Sony ICF-CD7000 Clock Radio
#5
4.3
based on 75 reviews
from $39.00 - $77.94
Ratings Distribution
5 star
34
4 star
33
3 star
7
2 star
0
1 star
1
Category Average
3.8
More Images
Pros
  • Neat features (29)
  • Great sound quality (28)
  • Good volume (26)
  • Reliable (21)
  • Great reception (20)
  • Durable (19)
  • Easy to set (18)
  • Lightweight (15)
  • Good battery life (8)
  • Looks great (3)
See less See more
Cons
  • Difficult to set (5)
  • Heavy / bulky (5)
  • Unattractive design (4)
  • Poor sound quality (2)
  • Unreliable (2)
  • Blue isnt everyones color (1)
  • Confusing / bad remote control (1)
  • Display could be brighter (1)
  • Doesn't play mp3 cd (1)
Best Uses
  • Home use (26)
  • Everyday (20)
  • Anywhere (10)
  • Home (2)
  • Home bedroom (2)
  • At home in bedroom (1)
  • Babies room (1)
  • Bed room use (1)
  • Bedside (1)
  • College dorm for student (1)
Provided by OneCall
FM/AM Digital Tuner: lets you choose from a variety of radio Programming.
Dual Alarm: permits 2 separate wake-up times with individual wake-up settings and also allows you to wake to a CD, the radio or a buzzer
ATS (Automatic Time Set): The correct EST (Eastern Standard Time) has been preset at the factory so just plug in your radio and adjust the time zone if necessary. In the case of a power interruption, the pre-installed Lithium battery maintains the correct time so when the power returns you don`t have to re-set the clock.
ADST (Automatic Daylight Savings Time): When Daylight Savings Time changes take place in the Spring and Fall each year, there is no need to adjust the clock because the built in calendar recognizes the dates and automatically makes the proper time adjustment.
No Power No Problem Alarm System: uses the pre-installed Lithium battery to maintain clock and alarm operation in the event of a blackout or other power failure.
Triple Time Display: displays the Current time, Alarm A and Alarm B on the easy-to-read LCD Display.
MP3 Connectivity with Built-in Audio Cable: allows you to easily connect your MP3 player and have access to all of your music
15 Station Presets: allows you to set 10 FM stations and 5 AM stations.
Count-down Time Nap Button: allows you to take a short nap and wake up to the radio or buzzer without changing your alarm settings. You can select your favorite nap time of 10, 20, 30, 60 or 90 minutes.
CD-R/CD-RW Playback: Plays CD's burned in eithera PC or home recording deck.
LCD Brightness Control: lets you choose between 3 positions: High, Medium or Low (H/M/L), by pressing the snooze button.
Extendable Snooze: gives you the freedom to choose your snooze time instead of having to settle for the standard time intervals of other alarms. Each press of the snooze button adds an additional 10 minutes to your snooze time, up to a full hour.
Built-in Audio Cable: allows for easy connectivity of a Digital music player.
Sleep timer: allows you to fall asleep to the Radio, a CD or a Digital Music Player. You can select how long you want the music to play, choosing between 15, 30, 60 or 90 minutes.
Illumination Light: allows you to adjust the brightess to your taste and environment between 3 settings; High, Low and Off.
Specification Description
Model 31CC2D11, ICF-CD7000BLK, ICFCD7000BL, ICFCD7000BLK
UPC 027242709805
Alarm 2 Alarm
Alarm Dual
Can Be Giftwrapped Yes
Can Ship in Original Container Yes
CD or Cassette CD Player
CD Player Yes
Channel Availability Online Only
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Corp National Status A
Date 1st Available Online 29-APR-09
Depth (Inches) 10.4
Freight Class ANY
Hazmat Warning N
Headphone Jack Rear Output
Height (Inches) 7.9
Line In Rear Input
Manufacturer Part Number ICFCD7000BLK
MP3 Player Minijack input for optional MP3 or iPod
Notify Me When Available Yes
Registerable Yes
TRU SKN 100687
Tuner AM
Tuner FM
Tuning AM/FM
Width (Inches) 8.9
Sony ICF-CD7000 Clock Radio Questions
Questions and Answers
Where to Buy
$67.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$63.55
BizRate Rating Outstanding 9.1
$39.00
BizRate Rating Outstanding 9.4
Show all 14 stores
_
Product Reviews
Last update: Nov 17, 2009
Sony ICF-CD7000 Clock Radio Reviews
Most helpful positive review
[9 of 9 customers found this review helpful]
Most helpful negative review
5.0
Very Nice Clock Radio
"Unit has a small footprint on my nightstand and can be dimmed enough to keep the room dark at night. Along with good sound, it also has the best radio reception of any of the clock radios I have owned over the last 15 years...." Read Full Review »
Jun 20, 2008 by John
See more positive Sony ICF-CD7000 Clock Radio reviews
3.0
Pretty good but no cigar
"I thought that this was to be a great CD player for bedroom use but am disappointed. though the sound is good, It can skip on prerecorded CDs and does not recognise Computer copies of CDs that play on my less expensive entertainment center CDPLAYER. MP3s recorded to disk are totally invisible. To hear MP3's you must plug in an MP3 player, whose battery life would make it not practical to use as a wake up compone..." Read Full Review »
Oct 13, 2009 by DAn
See more negative Sony ICF-CD7000 Clock Radio reviews
Displaying 1 - 5 of 75 Reviews
Show
Sort by
5.0
    Pros
  • Accurate Controls
  • Brightness
  • Clear Signal
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • None
"Unit has a small footprint on my nightstand and can be dimmed enough to keep the room dark at night. Along with good sound, it also has the best radio reception of any of the clock radios I have owned over the last 15 years. "
Was this Portable Radio review on the Sony ICF-CD7000 Clock Radio helpful to you?
 Report Abuse  (9)  (0)  0 comments
Jun 20 2008
John
Southern California
I am:
  • Practical
Reviewed at:
Price: $64.88
Best Clock Radio I Ever Invested In!!!
5.0
    Pros
  • Easy To Set
  • Good Volume
  • Neat Features
  • Reliable
    Cons
  • None
    Best Uses
  • None
"This has to be one of the best clock radios I have ever invested in. After waking up late for work, the second time this month, I came to the conclusion that cell phone alarm clocks suck.
I couldn't hear my phone go off, and I'm a light sleeper, so you can understand what I'm working with as far …"  Read Full Review »
Jul 11 2008
Andy
Mukwonago, WI
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Price: $39.00
[7 of 7 customers found this review helpful]
Best Bedroom Clock Ever
5.0
"I love love love my this clock radio. First of all it has a sexy blue light that has 3 different brightness controls that looks great when the room is dark or when the room is not dark. The CD player can be set as a timer, as an alarm, or programmed to play songs in the order you select. It also has …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Oct 10 2007
Cecelia
Baltimore
Reviewed at:
Price: $43.99
Almost Perfect
4.0
    Pros
  • Features
  • Good Sound Quality
  • Great Reception
    Cons
  • None
    Best Uses
  • Home Use
"This is the follow-on to the Sony Bedside Barrel with CD player in the top. That clock radio of the barrel also brings in TV/Weather stations, something this one should also. Despite this "take-away" most of the barrel features are ncluded and the design is certainly more interesting than the barre …"  Read Full Review »
Nov 17 2009
The Captain
Sunny Florida
I am:
  • Practical
Reviewed at:
Price: $64.88
[1 of 1 customers found this review helpful]
Stylish/functional alarm; ordinary sound
4.0
    Pros
  • Easy To Set
  • Good Volume
  • Neat Features
    Cons
  • Mediocre reception-sound
    Best Uses
  • None
"This alarm clock is very sleek, attractive, and reasonably functional. The blue backlit display--which lights up the control buttons as well as the clock--is the best feature. It easily adjusts to different brightness levels by touching the wide snooze bar. So, in the dark, you can increase the brig …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 15 2008
gsk
Indianapolis
I am:
  • Practical
Reviewed at:
Price: $39.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
