Sony PCMD50 Portable Linear Recorder
#1
4.7
based on 72 reviews
from $449.95 - $484.99
Ratings Distribution
5 star
55
4 star
15
3 star
2
2 star
0
1 star
0
Category Average
4.3
Low Price:
$449.95 at B&H Photo Video
$484.99 at J&R Electronics
Find it at Amazon
Pros
  • Easy to control (58)
  • Easy setup (53)
  • Fast (48)
  • Works every time (43)
  • Good quality duplicates (30)
  • Great sound quality (5)
  • Powerful (3)
  • Well built / quality construction (3)
  • Durable (2)
  • Low distortion (2)
See less See more
Cons
  • Difficult to use (2)
  • Adding xlr too expensive (1)
  • Built in mics so-so (1)
  • Can't record and usb conn (1)
  • Challenging studio sw (1)
  • Difficult to control (1)
  • File numbering system (1)
  • Heavy / bulky (1)
  • Io layout can be confusi (1)
  • Lacks automatic recording (1)
Best Uses
  • Audiophiles (41)
  • Smaller rooms / apartments (20)
  • Basic systems (17)
  • Large rooms (16)
  • High volume duplication (10)
  • Amateur recording (2)
  • Events (2)
  • Field recording (2)
  • Musicians (2)
  • Performances (2)
Provided by B&H Photo Video
The DEMO Sony PCM-D50 continues the tradition of offering high-quality and affordable solutions for portable field recording. This compact recorder offers 24-bit/96kHz stereo WAV recording to a built-in 4GB flash drive, with a Memory Stick Pro-HG Duo card slot for added capacity. Perfect for location sound recordists, journalists, musicians, and more, the PCM-D50 has a sturdy and lightweight aluminum housing designed to withstand the trials of professional use. The recorder is fitted with stereo microphones that can be positioned in an X/Y or wide pattern, and operates on four standard AA batteries for up to 14 hours of operation at 16-bit/44.1kHz recording. Recording features include five seconds of pre-record, Dual Digital Limiting to prevent distortion, and more. Playback functions include digital pitch control, A/B repeat, and more. It's easy to transfer your recordings to a Mac or PC with simple drag-and-drop file transfer via a high-speed USB connection.
Sony PCMD50 Portable Linear Recorder Questions
Questions and Answers
Where to Buy
$449.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$484.99
Product Reviews
Last update: Oct 29, 2009
Sony PCMD50 Portable Linear Recorder Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
For the Roaming Sound Seekers
"The best reviews have already been written: [@]I'm a public radio producer and a podcaster of events and interviews. The D50's got me hooked because of its:- Full metal jacket that can really take a beating. All rivals come in plastic.- Level and volume controls in knobs. Thank you SONY for answering my prayers.- 12-hr batteries, leaving rivals' 5 hours in shame.- 5 seconds of buffer that helps keep your butt co..." Read Full Review »
Feb 22, 2008 by thecocoon
See more positive Sony PCMD50 Portable Linear Recorder reviews
3.0
Sony PCM-D50 Decent but not fabulous
"Pros - great battery life super easy to use can produce great sound Cons - Built very solid In a small room mics pickup to many reflections and seem to have a slight phasing issue. In loud environments the case and mics seem to pick up some internal resonance at around 5000hz. Frequency response of mics change greatly as you move around unless mics are pointed right at speaker. - misc Holding the unit wit..." Read Full Review »
Jul 17, 2009 by Kali
See more negative Sony PCMD50 Portable Linear Recorder reviews
Displaying 1 - 5 of 72 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Clear sound
  • Durable
  • Good Features
    Cons
  • Bulky
  • No mp3 recording
    Best Uses
  • Bird watchers
  • Musicians
  • Radio journalists
  • Video production
"The best reviews have already been written: [@]I'm a public radio producer and a podcaster of events and interviews. The D50's got me hooked because of its:- Full metal jacket that can really take a beating. All rivals come in plastic.- Level and volume controls in knobs. Thank you SONY for answerin …"  Read Full Review »
Was this CD Recorder review on the Sony PCMD50 Portable Linear Recorder helpful to you?
 Report Abuse  (7)  (0)  0 comments
Feb 22 2008
thecocoon
nyc
I am:
  • Musically Inclined
  • Practical
  • Professional
Reviewed at:
Price: $449.95
[6 of 7 customers found this review helpful]
Awesome stereo sound, great onboard mics
4.0
    Pros
  • A monkey could do it.
  • Easy To Control
  • Easy To Set Up
  • Fast
  • Good Quality Duplicates
  • More »
    Cons
  • None
    Best Uses
  • Audiophiles
  • Larger Rooms
  • Smaller Rooms
"I ordered this bad boy to record sound effects and sound design work for film. I wanted something quiet because I was annoyed with my mini disc recorder I was using. The unit itself was noisy and the level meter sucked.My new Sony PCM-D50 is AWESOME. It makes no noise and the record sampling rate …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Feb 28 2008
timmy-tape-worm
Washington D.C.
I am:
  • Audiophile
  • Professional
Reviewed at:
Price: $449.95
[4 of 4 customers found this review helpful]
Great recorder
5.0
    Pros
  • Easy To Control
  • Easy To Set Up
  • Fast
  • Works Every Time
    Cons
  • None
    Best Uses
  • Audiophiles
"Sony put a lot of thought into the D50 and it shows. The internal mics are versatile and make some nice quality recordings in various situations. The internal preamp is good quality also, allowing for the use of a wide variety of external microphones. You will need some type of wind cover for out …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jul 9 2008
stantheman1976
Gulf Coast, MS
I am:
  • Tech Savvy
Reviewed at:
Price: $449.95
[3 of 3 customers found this review helpful]
Fantastic Audio Equipment
5.0
    Pros
  • Easy to import into FC
  • Excellent pro audio
  • Solid build quality
    Cons
  • None
    Best Uses
  • Audiophiles
  • Replace camera audio
"I bought the PCM-D50 primarily to record alternate audio tracks for video productions and I couldn't be more satisfied. I have found that in most cases the audio is so superb, I completely replace the audio recorded by my video cameras (HDR-FX1 and HVU-A1U) with the PCM-D50 audio.
I was initiall …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 22 2009
Jim Caldwell
Parkville, MO
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $449.95
I'm totally blown away!
5.0
    Pros
  • Easy To Control
  • Easy To Set Up
  • Fast
  • Works Every Time
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • High Volume Duplication
  • Larger Rooms
  • Smaller Rooms
"I just received my PCM-D50 today,..and I was fortunate enough to have it arrive before my gig this evening. It took no effort at all to navigate through the interface on this device. I recorded our Latin Jazz Ensemble this evening at 96/24-bit. I just listened to the result and,...WOW! I am tota …"  Read Full Review »
Oct 29 2009
MLovesJazz
Champaign IL
I am:
  • Audiophile
  • Movie Enthusiast
  • Professional
  • Tech Savvy
Reviewed at:
Price: $449.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
