Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette
#4
4.6
based on 145 reviews
Ratings Distribution
5 star
96
4 star
39
3 star
8
2 star
1
1 star
1
Category Average
4.5
Low Price:
$2.20 at Adorama
 Trusted:
$8.24 at Business-Supply
$2.99 at MacMall
see all stores
$2.20 - $9.84
from 10 stores
More Images
Pros
  • Reliable (90)
  • Good value (83)
  • High quality recording (57)
  • High-quality recording (28)
  • Durable (27)
  • Versatile (20)
  • Produces great video (5)
  • Easy to use (4)
  • High quality (4)
  • Highly compatible (4)
See less See more
Cons
  • Drops frames (3)
  • Loses quality over time (3)
  • Low-quality recordings (2)
  • Weak casing (2)
  • Cross-model issues (1)
  • Doesn't record audio well (1)
  • Doesn't work in my camera (1)
  • Drops frames sometimes (1)
  • Far to much wrapping (1)
  • Low-quality recording (1)
Best Uses
  • Master recordings (73)
  • Camcorders (31)
  • Back-up (30)
  • Dubbing (28)
  • Documentaries (5)
  • Shooting indoors (5)
  • Shooting outdoors (5)
  • Home movies (4)
  • Recording from tv (4)
  • Travel (4)
Provided by OnSale
DVM60PRL 60min DV tape DVM60PRL 60minute PREMIUM DV tape with combined technology of metal evaporated tape and diamond-like carbon coating protective layer that improves durability and helps prevent shedding and drop out. Watch the moments you record come alive on quality digital video when you record using the DV-M60PRL Digital Video Cassette. Providing 60 minutes of Premium quality digital video, this Mini Digital Video Tape, features Metal evaporated tape, and a Diamond-Like Carbon coating protective layer, which improves durability and helps prevent shedding and drop out. Start recording now on the DV-M60PRL.
Specification Description
Model 10273676, 10273684, DVM-60 PR, DVM-60PR
UPC 027242232631
#per pack 1
Accessory Indicator Yes
Benefits 60 minutes of recording time lets you capture the important momentsAdvanced metal-evaporated tape technology increases performance an
Capacity UOM mAh
Country Of Origin Mexico
Description Header Preserve the past.
Display Catalog Number 55023509
Manufacturer Labor Warranty 90
Manufacturer Part Number DVM60PRL
Manufacturer Parts Warranty 90
MAP Price 0.0
Maximum recording time 60 Minutes
Model DVM-60 PR
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer Return Disclaimer: *Due to manufacturers' policies, RadioShack.com cannot accept returns on this item for any reason. Check the box for damage when yo
Product Type MiniDV
Product Weight UOM pounds
Supported Languages English
Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette Questions
Questions and Answers
Where to Buy
$2.20
BizRate Rating Outstanding 9.1
$6.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$2.99
BizRate Rating Outstanding 9.0
Show all 10 stores
Product Reviews
Last update: Nov 17, 2009
Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette Reviews
Most helpful positive review
Most helpful negative review
4.0
A Solid Standard DV Tape
"I've been using these DVC Tapes for years. I use them both in my personal equipment as well as for professional applications. I do allot of work for a small cable access station that has used this particular tape stock for use with The Panasonic DVX-100A&B. Our work flow consists of Recording to tape, capturing in Final Cut Via a Sony DSR-11 DV Deck, and setting the tape on a shelf for storage. Once captur..." Read Full Review »
Jun 26, 2009 by MediaMike
See more positive Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette reviews
3.0
Good, but some cross-brand issues
"Have had only a few drop-outs, and some of those may be camera-related (usually on an old Canon XL1). One annoyance is when I shoot on the boss's Canon and capture using my Sony DSR11 deck, FCP constantly loses time code and stops. I have to instead capture using my Panasonic HVX200, and even then there are some dropped frames. Shooting and capturing from the HVX200 yields much better results. Can't beat the pri..." Read Full Review »
Oct 29, 2008 by TwinCitiesShooter
See more negative Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette reviews
Displaying 1 - 5 of 145 Reviews
Show
Sort by
4.0
    Pros
  • Inexpensive
  • Reliable
    Cons
  • Not for Repeated Use
    Best Uses
  • Camcorders
  • Single use recording
I use them both in my personal equipment as well as for professional applications. I do allot of work for a small cable access station that has used this particular tape stock for use with The Panasonic DVX-100A&B. Our work flow consists of Recording …"  Read Full Review »
Was this Blank VHS Tape review on the Sony DVM-60PR 60 Minutes Premium Mini DV Video Tape Cassette helpful to you?
Jun 26 2009
MediaMike
Los Angeles, CA
I am:
  • Enthusiast
Reviewed at:
Better than my Panasonics
5.0
    Pros
  • High-Quality Recording
    Cons
  • Weak Casing
    Best Uses
  • Camcorders
"I have been using Panasonic tapes with my Sony cameras in the past, so when I purchased a Z1U recently, I picked up the Panasonic DVM83PQ tapes for that camera. I used them for a while before switching to these because one of the Panasonic tapes I used to film a wedding came back completely unusabl …"  Read Full Review »
Jun 28 2009
Cheshire
Greenville SC
I am:
  • Power User
Reviewed at:
Great for back up when you run out.
4.0
    Pros
  • Great for back-up
    Cons
  • Loses Quality Over Time
    Best Uses
  • Movie making
"I've done extensive research and from experience know that these tapes are the best in the cheaper price range. They are better than tapes that cost twice as much. I would not use them for master recordings since they don't stand up to the test of time. I only buy them as back-ups for when I run …"  Read Full Review »
Aug 16 2009
Kai-Hsuan
San Antonio, TX
I am:
  • Power User
Reviewed at:
Fantastic quality AND price!!!
5.0
    Pros
  • Good Value
  • High Quality Recording
  • Reliable
  • Versatile
    Cons
  • None
    Best Uses
  • Backup
  • Dubbing
  • Master Recordings
"I've been using Sony tapes for about 3 years now and I haven't encountered a problem yet! I'm a videographer and have used it in so many cameras (JVC's newest HD cam, Canon PD-150, Sony HDV-Z1U, Panasonic PV-GS150, Canon GL1 and GL2) without any problem. The tapes are cheap (price wise), reliable, …"  Read Full Review »
May 21 2008
Kira
Plano, TX
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Affordable and Reliable
4.0
    Pros
  • Affordable
  • Durable Design
  • Easy To Use
  • Great for HDV
  • Highly Compatible
  • More »
    Cons
  • None
    Best Uses
  • Documentaries
  • Home Movies
  • Shooting Indoors
  • Shooting Outdoors
  • Training videos
  • More »
"Used for shooting HDV with the Sony FX1. Out of 100 or so I've had 1 bad tape (but it was immediately noticeable while recording, so I jut swapped tapes and all was good). To me that's an acceptable number of bad apples considering how affordable the tapes are. That one bad tape is what made me rate …"  Read Full Review »
Apr 10 2008
Patrick
Denver, CO
I am:
  • Tech Savvy
  • Video Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
