Sony SPK-HCE Sports Pack Camcorder Waterhousing
#121
4.0
based on 12 reviews
Ratings Distribution
5 star
3
4 star
7
3 star
1
2 star
1
1 star
0
Category Average
4.2
Low Price:
$157.99 at B&H Photo Video
 Trusted:
$158.49 at Adorama
Find it at Amazon
$157.99 - $249.99
from 10 stores
More Images
Pros
  • Seals easily (10)
  • Easily loaded equipment (7)
  • Lightweight (7)
  • Well built / quality construction (7)
  • Easy to use (1)
See less See more
Cons
  • Distracting reflections (1)
Best Uses
  • Underwater photography (8)
  • Waterproofing cameras (8)
Provided by ClubMac
SPK-HCE Camcorder Waterhousing Shoot from below the surface with this water-resistant camcorder sports pack and capture the moment like never before. Nothing recreates your underwater adventures like a water-resistant sports pack. Compatible with nearly all 2006-2009 Handycam camcorders, the SPK-HCE sports pack not only allows you to capture unique marine video footage from depths up to 17 feet (5m), but even allows you to record audio with the built-in microphone. In addition to the hard plastic housing to protect your camcorder from watery mishaps, the SPK-HCE features a mounting shoe and external controls for power, record, zoom and photo capture.Features:
  • Hard-plastic housing shields camcorder from rain, snow, and other moisture
  • Records audio via built-in stereo microphone
  • Usable depth: Up to 17ft (5m): Offers waterproof protection up to 17 feet deep.
  • Button Functions: Power On/Off
  • Record Start/Stop
  • Zoom Tele/Wide
  • Mode Video/Photo
  • Photo Capture
  • Compatible with nearly all 2006-2009 Handycam camcorders.
  • Convenient shoulder strap
  • New camera mounting shoe
Specifications:&nbsp&nbsp&nbsp&nbsp• Material : Plastic (PC, ABS), Glass
Specification Description
Model SPK-HCE, SPKHCE
UPC 027242749399
Material Plastic
To Fit Sony
Sony SPK-HCE Sports Pack Camcorder Waterhousing Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2009
Sony SPK-HCE Sports Pack Camcorder Waterhousing Reviews
Most helpful positive review
[12 of 12 customers found this review helpful]
Most helpful negative review
4.0
Good unit
"I purchased this unit for a Sony HDR-HC3 camcorder in February 2008. I have used it extensively in Tahiti, Hawaii and a water park in Orlando. It works well underwater. I did go well below 17 feet while Aquabiking, but it didn't cause in problems. I only had two problems: buoyancy and viewing the screen in the mirror. The buoyancy problem is solved with the use of weights. The mirror is marginally useful in pool..." Read Full Review »
Jun 29, 2009 by MauiNate
See more positive Sony SPK-HCE Sports Pack Camcorder Waterhousing reviews
2.0
Very cool... except in bright sunshine
"I bought this primarily for use on the beach and in the water. However, bright sunlight renders it nearly useless because of the transparent body. The sun shining through the top of the housing makes it nearly impossible to see the camcorder's monitor through the otherwise ingeniously designed pop-out mirror. And unlike some of Sony's previous "Sports" housings, this one does not offer the option of using the ca..." Read Full Review »
May 25, 2009 by Wilson
See more negative Sony SPK-HCE Sports Pack Camcorder Waterhousing reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
Good unit
4.0
I only had two problems: buoyancy and viewing the sc …"  Read Full Review »
Was this Waterproof Housing review on the Sony SPK-HCE Sports Pack Camcorder Waterhousing helpful to you?
 Report Abuse  (12)  (0)  0 comments
Jun 29 2009
MauiNate
South Carolina
Reviewed at:
Price: $249.99
Great for rafting video
4.0
    Pros
  • Easily Loaded Equipment
  • Lightweight
  • Seals Easily
  • Strong Construction
    Cons
    Best Uses
  • Waterproofing Cameras
"I had used an older, larger Sport Pack with a previous camera and had lots of fun shooting water activities for our church youth group. Since I wore out that camera, I needed a new case for my latest Sony. I received it the day before my raft trip, tested it once in the water for leaks and jumped on …"  Read Full Review »
Aug 13 2009
hey camera guy
Salem, Oregon
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $157.99
Finally a great underwater housing
5.0
    Pros
  • Lightweight
  • Seals Easily
    Cons
  • None
    Best Uses
  • Underwater Photography
"I had a previous model housing for an old VHS-C Sony video camera that worked well after even 15 years of use and still fit the newer cameras. However, it was big and bulky and you couldn't use the lcd screen - hard to get the picture framed right underwater. This new case does it all. I have a S …"  Read Full Review »
Sep 2 2009
Exuss
Lafayette, LA USA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $158.49
perfect for our off shore tuna trips
4.0
    Pros
  • Lightweight
  • Seals Easily
    Cons
  • None
    Best Uses
"the sony sport pack is great for the boat.we use ours for off shore tuna trips,there is salt water, fog, and blood we also put the sport pack on a mono pod and shoot under water as fish get close to the boat.i cant think of on bad thing to say about this product. "
Nov 3 2009
harbormaster phil
depoebay oregon
Reviewed at:
Price: $158.49
2.0
    Pros
  • Seals Easily
    Cons
  • None
    Best Uses
"I bought this primarily for use on the beach and in the water. However, bright sunlight renders it nearly useless because of the transparent body. The sun shining through the top of the housing makes it nearly impossible to see the camcorder's monitor through the otherwise ingeniously designed pop-o …"  Read Full Review »
May 25 2009
Wilson
Jackson, Mississippi
I am:
  • Casual Photographer
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
