Sony Marine CD Receiver
#47
4.2
based on 10 reviews
Ratings Distribution
5 star
5
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.1
Low Price:
$139.00 at Abt Electronics
 Trusted:
$154.00 at Online Car Stereo
Find it at Amazon
$139.00 - $154.00
from 2 stores
More Images
Pros
  • Easy to install (5)
  • Reliable (3)
  • Waterproof (3)
  • Attractive design (2)
  • Durable (2)
  • Nice features (2)
  • Simple / intuitive controls (2)
  • Easy to use (1)
  • Great sound quality (1)
  • Ipod connector charger (1)
See less See more
Cons
  • Hard to tune stations (1)
  • Ipod control (1)
  • Not durable (1)
  • Not weather resistant (1)
  • Poorly designed (1)
  • Pricey (1)
Best Uses
  • Small boats (4)
  • Large boats (3)
  • Outdoors (3)
  • Cd (1)
  • Don't buy (1)
  • Radio (1)
  • Ski boat (1)
Provided by BoatersWorld.com
CD/CD-R/CD-RW
Have the freedom to playback songs from your CDs, CD-R or CD-RW discs!
SAT Radio Ready
All the possibilities of Satellite radio available at your fingertips
DSO2
Raise the soundstage, raise your enjoyment.
Best Tuning Memory
Setting your radio presets can be a real pain while you're driving-especially if you're in an unfamiliar area. So, let the tuner do the work for you!
EQ3
Tweak your EQ3 to help maximize the sound within your car.
MP3 Playback
There are a lot of MP3 music files sitting on computer hard drives that are just itching to be played
CD Text
What was the name of that song? Now, with CD TEXT, your player can tell you the name of each song on a CD!
45 Degree Install
Most dashboards found in today's vehicles are perpendicular to the floor
Xplod Power
So, just how much power is enough? As much as possible!
Front Panel Aux In
Plugging your portable audio devices into your car's sound system is like stealing candy from a baby.
Specification Description
Model CDX-M50IP, CDXM50IP
UPC 027242718722
Car Electronic Accessory iPod Play Adapter
CD Player Holds 1 CD
keyFeatures DSO2 soundstage
keyFeatures Front panel aux in
keyFeatures Front/rear sub selectable preouts
keyFeatures Satellite radio ready
keyFeatures iPod direct 30-pin connector with 2.7 meter cable
Sony Marine CD Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2008
Sony Marine CD Receiver Reviews
Most helpful positive review
Most helpful negative review
4.0
Solid Value
"This is a marine head unit, but I have installed it outside on my deck using a waterproof housing and a DC converter. It works great, sounds great, and is easy to use. The wireless remote control is also a very nice feature. There are many different ways to alter the sound using preset or custom equalizer settings. I've tried a lot of different setups on my deck, and this one is the best sounding by far. My onl..." Read Full Review »
May 08, 2008 by Scott
See more positive Sony Marine CD Receiver reviews
1.0
Shouldn't be advertised as marine
"This product is junk! I have exchanged it through Sony warranty 3 times before finally getting a refund. Problems were with the tuner on one, the XM interface on the 2nd and the CD player quit on the 3rd. This is an auto unit with a thin layer of plastic on the top to make it "marine". It will not stand up to even the mildest marine environment...." Read Full Review »
Aug 02, 2008 by James
See more negative Sony Marine CD Receiver reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Solid Value
4.0
    Pros
  • Easy To Use
    Cons
  • IPod control
    Best Uses
  • outdoor deck
"This is a marine head unit, but I have installed it outside on my deck using a waterproof housing and a DC converter. It works great, sounds great, and is easy to use. The wireless remote control is also a very nice feature. There are many different ways to alter the sound using preset or custom equ …"  Read Full Review »
Was this In-Dash Car Audio System review on the Sony Marine CD Receiver helpful to you?
May 8 2008
Scott
Evanston, IL
I am:
  • Practical
Reviewed at:
Price: $139.00
1.0
    Pros
  • None
    Cons
  • NOT DURABLE
  • Not Weather Resistant
  • Poorly Designed
    Best Uses
  • Don't buy
"This product is junk! I have exchanged it through Sony warranty 3 times before finally getting a refund. Problems were with the tuner on one, the XM interface on the 2nd and the CD player quit on the 3rd. This is an auto unit with a thin layer of plastic on the top to make it "marine". It will n …"  Read Full Review »
Aug 2 2008
James
Dallas
I am:
  • Recreational
Reviewed at:
Nice Head-Unit
4.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Install
  • Nice Features
  • Sensitive tuner
  • More »
    Cons
  • None
    Best Uses
  • Ski boat
"I haven't played enough with this unit to get a really good feel for it but what I have seen in a weekend of use I really like. The tuner picks up a lot more stations than my old JVC, it sounds great and is easy-to-use. "
Jun 15 2008
bound4er
Waukesha, WI
Reviewed at:
Price: $139.00
Great Buy
5.0
    Pros
  • Easy To Install
  • Excellent sound
  • Love the remote
  • Picked up stations
  • More »
    Cons
  • Expensive
    Best Uses
  • Large Boats
  • Outdoor
  • Small Boats
"Great sound. Very Loud. Loved the ipod connector and front aux jack. This radio picked up HD stations from Florida in Arkansas. Wow! "
Aug 12 2008
astatefan1
memphis,TN
I am:
  • Recreational
Reviewed at:
[1 of 1 customers found this review helpful]
So far Very good!
4.0
"I bought this as a replacement unit for the stock unit in my correctcraft. The sound quality is very good and the direct hookup for an ipod is a great feature. Sony makes a good product and I am hopeful that overtime it will prove to be weather resistant. So far, so good! "
 Report Abuse  (1)  (0)  0 comments
Aug 29 2008
Mach1 Catfish
Fannin, Mississippi
I am:
  • Recreational
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
