Sony STR-DG1200 7.1-Channel Home Theater Reciever
4.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.3
Pros
  • Easy setup (2)
  • Good power output (2)
  • Accurate controls (1)
  • Durable (1)
  • Great sound quality (1)
See less See more
Best Uses
  • Home theater (2)
Provided by OneCall
Optimized for Blu-ray Disc™ and Other HD Sources
The STR-DG1200 is engineered to be the ideal Blu-ray Disc™ compatible A/V receiver, and works with the Sony family of Blu-ray Disc players (sold separately). Superior video switching and audio performance ensure easy compatibility with today's demanding HD sources. The STR-DG1200 features 4 High Definition Multimedia Interface (HDMI™) inputs which are capable of accepting resolutions up to 1080p, offering the exceptional video quality that Blu-ray Disc format can deliver.
Up to 8 channels of Linear PCM audio
Compatible with Blu-ray Disc™ format linear PCM (uncompressed) output, producing up to eight channels of high quality audio reproduction.
HDMI Active Intelligence
The receiver can detect and receive the best possible video and audio signals from all connected devices-making connection and performance as simple as plugging in a single wire. Sony HDMI Active Intelligence produces both audio and video through one HDMI cable (sold separately).
Faroudja® DCDi Cinema™ Chipset for Up Scaling to 1080p
The IC processor developed by Faroudja and first used by Sony upscales video signals (less than 1080p) to 1080p via HDMI. This chipset reduces image jaggedness and block noise, while reproducing colors that are closer to the original. The end result is a beautiful and smooth high definition image.
xross Media Bar® Inspired Graphic User Interface
An on-screen menu that simplifies the most complex operations of an A/V receiver for home theater applications. This advanced menu system incorporates icons, an easy to follow tree system and a blending technique so users know exactly where they are among the various settings while still watching their main video source (up to 1080i). The menu includes access to DIGITAL MEDIA PORT accessories (sold separately), which lets you assign HDMI inputs and provides independent A/V sync control for each input. It's simple. Just pick up the remote and a whole new experience will be revealed.
Digital Cinema Auto Calibration
An ideal listening experience is only a button away. Simply place the included microphone in your listening position, push a single button and speaker position, distance and delays are automatically calibrated. Sony Digital Signal Processing uses feedback between the microphone and receiver to optimize sound settings.
Sirius and XM Connect-and-Play™ Ready
A world of digital radio at your fingertips. Connect the optional antenna for either Sirius® and/or XM® subscription service and enjoy the variety and quality of digital radio with the superior sound quality of an A/V receiver.
Portable Audio Enhancer
The 7.1 A/V Receivers are ideal for today's portable audio devices. A powerful Digital Signal Processor expands the quality of sound from any connected device. Simplified front-side audio and video connections make it easy to play content from your portable audio device through the receiver.
BRAVIA® Sync for Theatre
The receiver can transmit control functions, as well as the audio and video signals, to select BRAVIA® televisions.
Specification Description
UPC 027242729865
Analog Audio (1) Front Input
Analog Audio (2) Rear Output
Analog Audio (8) Rear Input
Analog Audio / Video (1) Front Input
Analog Audio / Video (2) Rear Output
Analog Audio / Video (4) Rear Input
Color Black
Component Video (1) Rear Output
Component Video (3) Rear Input
Depth (Inches) 15.4
HDMI (1) Rear Output
HDMI (4) Rear Input
HDMI Version 1.3
Headphone Jack Front Output
Height (Inches) 6.25
Multi-Channel 7.1 Channel Input
Optical (1) Rear Output
Optical (3) Rear Input
Phono Rear Input
Preamplifier Outputs Subwoofer
Remote Control Included
Remote Control Learning
Satellite Radio Sirius Satellite Radio Ready
Satellite Radio XM Radio Ready
Speaker Switching A+B
Speaker Switching A/B
Speaker Terminals 5-Way Binding Post
Surround Modes DTS
Surround Modes DTS 96/24
Surround Modes DTS ES
Surround Modes DTS NEO:6
Surround Modes Dolby Digital
Surround Modes Dolby Digital EX
Surround Modes Dolby Digital Plus
Surround Modes Dolby Pro Logic
Surround Modes Dolby Pro Logic II
Surround Modes Dolby Pro Logic IIx
Surround Modes Dolby TrueHD
Surround Modes THX
Surround Power Rating 110 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
Weight (Pounds) 26.9
Width (Inches) 17
Sony STR-DG1200 7.1-Channel Home Theater Reciever Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: STR-DG1200 7.1-Channel Home Theater Reciever
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 30, 2009
Sony STR-DG1200 7.1-Channel Home Theater Reciever Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Good User Interface
4.0
    Pros
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
"I'm glad to see that Sony is paying more attention to the user interface than they used to. My previous Sony receiver, and its remote, was full of buttons whose use I never did discover. This one is cleaner, and it has "GUI Mode" where the controls are displayed in a primitive but useful graphics mo …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sony STR-DG1200 7.1-Channel Home Theater Reciever helpful to you?
Jan 30 2009
Wayno
Minneapolis, Minnesota
I am:
  • Tech Savvy
Reviewed at:
better features than i thought
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • none so far
    Best Uses
  • Home Theater
"It shut it self down when i really pumped saying protection so i moved it to a better ventilated area an have not had anymore problems. Other than that i think i need to check the speaker terminal connections. Why pay the EX edition money when you can get it all with this 1200 model. "
Jan 26 2009
Naytt
Newport News, Va.
I am:
  • Musically Inclined
  • Professional
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
