Close Login Module
Join
Sony SPK-HCD Underwater Camcorder Sports Pack
4.3
based on 28 reviews
Ratings Distribution
5 star
15
4 star
8
3 star
3
2 star
1
1 star
1
Category Average
3.5
Pros
  • Easy to use (22)
  • Quality construction (18)
  • Good interface with camcorder (14)
  • Lightweight (9)
  • Functional (3)
  • Improves performance (3)
  • Durable (2)
  • Good depth range (2)
  • Water-tight seals (2)
  • Great controls and access (1)
See less See more
Cons
  • No performance improvement (3)
  • Bulky (2)
  • Poor interface (2)
  • A tad bulky vs camcorder (1)
  • Documentation limited (1)
  • Heavy (1)
  • Not camera specific (1)
  • Not neutrally bouyant (1)
  • Stiff buttons (1)
  • Viewer- hard to keep open (1)
Best Uses
  • Shooting outdoors (17)
  • Travel (9)
  • Home movies (6)
  • Snorkeling (3)
  • Shooting indoors (2)
  • Diving (1)
  • Freediving (1)
  • High humidity cover (1)
  • Paintball (1)
  • Pool water park (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: SPK-HCD Underwater Camcorder Sports Pack
See all eBay results
  at eBay.com
Product Reviews
Last update: Apr 6, 2009
Sony SPK-HCD Underwater Camcorder Sports Pack Reviews
Most helpful positive review
[34 of 41 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
4.0
Great Idea
"This takes great pictures and sound underwater. The problems come in if you forget to open the lens as I did, you cant fix it once you are in the water. Also there is some problem with being able to see what you are shooting in the little side port as it has a hard time staying open. However is you keep it pointed on what you are shooting it works great1..." Read Full Review »
Jan 05, 2009 by tori
See more positive Sony SPK-HCD Underwater Camcorder Sports Pack reviews
2.0
Hard to hold...
"This product is used in shallow water for video and still image capture and while the controls are fantastic, fully functioning, and easy to find, read and work with, it seems that sony has again missed the mark by not making these items neutrally bouyant. We would like to see this item suspend not more than say 12 feet or 4M it would indeed be perfect. Sadly though the effort required to hold the item in place ..." Read Full Review »
Apr 10, 2008 by MMP Studios
See more negative Sony SPK-HCD Underwater Camcorder Sports Pack reviews
Displaying 1 - 5 of 28 Reviews
Show
Sort by
Great Idea
4.0
"This takes great pictures and sound underwater. The problems come in if you forget to open the lens as I did, you cant fix it once you are in the water. Also there is some problem with being able to see what you are shooting in the little side port as it has a hard time staying open. However is you …"  Read Full Review »
Jan 5 2009
tori
Lancaster, OH
Reviewed at:
[3 of 3 customers found this review helpful]
Paintball Camcorder Case
4.0
    Pros
  • Durable
  • Easy To Use
  • Highly Compatible
    Cons
    Best Uses
  • Paintball
  • Shooting Outdoors
"Alright, here's the deal - I just bought me a $1500 Sony camcorder, so what's a paintball addict to do? Buy the SPK-HCD of course!Yeah, there's little grooves and divots where paint can get lodged on the case, but hey - this thing is submersible. Get it dirty, get it gooped up with sticky paintballs …"  Read Full Review »
Apr 14 2008
ZORN
Lynchburg, VA
I am:
  • Paintball Addict
  • Parent
Reviewed at:
Hard to hold...
2.0
    Pros
  • Durable
  • Great Controls and access
  • Stable platform
  • Wide Port
    Cons
  • Not Neutrally bouyant
    Best Uses
  • High Humidity Cover
  • Rain Guard
  • Splash Guard
"This product is used in shallow water for video and still image capture and while the controls are fantastic, fully functioning, and easy to find, read and work with, it seems that sony has again missed the mark by not making these items neutrally bouyant. We would like to see this item suspend not …"  Read Full Review »
Apr 10 2008
MMP Studios
Lakeland, Florida
Reviewed at:
Worthwhile Investment
5.0
    Pros
  • Easy To Use
  • Functional
  • Good Depth Range
  • Water-tight Seals
    Cons
    Best Uses
  • Snorkeling
  • Swimming Pool
"The Sony SPK-HCD Underwater Camcorder Sports Pack is about the coolest thing since sliced bread...well, maybe not the coolest, but... We were going back to Hawaii this year and felt like we needed more than just the disposable underwater cameras. So, we bought this pack for our HDR-SR5 and took it …"  Read Full Review »
Mar 19 2009
Stacey G
NJ
I am:
  • Casual Photographer
Reviewed at:
[1 of 1 customers found this review helpful]
Fantastic with a Current Camera
4.0
    Pros
  • Easy To Use
  • Good Interface With Camcorder
  • Lightweight
  • Quality Construction
    Cons
  • None
    Best Uses
  • None
"I've read reviews where people mention the inconvenience of the mirrored display on the side, and the lack of bouyancy. I have a new camera, an HDR-SR12 that's designed to be used with this underwater case. When the camera is positioned in the case and turned on before closing, the camera's displa …"  Read Full Review »
Sep 2 2008
Bubut
Vancouver, WA
I am:
  • Aspiring Film Maker
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
BizRate Rating Outstanding 9.6
$159.95
No Tax Outside NY
BizRate Rating Outstanding 9.1
$159.95
$175.49
$179.99
Overstock.com Club O Deals!
$199.99
$199.99
$222.99
$222.99
$249.99
$249.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
