Sony MiniDV Video Walkman with 4-Inch LCD Screen (GV-D1000)
5.0
based on 2 reviews
from
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.9
More Images
Pros
  • Durable (1)
  • Good battery life (1)
  • Great picture quality (1)
  • Lightweight (1)
  • Nice sound (1)
  • Portable (1)
  • Simple / intuitive controls (1)
See less See more
Best Uses
  • Home (1)
  • In the car (1)
  • Office (1)
  • Travel (1)
Provided by OneCall
Sony's GV-D1000 Video Walkman has it all, despite its size and portability. Its MiniDV recording format delivers 3X the color bandwidth of a VHS tape and with its 4" LCD display you will enjoy excellent viewing clarity with improved resolution. The GV-D1000 includes a Memory Stick Media(R) terminal, MPEG movie capture capabilities from tapes and USB streaming.
Features include:
  • 4" Color Active Matrix LCD Screen & Built-In Speaker
  • i.LINK(R) DV Interface (IEEE1394)
  • 20-Segment Assemble Edit
  • 12/16 bit PCM Digital Stereo
  • Crystal Clear Still/Slow Motion
    Supplied Accessories AC-L10 Power Adapter, AV Cables, RMT-811 Remote Commander(R), 2 AA batteries, CD-ROM Drivers (PIXELA ImageMixer 1.0)
  • Mini DV Format : Mini DV recording format delivers 3X the color bandwidth of VHS with significantly less video noise ratio compared to analog formats and providing stunning video performance.
  • 4" LCD Display (123K Pixels) : Provides excellent viewing clarity with improved resolution. The 123K pixel LCD rotates for multiple viewing angles providing sharp detailed images for monitoring or playback.
  • Digital Still Memory Mode with Memory Stick(R) Media : Capture digital still images at 640 x 480 resolution from video-tapes, analog inputs or digital video i.LINK(R) input, directly onto Memory Stick media. The images can be easily transferred to PCs for emailing, printing or sharing with other compatible Memory Stick devices.
  • MPEG Movie Mode : Capture MPEG1 compressed video with audio directly to Memory Stick media. Shoot an MPEG Movie "on location" or select up to 60 seconds from your recorded videotapes. The Video Email mail mode, 160 x 112, is ideal resolution for sharing videos via the Internet. Use the Presentation Mode, 320 x 240, to increase the resolution for greater detail.
  • USB Streaming : Stay connected with family and friends by broadcasting prerecorded videos with audio, via the Internet with the USB interface. It's like having your own video conferencing system.
  • i.LINK(R) (1)DV Interface (IEEE1394) : A high speed bi-directional digital video/audio communication between two devices equipped with an IEEE1394 interface, including camcorders, digital VCRs, and PCs.
  • Analog Input/Output Capability : Utilizing standard composite video inputs will allow the capability to record previous recorded video on a smaller more compact MiniDV tape. Utilizing the higher quality S-Video cable reduces "Dot Crawl" which is commonly seen as distortion around the edge of the recorded video signal, which is normally found from analog sources.
  • Analog-to-Digital Conversion with Pass-Through : Convert and/or record any analog NTSC video source to digital video via the analog inputs. Analog NTSC video can also be passed-through the Digital Handycam(R) camcorder directly into a PC via the i.LINK interface in real time for easy PC editing of your analog footage.
  • 12-Bit/16-Bit PCM Digital Stereo : 16-bit recording offers the same, outstanding sound quality as Compact Disc. 12-bit recording enables you to add an additional audio track with compatible audio dubbing equipment or i.LINK compatible computers.
  • SP and LP Record/Playback : Standard Play offers up to 60 minutes of digital recording, or Long Play for up to 90 minutes, on one Mini DV cassette.
  • Digital Program Editing : Allows you to select a sequence of 20 scenes and then control dubbing via i.LINK to another i.LINK camcorder, via infrared remote to an analog VCR. Controls both Sony and other brand camcorders and VCRs.
  • Precision Assemble Editing with Optional DSRM-E1 (99 Segment x 4) USB Interface : Provides an easy way to connect the Video Walkman(R) VCR to computers for fast transfer of digital images and MPEG movies.
  • Playback Zoom : Manipulates the picture inside the Video Walkman(R) VCR. While playing back your images on the Video Walkman VCR, it allows you to edit your images by zooming in (up to 2 times) and cropping your picture (up, down, left, right). You can save the new image as a separate file. Resize lets you save a copy of an image to a smaller or larger file size.
  • Print Mark : Pre-select your digital still images (in the camcorder) for printing, and connect with a DPOF (Digital Print Order Format) compatible printer for hassle free printing. Because your images are already selected, your printing experience will be fast and enjoyable.
  • Crystal Clear Still/Slow Motion Playback : Digital video provides noise free playback in slow motion and in the pause mode for detailed playback.
  • Drop Frame Time Code : Assigns each video frame a sequential code number providing frame accurate editing for each of the 29.97 frames contained in 1 second of DV video.
  • Index Titler : Add titles to your videos. Allows an updateable title to be stored on a DV cassette IC chip and accessed using the GV-D1000 data code.
  • Cassette Memory : Compatible with the Mini DV tapes with a built-in 4K Integrated Circuit Memory Chip. The Memory Chip provides the ability to read and write data that can be used to access index points, Photo ID points, Title for the scene or Title for the entire tape.
  • InfoLithium(R) M Series Battery w/AccuPower(TM) Meter System (Optional)
  • Specification Description
    Model GVD1000
    UPC 027242600553
    Analog Audio / Video (1) Rear In/Out
    Battery Charger Built-in
    Compatible Battery Lithium-Ion Rechargable battery (Optional)
    DPOF Yes
    Headphone Jack Yes
    IEEE 1394 (Firewire) (1) Rear In/Out
    LCD Display Size (Inches) 4
    Memory Stick(R) Memory Stick compatible interface on front panel
    MiniDV Recording Yes
    MPEG Movie Yes
    Playback Zoom Yes
    Removable Memory Type Memory Stick
    S-Video (1) Rear In/Out
    Select Mini-DV Tape
    Slow Motion Yes
    Still Image Resolution (Max.) 640 x 480
    Titler Yes
    USB Port Yes
    USB Streaming Yes
    Sony MiniDV Video Walkman with 4-Inch LCD Screen (GV-D1000) Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: MiniDV Video Walkman with 4-Inch LCD Screen (GV-D1000)
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Feb 21, 2008
    Sony MiniDV Video Walkman with 4-Inch LCD Screen (GV-D1000) Reviews
    Displaying 1 - 2 of 2 Reviews
    Show
    Sort by
    [1 of 1 customers found this review helpful]
    7 years and still running strong!
    5.0
      Pros
    • Durable
    • Easy Controls
    • Good Picture
    • Good Sound
    • Lightweight
    • More »
      Cons
    • None
      Best Uses
    • At Home
    • In The Car
    • Office
    • Travel
    "I have had this almost 7 years now and it still works great! And I have used it a lot. The only issue I have had with it is the scroll button is a little sensitive but not something that would stop me from recommending it to anyone. "
    Was this Portable DVD Player review on the Sony MiniDV Video Walkman with 4-Inch LCD Screen (GV-D1000) helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Feb 21 2008
    Stellan
    LA, CA
    I am:
    • Gearhead
    Reviewed at:
    Sony GVD 1000
    5.0
    "This is a totally reliable product which has taken hightraffic usage within a high school digital video editingclass for the past 4 years, and it works with ease each andevery time.
    Expertise: Teacher "
    Aug 26 2007
    Kathleen
    Slidell, LA
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
