Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi
#4
4.6
based on 24 reviews
Ratings Distribution
5 star
17
4 star
6
3 star
0
2 star
1
1 star
0
Category Average
4.1
$199.00 at B&H Photo Video
Find it at Amazon
Find it at Ebay
$199.00
from 1 store
More Images
Pros
  • Great sound (12)
  • Simple / intuitive controls (11)
  • Attractive design (10)
  • Easy setup (10)
  • Powerful (10)
  • Doesn't skip (1)
  • Durable (1)
  • Only 170 for 530 watts (1)
See less See more
Cons
  • Heavy on the bass (1)
  • Too bulky (1)
Best Uses
  • Basic use (8)
  • Larger rooms (8)
  • Smaller rooms (7)
  • Audiophiles (3)
  • Office (2)
  • Anywhere (1)
  • Basic systems (1)
Provided by Buzzillions.com
With its continued excellence in sound reproduction, Sony has once again created a versatile, space efficient audio solution for the music lover in you. The MHC-EC98Pi Mini Hi-Fi Shelf System combines functionality and versatility, with abilities to playback iPod audio through the iPod dock, and CD-R/W, and MP3 playback capabilities. It features a very stylish design that will enhance any decor, a built-in AM/FM tuner with 30 presets and automatic scan tuning, two full range (2-way) speakers, 7.8" subwoofer, and a powerful 530W output. This unique system offers great features that will be hard to match, such as slot-in CD loading mechanism and braced construction to assist in superb audio tonality. Enjoy an external audio (mini jack) input, and FL display technology. Use it in your bedroom, office or school. Either way, you will enjoy high quality audio reproduction at an affordable price.
Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi Questions
Questions and Answers
Where to Buy
$199.00
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
Product Reviews
Last update: Sep 10, 2009
Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi Reviews
Most helpful positive review
Most helpful negative review
5.0
An Exceptional Hi-Fi System
"To date I've used my Sony Mini Hi-Fi for FM radio / music and CDs. It took me about half an hour to set up and it hasn't stopped since. Well, I turn it off at night. The sub-woofer helps make the difference between the Sony Hi-Fi system and ordinary Hi-Fi systems. Pros: Don't be fooled by the "Mini" or "Book Shelf" system description. It may actually be snug on many shelf setups. The tuner and CD player are exc..." Read Full Review »
Apr 10, 2009 by Maxbyte
See more positive Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi reviews
2.0
CD broken within the first week, but..
"After doing a lot of research, this model made the most sense and value for your money. It sounds great and has plenty of features for your teen or classroom, which is what I purchased it for. But the CD was broken after the first week. VERY disappointing for being a Sony product...." Read Full Review »
Sep 13, 2008 by PurplePower
See more negative Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Use
  • Larger Rooms
  • Offices
  • Smaller Rooms
Pros: Don't be fooled by the "Mi …"  Read Full Review »
Was this Shelf System review on the Sony MHC-EC98Pi Mini Hi-Fi Shelf System MHCEC98Pi helpful to you?
Apr 10 2009
Maxbyte
Stoughton, WI
I am:
  • Audiophile
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $199.00
Better than I deserve at work
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Use
  • Offices
  • Smaller Rooms
"I use this stereo to review possible performers at my music hall. I'll lead with the only negative thing I have to say about it, that is that it has pre-set eq which I'd prefer to have control over. Having said that, I do find presets that work for me in most cases and when using my mp3 player there …"  Read Full Review »
Jul 29 2009
nuhorn
peekskill, ny
I am:
  • Audiophile
  • Professional
Reviewed at:
Price: $199.00
[1 of 1 customers found this review helpful]
Excellent Sound
4.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Use
  • Larger Rooms
  • Smaller Rooms
"This has a very nice sound range to it. The preset EQ's and the abaility to turn the subwoofer on and off are great features. Also the ability to turn the GDMX on or off is a great capability. The system has so much bass capability a lot of times you don't even need the subwoofer or the GDMX. I woul …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 1 2008
Mike the music enthusiast
Cleveland, OH
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Fantastic
5.0
    Pros
  • Easy Controls
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Use
  • Smaller Rooms
"I am actually a teenager and I choose to write this review because I was amazed at this product. It is great for music with heavy beats. The bass is astounding. I would have checked attractive design from the front it is awesome however the main console is very long. Beware if you have small shelves …"  Read Full Review »
Jan 28 2009
Gav
Chicago, IL
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
best sound for the price
4.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
  • More »
    Cons
  • Heavy on the bass
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This system sounds great. Its compact and has great bass. Sometimes the bass can be a bit overpowering but simply change the EQ and you should be fine. The ipod dock makes it easy to connect to the system. This baby can get incredibly loud. One thing I would change would be having a manual EQ option …"  Read Full Review »
Aug 8 2008
Marc the fiddler
New York, NY
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $199.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
