Sony SS-B3000 3-Way Bookshelf Speakers
#46
4.5
based on 36 reviews
from $83.60 - $99.99
Ratings Distribution
5 star
23
4 star
10
3 star
2
2 star
0
1 star
1
Category Average
4.4
More Images
Pros
  • Attractive design (4)
  • Easy setup (4)
  • Great sound quality (4)
  • Compact (2)
  • Easy to connect (2)
  • Powerful (2)
  • Sturdy (2)
  • Blends well with decor (1)
  • Handsome unobtrusive (1)
  • Quality mounting hardware (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Lacks rubber feet (1)
  • Unattractive design (1)
Best Uses
  • Basic systems (2)
  • Improving sound (2)
  • Front surround speakers (1)
  • Saving space (1)
  • Smaller rooms / apartments (1)
  • Surround sound speakers (1)
Provided by MacMall
SS B3000 - Left / right channel speakers - 3-way When it comes to creating high-quality Hi-Fi sound in your home, selecting the proper speakers is even more important. Sony makes it easy with an extremely wide range of different speakers. Whether you're listening to a refined string quartet or ... When it comes to creating high-quality Hi-Fi sound in your home, selecting the proper speakers is even more important. Sony makes it easy with an extremely wide range of different speakers. Whether you're listening to a refined string quartet or watching a powerful action-packed movie, Sony's speakers are designed to deliver an intensive acoustic experience that is both powerful and emotional.PRODUCT FEATURES:8" newly developed Kevlar H.O.P. woofer;3 " enhanced H.O.P. cone - mid driver;1" nano fine balanced dome tweeter;Sound reproduction to 50kHz (for high resolution audio);120W maximum input power.
Specification Description
Model SS-B3000, SSB3000
UPC 027242712836
Connection Type Cable
Speaker Type Speaker
Sony SS-B3000 3-Way Bookshelf Speakers Questions
Questions and Answers
Where to Buy
$83.60
BizRate Rating Outstanding 9.4
$98.00
$99.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
Product Reviews
Last update: Sep 21, 2009
Sony SS-B3000 3-Way Bookshelf Speakers Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
Most bang for the buck!
"I added these to my Sony Surround 5.1 system in place of my front L+R speakers. Once I set up for "large" front speakers on the receiver, which drops the crossover from 150Hz to 75Hz for these channels, I appreciated heo wider, smoother response. The sub-bass is also fatter & punchier as it has an octave less to reproduce. I'd still like to put them on 12"-18" stands eventually - but they cost more than the spe..." Read Full Review »
Apr 14, 2008 by Sound-man Hank
See more positive Sony SS-B3000 3-Way Bookshelf Speakers reviews
3.0
Definitely not audiophile grade, but all right
"Before I knew much about sound (and before Best Buy offered the Insignia NS-B2111's), I snagged these while they were still under a hundred dollars. Inexplicably, they're usually just over one hundred these days. Regardless, this price range represents a pretty good value, considering you get a three-way design with a nicely-sized (8") woofer. Unfortunately, value doesn't necessarily equal quality. For casual l..." Read Full Review »
Jan 29, 2008 by Squonk
See more negative Sony SS-B3000 3-Way Bookshelf Speakers reviews
Displaying 1 - 5 of 36 Reviews
Show
Sort by
3.0
"Before I knew much about sound (and before Best Buy offered the Insignia NS-B2111's), I snagged these while they were still under a hundred dollars. Inexplicably, they're usually just over one hundred these days. Regardless, this price range represents a pretty good value, considering you get a thre …"  Read Full Review »
Was this Speaker Stand & Mount review on the Sony SS-B3000 3-Way Bookshelf Speakers helpful to you?
Jan 29 2008
Squonk
Undisclosed
Reviewed at:
4.0
    Pros
    Cons
  • Lacks rubber feet
    Best Uses
"I added these to my Sony Surround 5.1 system in place of my front L+R speakers. Once I set up for "large" front speakers on the receiver, which drops the crossover from 150Hz to 75Hz for these channels, I appreciated heo wider, smoother response. The sub-bass is also fatter & punchier as it has an …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Apr 14 2008
Sound-man Hank
Shirley, NY
I am:
  • Amateur audio recordist
  • Avid video enthusiast
Reviewed at:
Best speakers I've ever had. 5 stars.
5.0
    Pros
  • Attractive Design
  • Easy Setup
  • Quality Mounting Hardware
  • Sturdy
    Cons
  • None
    Best Uses
  • Improving Sound
"I have 2 pairs of these speakers which I use for full stereo. I have 2 of these speakers and 2 in the back for a surround sound like experience which is great for listening to music,movies,video games, tv shows on DVD,etc. A lot of the cds I own sound great this way you can hear vocals,guitar solos, …"  Read Full Review »
Apr 27 2009
Matt the Cat
Grand Haven, MI
I am:
  • Practical
Reviewed at:
Price: $83.60
Not bad... Not bad at all.
5.0
"I bought these speakers for my dorm. They are a little big in size to be considered bookshelf speakers, but they work well for my purpose. The store display was not working, so I was a little reluctant to buy them, but for 75 dollars plus tax, I bought them anyway. I hooked these up to my nice pione …"  Read Full Review »
Jan 4 2008
P-Town
Reviewed at:
Pure Brillant
5.0
"I use this in my apartment as part of a 7.1 surround system. I got 4 of these to use as my rear and side speakers. They work wonderful. They are a bit big as rear speakers, but I built some pretty nifty stand that they sit on and place then good and it looks awesome. When I'm listening to music I pu …"  Read Full Review »
May 23 2008
Anomics
Idaho
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
