Sony DVP-NS77H DVD Player
4.5
based on 37 reviews
Ratings Distribution
5 star
21
4 star
15
3 star
1
2 star
0
1 star
0
Category Average
3.6
More Images
Pros
  • Easy setup (35)
  • Easy to use (34)
  • High quality picture (34)
  • Consistent performance (26)
  • Durable (14)
See less See more
Cons
  • Available (1)
  • Average picture quality (1)
  • Difficult to use (1)
  • Noisy when used with rca (1)
  • Specs don't say 1080p is (1)
  • Tiny buttons (1)
Best Uses
  • Home (33)
  • High volume usage (5)
  • Dorm room (4)
  • Office (4)
  • Bedroom (1)
  • Business (1)
  • Media room (1)
Provided by B&H Photo Video
The Sony DVP-NS77H DVD Player brings your home theater experience to a whole new level with superb HD DVD imagery and exquisite digital audio sound. Your current DVD library will look and sound better than ever before, because the DVP-NS77H is a backward-compatible multi-format DVD player, capable of upconverting your DVDs to a 1080p high-definition experience. With the DVP-NS77H, enjoy the awesome power of Dolby Digital and DTS digital-audio for a wider, more enveloping surround-sound experience. In addition, the Sony DVP-NS77H presents superb functionality and high-end features that will be hard to match, such as Precision Cinema Progressive, component video output, HDMI output, 192KHz/24-Bit audio processing, and Precision Drive 3 System. With connectivity to multiple A/V components and playback capabilities of a variety of video and audio formats, the Sony DVP-NS77H answers the call with versatility and reliability.
Specification Description
Model DVP-NS77H/B, DVP-NS77H/S, DVP-NS77HB, DVPNS77H/B
UPC 027242708914
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD
DiVX Play Compatible Not Applicable
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Not Applicable
DVD Dual Layer Record Compatible Does not Record
Manufacturer’s Warranty 1 Year
Power Supply 110 Volts AC
Scanning Modes Progressive Scan
TV Broadcast Compatibility NTSC
Type of DVD Unit Component DVD Player
Video Standard Up to 480p
Sony DVP-NS77H DVD Player Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DVP-NS77H DVD Player
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 5, 2008
Sony DVP-NS77H DVD Player Reviews
Most helpful positive review
Most helpful negative review
5.0
Great product, great value.
"A HUGE difference on my HDTV set. My old DVD player was a solid workhorse, but on a high def tv, the dvds still looked grainy. But, the new upconverting player, along with an HDMI cable, does a nice job of playing movies in almost true HD. I watch a lot of DVDs (a lot of time it's background viewing as I'm going about my day), and this one makes the visual aspect of my movie watching that much better. [$] it..." Read Full Review »
Jan 14, 2008 by PJ
See more positive Sony DVP-NS77H DVD Player reviews
3.0
Sony 1080p upconverting DVD player
"Picture quality isn't any different from a regular DVD player..." Read Full Review »
Mar 10, 2008 by phil
See more negative Sony DVP-NS77H DVD Player reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • None
    Best Uses
  • High Volume Usage
  • Home
"A HUGE difference on my HDTV set. My old DVD player was a solid workhorse, but on a high def tv, the dvds still looked grainy. But, the new upconverting player, along with an HDMI cable, does a nice job of playing movies in almost true HD. I watch a lot of DVDs (a lot of time it's background view …"  Read Full Review »
Was this DVD Player review on the Sony DVP-NS77H DVD Player helpful to you?
Jan 14 2008
PJ
Elgin, IL
I am:
  • Gearhead
  • Practical
  • Tech Savvy
Reviewed at:
Great DVD player
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"I purchased this DVD player to watch DVD's on my new Sony KDL26S3000 LCD HD TV. The connection to the TV is via the HDMI output. As with most new devices with HDMI connectivity, the cable is not included. I picked up a generic cable at my local electronics store. Don't fall for the ultra expensi …"  Read Full Review »
Jan 25 2008
Tom K
New York
I am:
  • Tech Savvy
Reviewed at:
Small and unobtrusive player delivers
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • Noisy when used with RCA
    Best Uses
  • Home
"Simple and easy to set up, this player offers a cheap entry-level upconverting DVD player. I had no problems hooking this unit up to my Samsung LN-T3232 LCD. It has performed quite well and I got what I was expecting from a player at this tier. I like the fact that, unlike my old JVC, there is not a …"  Read Full Review »
Feb 5 2008
Monk
Sherman, Tx.
I am:
  • Tech Savvy
Reviewed at:
Seems fine. Decent price.
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Dorm Room
  • Home
"Works fine. Picture is very good. Seems to be a very good player.
3 Pros--
1. It's a SONY...that means a lot when it comes to quality.
2. Remote can control TV also.
3. Instruction booklet actually makes sense (for the most part) and that is not the norm for most tech devices.
Mar 10 2008
brewski53
Capon Bridge, WV
I am:
  • Practical
Reviewed at:
Great player, great price
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Dorm Room
  • High Volume Usage
  • Home
  • Office
"Some reviews have said it is slow to load. I didn't find this to be as bad as some describe. it does take anywhere from 20 - 50 seconds to get warmed up, but then it performs like a champ.
The picture quality is excellent, and quite noticable from using component video and audio cables. Spider …"  Read Full Review »
Jun 12 2008
Chuck
Phoenix, AZ
I am:
  • Practical
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
