Sony KDL-37M3000 37-inch M Series LCD Flat Panel HDTV
4.4
based on 8 reviews
Ratings Distribution
5 star
3
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.4
$949.99 at Crutchfield
Find it at Amazon
Find it at Ebay
$949.99
from 1 store
More Images
Pros
  • Attractive design (7)
  • Great picture quality (7)
  • High resolution (4)
  • Fast setup (3)
  • Easy setup (2)
  • Good connection options (2)
  • Great sound quality (2)
  • Durable (1)
  • Simple / intuitive controls (1)
  • Simple controls (1)
See less See more
Cons
  • Poor connection options (1)
  • Poor sony set up info (1)
Best Uses
  • Home (3)
  • Small rooms (3)
  • Office (2)
  • Kitchen (1)
  • Large rooms (1)
  • Movies (1)
Provided by OneCall
BRAVIA(R) HDTV - Affordable Excellence
BRAVIA HDTVs represent outstanding performance from the top of the line right down to where it all starts - M-Series. M-Series HDTVs have just the right amount of features, style and performance to make them a great entry level choice. It starts with the 16:9 high definition LCD display panel including a fast panel response time and excellent 178 degree wide viewing angles. The 3D comb filter reduces dot crawl and color imperfections for fine picture detail, The right connections to enable connection of the latest video sources. And then there`s that famous BRAVIA style. A rich-looking space saving black cabinet wraps around the bottom mounted speakers and is accented by silver trim and mounted to the included silver pedestal. Now just about anyone can afford a BRAVIA HDTV!
  • Inputs : HDMI(TM) (x2), YPbPr (x2), PC Input1 x1, S-video x1, Composite x3
  • 16:9 HD Resolution Panel (1366 x 768)
  • 3D Comb Filter
  • Space Saving Bottom Speaker
  • Channel labels
  • Favorite channels
  • Clock and Sleep timer
  • Digital audio amplifier
  • Fast panel response
  • Wide 178 degree Viewing Angles
  • Light sensor backlighting control
  • HDTV with ATSC Digital Tuner with QAM
    • HDMI and PC Connectivity : Designed for maximum versatility, Sony`s BRAVIA(R) M-Series Digital LCD TV line is equipped with a comprehensive range of input interfaces. The HDMI (High-Definition Multimedia Interface) is the first industry-supported, uncompressed, all-Digital audio/video interface. HDMI technology supports enhanced or High Definition video, together with multi-channel Digital audio to provide matchless image and sound reproduction. The HDMI and PC inputs (HD-15-pin) offer easy connection to your PC, allowing you to use your high Resolution BRAVIA(R) M-Series Digital TV as a computer monitor.
    • Light Sensor : Intelligently adjusts the screen Brightness to match the ambient light in a room, ensuring a comfortable viewing experience. In a dim room for example the screen automatically reduces Brightness making it much more comfortable for viewing.
    Specification Description
    Model KDL-37M3000, KDL37M3000
    UPC 027242719941
    Analog Audio (1) Rear Input
    Analog Audio (1) Rear Output
    Analog Audio (1) Side Input
    Analog Audio / Video (1) Rear Output
    Analog Audio / Video (3) Rear Input
    Analog Audio / Video Side Input
    Aspect Ratio 16:9
    Coaxial Rear Output
    Compatible Formats 720p
    Compatible Furniture or Stand SUFL71M
    Component Video (2) Rear Input
    Contrast Ratio 1,000:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 10.5
    Energy Star Compliant Yes
    HDMI (2) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 720p
    Headphone Jack Side Output
    Height (Inches) 24
    PC Audio Rear Input
    Refresh Frequency 60 Hz
    Remote Control Included
    Resolution 1366 x 768
    RF Rear Input
    S-Video Rear Input
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size (inches) 37
    Screen Size (Inches/Diagonal) 37
    Speakers 10 Watts x 2
    Tuner ATSC
    Tuner QAM
    TV Manufacturer’s Warranty (Labor) 1 Year
    TV Manufacturer’s Warranty (Parts) 1 Year
    Viewing Angle 178 degrees Horizontal
    Viewing Angle 178 degrees Vertical
    Wall Mountable Yes
    Weight (Pounds) 49
    Width (Inches) 36.25
    Sony KDL-37M3000 37-inch M Series LCD Flat Panel HDTV Questions
    Questions and Answers
    Where to Buy
    $949.99
    BizRate Rating Outstanding 9.4
    Product Reviews
    Last update: Aug 30, 2008
    Sony KDL-37M3000 37-inch M Series LCD Flat Panel HDTV Reviews
    Displaying 1 - 5 of 8 Reviews
    Show
    Sort by
    Back on Board w/ Sony
    5.0
      Pros
    • Attractive Design
    • Clear Picture
      Cons
    • None
      Best Uses
    • Small Rooms
    "We have a somehwat limited area where we could put the TV in our familly room. We also could not put it on the wall, so the stand and the TV size were major issues. The 37" was perfect. The 40" would have been tight and from our viewing distance the 720 looks just as good as any 1080 would. Sony rem …"  Read Full Review »
    Fits under wall AC Unit and clears Back Door
    • Using Product
    • Picture of Product
    Was this LCD TV review on the Sony KDL-37M3000 37-inch M Series LCD Flat Panel HDTV helpful to you?
    Dec 23 2007
    Shbart
    Wilmette, Illinois
    I am:
    • Tech Savvy
    Reviewed at:
    Who needs an HD Box?
    4.0
      Pros
    • Bright Image
    • Good Resolution
      Cons
    • None
      Best Uses
    • Home
    "Save some money and not get the HD box from your cable provider and just get the TV! The picture is so good you I asked my friends who have HD to review this set and they were amazed at how close, or the same, as their set was with an HD box. 'nuf said. "
    Jun 11 2008
    Practical Paul
    Bay Area, California
    I am:
    • Practical
    As expected
    4.0
      Pros
    • Attractive Design
    • Clear Audio
    • Clear Picture
    • Durable
    • Easy To Set Up
      Cons
    • None
      Best Uses
    • Office
    • Small Rooms
    "TV is ok. Not sure if a less epecsive one would have got the job done. Used in bed room, I wont be using all the bells and whistels. No real complaint but I over bought for my use. "
    Jan 19 2008
    jeguid
    New Orleans
    I am:
    • Practical
    Reviewed at:
    Very good choice
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
      Cons
    • None
      Best Uses
    • Home
    "I expected Sony quality and I got it. Beautiful picture and sound. No visual distortion that I had seen on other HD's. A little pricier than the others, but worth it in my opinion. "
    Jun 19 2008
    Pistol Pete
    Philadelphia
    I am:
    • Tech Savvy
    Reviewed at:
    Great TV especially for the price.
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • Reduced Glare
      Cons
    • Poor Connection Options
      Best Uses
    • Kitchen
    • Office
    "Great TV. Mounts well but Sony requires an odd size mounting plate which requires an adapter. Energy efficient and great picture in high def. "
    Aug 30 2008
    Shane
    Chicago, IL
    I am:
    • Tech Savvy
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
