Sony SAL1635Z System 16-35mm f/2.8 ZA SSM
#215
5.0
based on 5 reviews
Ratings Distribution
5 star
5
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.5
$1,899.00 - $1,899.99
from 4 stores
More Images
Pros
  • Fast / accurate auto-focus (3)
  • Fast focus (3)
  • Well built / quality construction (3)
  • Rugged (2)
  • Balances well on an a900 (1)
  • Build quality (1)
  • Consistent output (1)
  • Great picture quality (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Pricey (1)
Best Uses
  • Landscapes (3)
  • General purpose (2)
  • Confined areas (1)
  • Special effects (1)
  • Urban architectural photo (1)
  • Wide vistas (1)
Provided by OneCall
Super Wide-Angle Zoom 16-35mm
Perfect for dramatic landscapes, interiors and unique perspectives on everyday objects. (35mm equivalent when used with APS-C format cameras: 24-52.5mm.)
Fast, constant aperture f/2.8
While typical zoom lenses lose maximum aperture toward the telephoto end, the SAL1635Z maintains a very fast f/2.8 across the entire zoom range for the utmost flexibility in challenging light conditions.
World-famous Carl Zeiss optics
Carl Zeiss lenses are prized by photographic professionals. The SAL1635Z features the classic Carl Zeiss Vario-Sonnar zoom lens design.
Superb, corner-to-corner consistency
Resolution, contrast and image brightness are maintained not just at the image center, but also in the corners -- a hallmark of Carl Zeiss design.
Carl Zeiss T* (T-star) coatings
Internal reflections on the glass-to-air surfaces can create veiling glare, which reduces contrast and takes the life out of your pictures. The SAL1635Z overcomes this issue with the famous Carl Zeiss T* coatings.
Super low distortion
The lens minimizes field curvature even at wide angle settings.
Short Minimum Focusing Distance
With the ability to focus as closely as 11 inches (0.28 m), this wide angle zoom lens also lets you move in for dramatic perspectives on people, natural subjects and close-up details.
In-Camera Image Stabilization
Because Sony builds SteadyShot® image stabilization into the a cameras, the SAL1635Z does what other lenses can't. This is the world's only large-aperture, full-frame capable wide-angle zoom with the benefit of image stabilization (as of Sept. 2008).
SSM (Super Sonic wave Motor)
Large, wide-aperture zoom lenses tend to have larger, heavier elements that are harder to drive in Auto Focus. Sony achieves fast, smooth, near-silent automatic focusing with the Super Sonic wave Motor. It delivers high torque, high speed and rapid start/stop response.
Focus Hold Button
For creative control a focus hold button conveniently located on the lens barrel lets you firmly lock in focus. Focus Hold also enables image preview with the a900 D-SLR.
Multi-Element Design
The SAL1635Z incorporates 17 elements in 13 groups for superb sharpness, speed and edge-to-edge consistency.
Super Extra-low Dispersion (Super ED) and ED glass
Newton showed that different colors bend at different angles when they pass through glass. In lenses, this causes the problem of chromatic aberration. Sony solves the problem with a Super ED and an ED glass element. You get sharp, clear images with well defined colors.
Three aspherical elements
Fast lenses have a difficult time maintaining sharpness at maximum aperture. The SAL1635Z is amazingly fast for a 16-35mm zoom. Yet thanks to three aspherical elements, the lens achieves incredibly consistent, corner-to-corner sharpness at maximum aperture.
Circular Aperture
Because the aperture blades form a near circle at the wide openings used for low-light shots, spot-light sources have a pleasing circular defocused effect. The lens features nine aperture blades.
Auto Clutch
For reliable operation, the manual focus ring does not rotate in auto-focus mode.
Specification Description
Model SAL1635Z
UPC 027242714267
Aperture f/22
Filter/Wide Angle Capability 77mm
Fits Camera Made By Sony
Lens Type Wide-Angle
Magnification .24
Minimum Focusing Distance 1 ft.
Select Digital Specific Lenses
Select Lens Style Wide Zooms
Select Mount Sony Alpha / Maxxum
Sony SAL1635Z System 16-35mm f/2.8 ZA SSM Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 12, 2009
Sony SAL1635Z System 16-35mm f/2.8 ZA SSM Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[12 of 12 customers found this review helpful]
Zeiss rounds out the Sony zoom line-up
5.0
    Pros
  • Balances well on an A900
  • Build Quality
  • High image quality
    Cons
  • Price
    Best Uses
  • Confined areas
  • Wide vistas
"I am a full time Professional photographer. My use for this lens is primarily for shooting weddings and some general photography.
The 16-35/2.8 is the prefect companion to the Zeiss 24-70/2.8. Same robust build quality, matching Zeiss color and contrast.
The zoom ring is smooth but well dampe …"  Read Full Review »
Was this Camera Lens review on the Sony SAL1635Z System 16-35mm f/2.8 ZA SSM helpful to you?
 Report Abuse  (12)  (0)  0 comments
Mar 12 2009
Fotografz
Detroit, Michigan
Reviewed at:
Price: $1,899.99
[1 of 1 customers found this review helpful]
Sony 16-35mm f/2.8 Wide-Angle Zoom
5.0
    Pros
  • Quick Focus
  • Rugged
  • Sharp Focus
  • Strong Construction
    Cons
  • None
    Best Uses
  • General Use
  • Landscape Photography
  • Urban Architectural Photo
"Excellent corner-to-corner sharpness and contrast.
Geometric distortion is well controlled for a lens of this type.
When used with the Sony Alpha 900 body you can zoom out, correct architectural verticals, expose, and then crop the finished image while retaining fine details.
Besides enhancin …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 12 2009
Jim
Chicago, IL
I am:
  • Professional
Reviewed at:
Price: $1,899.99
Excellent Wide-Angle Zoom Lens
5.0
    Pros
  • Quick Focus
  • Rugged
  • Sharp Focus
    Cons
  • Heavy
    Best Uses
"Using the Imatest software to compare to the legendary Minolta 17-35mm f3.5 G lens, I find that the Sony/Zeiss 16-35mm f2.8 lens has equal sharpness at the center, but better sharpness and less chromatic aberration at the corners. So, Zeiss has improved upon the rare and coveted Minolta lens, in th …"  Read Full Review »
Apr 27 2009
Photo/Video Gearhead
Palo Alto, CA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $1,899.00
[2 of 2 customers found this review helpful]
Fantastic Lens
5.0
"Oh my goodness. This is a great lens. A wonderful lens. What can I say? Seriously. It snaps into crystal clear focus so quickly and silently you don't even know its done it, and takes pictures so sharp and clear you won't believe it. Bokeh is rich and buttery, and when you zoom down to the details i …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Apr 17 2009
Snappy
Albuquerque, NM
Reviewed at:
Price: $1,899.99
[2 of 4 customers found this review helpful]
Very good lens
5.0
    Pros
  • Consistent Output
  • Quick Focus
  • Sharp Focus
    Cons
  • None
    Best Uses
  • General Use
  • Special Effects
"Very sharp, fast and silent AF on Sony a900. "
 Report Abuse  (2)  (2)  0 comments
Apr 16 2009
Sudden
Sweden
I am:
  • Semi-Professional
Reviewed at:
Price: $1,899.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
