Sony DSC-W70 Digital Camera, 7.0 Megapixel, 3x Optical, 2x Digital Zoom, 2.5" LCD Screen
4.4
based on 7 reviews
from
Ratings Distribution
5 star
3
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.2
More Images
Pros
  • Accurate colors (7)
  • High resolution (7)
  • Nice features/settings (7)
  • Simple controls (5)
  • Rugged (3)
  • Compact (1)
  • Crisp and clear (1)
  • Lightweight (1)
See less See more
Cons
  • Flash delay in low light (1)
Best Uses
  • Everyday (6)
  • Outdoors (4)
  • Sports/action (4)
  • Portraits (3)
  • Low light (2)
  • Travel (2)
  • Weddings (1)
Provided by RitzCamera.com
The Sony Cyber-shot DSC-W70 is an ideal camera for starting out right in digital photography, combining the quality of 7.2 megapixels and Carl Zeiss 3X optical zoom, the performance of High Sensitivity mode for great low-light shots, the simplicity of on-screen Function Guide for easy setup, and the convenience of 58 MB2 Internal Memory for shooting images in-camera.
7.2 Megapixel Super HAD CCD - Higher megapixels gives you more detail and definition for large prints and cropping in on your subject. Sony's advanced Super HAD (Hole Accumulated Diode) CCD design allows more light to pass to each pixel, increasing sensitivity and reducing noise.
Large 2.5-inch LCD Screen - The DSC-W70 has a bright 2.5-inch LCD screen for setting up and viewing images -- with a one touch Play button that makes it quick and easy to view your photos.
Simple Controls, Function Guide - User-friendly controls and simple on-screen Function Guide text/icon display help you set up camera functions -- and you' ll have greater creative freedom to adjust color mode (including Natural for subtle colors and Rich for more intense colors), sensitivity, brightness and image size.
High Sensitivity Mode - A new High Sensitivity Mode (ISO 1000) allows you to shoot with great results in low-light conditions -- and Sony's original Clear RAW NR (Noise Reduction) image processing technology helps suppress the color noise that can accompany high-sensitivity shooting.
Carl Zeiss 3X Optical/2X Digital Zoom/6X Total Zoom - 3X Optical Zoom helps the DSC-W50 bring distant subjects closer and lets you frame shots for better composition; Sony's precision 2X Digital Zoom provides an additional 2X magnification to zoom in close without jagged edges.
Stamina Battery Power - With its powerful Lithium Ion rechargeable battery, the DSC-W70 can capture up to 3602 images -- enough for a week of shooting. The compact BC-CSG Battery Charger is also supplied for battery recharging on the go.
14X Smart Zoom Feature - Sony's Smart Zoom feature lets you magnify your subject beyond the 3x optical zoom - to 3.6x (5MP), 4.5x (3MP), even 14x (VGA). By intelligently cropping into the central portion of the scene, it avoids the image distortion of other digital zooms.
Smart Zoom feature will not work at the highest resolution setting
Capture Images In-Camera - With 58 MB4 Internal Memory, the DSC-W70 allows you to shoot without a flash memory card --then transfer your images to optional Memory Stick Duo media, upload to your computer or make prints on your digital printer.
Memory Stick Duo Media - The DSC-W70 has a built-in slot for optional Memory Stick Duo or higher-capacity Memory Stick PRO Duo media -- the ultra compact media for shooting, storing and sharing your photo images.
Specification Description
Model DSC-W70, DSCW70
UPC 027242682245
Pixel Count 7 Megapixel
Select Camera Style Point & Shoot with Zoom Lens
Select Media Internal Memory,Memory Stick
Sony DSC-W70 Digital Camera, 7.0 Megapixel, 3x Optical, 2x Digital Zoom, 2.5" LCD Screen Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DSC-W70 Digital Camera, 7.0 Megapixel, 3x Optical, 2x Digital Zoom, 2.5" LCD Screen
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 3, 2007
Sony DSC-W70 Digital Camera, 7.0 Megapixel, 3x Optical, 2x Digital Zoom, 2.5" LCD Screen Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[6 of 7 customers found this review helpful]
great buy
5.0
    Pros
  • Accurate Colors
  • Compact
  • Great Resolution
  • Light weight
  • Nice Features and Settings
    Cons
  • None
    Best Uses
  • Everyday
"i love it. i used to have the cyber shot dsc w7 and that one was great but this one is awesome. it is smaller and sleeker. it takes awesome pictures too. "
a picture of my niece i took at the pool
  • Made with Product
  • Using Product
Was this Point & Shoot Camera review on the Sony DSC-W70 Digital Camera, 7.0 Megapixel, 3x Optical, 2x Digital Zoom, 2.5" LCD Screen helpful to you?
 Report Abuse  (6)  (1)  0 comments
Dec 22 2006
Jazzy Jaz
Daytona beach, FL
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Enough and then some...
4.0
    Pros
  • Accurate Colors
  • Great Resolution
  • Simple Controls
    Cons
  • Flash Delay in Low Light
    Best Uses
  • Everyday
  • Outdoors
  • Portraits
  • Sports/Action
"PROSSmall/compact and easy to use. Controls are simplified and descriptions of controls are easily identified.Multi function allows me to take multiple shots over a few seconds. Great for analyzing your golf swing and kid's baseball swing.CONSZoom is weaker than what I expected, but that can easil …"  Read Full Review »
Dec 19 2006
Matt
Chicago
I am:
  • Casual user
Reviewed at:
[2 of 2 customers found this review helpful]
Great things DO come in small packages!
5.0
    Pros
  • Accurate Colors
  • Crisp and Clear
  • Great Resolution
  • Rugged
  • More »
    Cons
  • None
    Best Uses
  • Everyday
  • Low Lighting
  • Outdoors
  • Sports/Action
  • Travel
"This is a compact camera with incredible features and abilities. I would recommend it to everyone. It exceeded my expectations! "
 Report Abuse  (2)  (0)  0 comments
Dec 30 2006
Jumper Joy
Rapid City, SD
I am:
Reviewed at:
Style
4.0
    Pros
  • Accurate Colors
  • Great Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Everyday
  • Low Lighting
  • Outdoors
  • Portraits
  • Sports/Action
  • More »
"I like the size and shape, but I wish that the LCD screen had a protective step that would prevent screen contact when set on its back. Just a thought "
Jan 3 2007
Steve
Chicago,IL
I am:
  • Casual user
  • Getting started
Reviewed at:
[0 of 1 customers found this review helpful]
Great Camera!!
4.0
    Pros
  • Accurate Colors
  • Great Resolution
  • Rugged
  • Simple Controls
    Cons
  • None
    Best Uses
  • Everyday
  • Outdoors
  • Sports/Action
"Love it! It's compact and takes great pics. "
 Report Abuse  (0)  (1)  0 comments
Dec 13 2006
D
Chicago
I am:
  • Casual user
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
