Disc™ movies are mastered at 24 frame per second, so it is only fitting that the STR-DH500can output your films at 1080/24p for a true film-like experience at home.
Multi Function Audio Input
Sony’s DIGITAL MEDIA PORT plays back music from various audio sources whether it is stored on an iPod, Walkman, Bluetooth device or PC.
Quick Speaker Set Up
An ideal listening experience is only a button away. Simply place the included microphone in your listening position, push a single button and speaker placement, distance and delays are automatically adjusted.
Footnotes:
1. Requires Digital Media Port accessory compatible with the device (sold separately).
2. Sirius requires optional antenna and subscription service.
iPodreg; support is limited based upon which optional Digital Media Port is being used. The TDM-IP20 will support the following players: iPodreg; touch, iPodreg; classic, iPodreg; Nano 1st, 2nd & 3rd generation, iPodreg; 4th& 5th generation &iPodreg; Mini. The TDM-IP 50 adds iPhone™ support as well.
Specification Description
Model STR-DH500, STRDH500
UPC 027242753556
Analog Audio (1) Rear Output
Analog Audio (4) Rear Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (2) Rear Input
Channels 2
Color Black
Command / Control Digital MEDIA Port
Component Video (1) Rear Output
Component Video (2) Rear Input
Depth (Inches) 12.75
HDMI (1) Rear Output
HDMI (3) Rear Input
Headphone Jack Front Output
Height (Inches) 6.25
Optical (2) Rear Input
Remote Control Included
Surround Modes DTS
Surround Modes Dolby Digital
Surround Modes Dolby Pro Logic
Surround Modes Dolby Pro Logic II
Surround Power Rating (watts) 100
Tuner AM
Tuner FM
Type of Receiver Stereo
Watts per channel 100
Weight (Pounds) 16.4
Width (Inches) 17
Sony STR-DH500 A/V Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Sony STR-DH500 A/V Receiver Reviews
Most helpful positive review
[21 of 24 customers found this review helpful]
Most helpful negative review
[3 of 4 customers found this review helpful]
4.0
Great Value
"Sony's new entry level A/V receiver is a clear step up from the old model. Sound quality is very good. The HDMI switching and Bravia-sync are a bounus espcially since the rest of the components I have are compatible. The menu is not intuitative but can be navigated reasonably well with a little practice. While Sony clearly indicates the HDMI connections are not for audio, it is still annoying to shell out for di..." Read Full Review »
Mar 31, 2009 by Vitosvettes
See more positive Sony STR-DH500 A/V Receiver reviews
3.0
Great for starters!
"This is good for basic setups. I am using this for my TV, speaker system connected to my DVD, Ipod and turntable. I renamed some of the menus. I didn't like that the HDMIs are basically passthroughs and you need a separate connection for audio for each inputs. The receiver is pretty big too...." Read Full Review »
Aug 05, 2009 by ClaptonIsGod
See more negative Sony STR-DH500 A/V Receiver reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
Great Value
4.0
"Sony's new entry level A/V receiver is a clear step up from the old model. Sound quality is very good. The HDMI switching and Bravia-sync are a bounus espcially since the rest of the components I have are compatible. The menu is not intuitative but can be navigated reasonably well with a little prac …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sony STR-DH500 A/V Receiver helpful to you?
 Report Abuse  (21)  (3)  0 comments
Mar 31 2009
Vitosvettes
Annapolis, MD
Reviewed at:
Price: $199.99
Seems like a good replacement receiver
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
  • Difficult To Set Up
    Best Uses
  • Home Theater
"The receiver makes a good replacement for my JVV884 that recently went down. It has decent power. The sound processing is great. The menu took some getting used to but is becoming easier with each use. The power ratings seem a little high as it seems more like 65 watts x 5. Overall it is a great rec …"  Read Full Review »
Nov 14 2009
KFXryder
Knoxville, TN
I am:
  • Tech Savvy
Reviewed at:
Price: $159.00
Sony keeps its name and reputation!
5.0
    Pros
  • Accurate Controls
  • Awesome
  • Clean Sound
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"Awesome product. Easy to set up. Sony keeps its name and reputation by producing reliable products with high quality "
Nov 17 2009
Agnes - The Flying Hawaiian
Leesburg, VA
I am:
  • Movie Enthusiast
  • Practical
  • Technically Challenged
Reviewed at:
Price: $159.00
Great for starters!
3.0
    Pros
  • Easy To Set Up
  • Good Power
    Cons
  • Limited Functions
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"This is good for basic setups. I am using this for my TV, speaker system connected to my DVD, Ipod and turntable. I renamed some of the menus. I didn't like that the HDMIs are basically passthroughs and you need a separate connection for audio for each inputs. The receiver is pretty big too. "
 Report Abuse  (3)  (1)  0 comments
Aug 5 2009
ClaptonIsGod
Los Angeles, CA
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $159.00
GREAT VALUE!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
"This does so much more than some owners will ever need. my comcast DVR remote works with this Sony Receiver too. It is easy to use if you don't mind reading the manual; no one can expect a product that does everything to be plug and play!
I did spend an afternoon reading and interacting with the …"  Read Full Review »
Jul 28 2009
Lorraine & David
South Florida
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Reviewed at:
Price: $158.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
