Sony DCR-DVD850 DVD Handycam Camcorder
#33
4.9
based on 8 reviews
from $359.00 - $429.99
Ratings Distribution
5 star
7
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$359.00 at B&H Photo Video
 Trusted:
$359.99 at Crutchfield
Find it at Amazon
More Images
Pros
  • Comfortable to operate (4)
  • Great features (4)
  • Great picture quality (4)
  • Great sound quality (4)
  • Simple controls (4)
  • Versatile (4)
  • Durable (3)
  • Internal 16mb memory (1)
  • Memory stick (1)
  • Mini dvd recorder (1)
See less See more
Cons
  • Lacks headphone jack (1)
  • Lacks internal mic input (1)
  • Uncomfortable (1)
Best Uses
  • Travel (5)
  • Home movies (4)
  • Movies/short films (4)
Provided by ClubMac
DCR-DVD850 16GB DVD Handycam Camcorder Enjoy those priceless moments over and over with the DCR-DVD850 DVD Handycam camcorder. It combines maximum flexibility with powerful features. Series highlights: 16GB embedded memory, hybrid plus, 60x optical / 2000x digital zoom, Carl Zeiss Vario-Tessar lens, 1/8" advanced HAD CCD imager, DVD-R/-RW/+RW and +R DL (Dual Layer) compatibleEnjoy those priceless moments over and over with the DCR-DVD850 DVD Handycam camcorder. It combines maximum flexibility with powerful features like a Carl Zeiss 60x optical zoom lens and SteadyShot image stabilization that makes capturing sharp images a snap. Hybrid Plus technology gives you the option to record to DVD, 16GB of internal memory, or removable Memory Stick Duo or Memory Stick PRO Duo media (sold separately).Features:
  • 16GB embedded memory: 16GB of embedded memory can record and store up to almost 11 hours of video footage (SD LP mode).
  • Hybrid Plus offers flexible recording and transfer options: Hybrid Plus recording technology delivers a new level of flexibility for transferring your video footage and digital photos from the camcorder to compatible viewing devices. Record to your choice of 3 DVD media, 16GB embedded flash memory, or removable Memory Stick PRO Duo media (all media sold separately). You can even select from various dubbing functions to easily copy video from Memory Stick media or built in flash memory media to DVD -- without using a PC. Images recorded or transferred to DVD media can then be played directly in most DVD Players (SD), computers, Blu-ray Disc players, and even PLAYSTATION3 video game consoles to share your memories with friends and family.
  • 60X Optical / 2000X Digital Zoom: Ideal for sporting events, wildlife, or distance shooting, 60X optical zoom brings you closer to the action, so you can capture extremely tight shots, even from far away. In addition, Digital Zoom Interpolation means that extreme digital zooming (up to 2000X) is clearer, with less distortion than previous types of digital zooms.
  • Carl Zeiss Vario-Tessar lens with SteadyShot image stabilization: The DCR-DVD850 features a professional-quality Carl Zeiss Vario-Tessar lens designed specifically for compact camcorders. Precision ground optics help maintain the sharpness and contrast of larger lenses, and SteadyShot image stabilization helps reduce blur caused by camera shake.
  • 1/8 Advanced HAD CCD Imager: A 1/8 Advanced HAD (Hole Accumulation Diode) CCD imager with 410K (effective) pixel resolution delivers stunning detail and clarity for exceptional video and still image performance.
  • DVD-R/-RW/+RW and +R DL (Dual Layer) Compatible: The DCR-DVD850 is compatible with a variety of DVD formats (DVD-R/-RW/+RW and +R DL (Dual Layer), allowing you to take advantage of the ease-of-use and simplicity found in DVD media. With DVD+RW media, there is no need to finalize the disc (minimum recording required); simply remove and insert the media into a compatible DVD or Blu-ray Disc player.
  • 2.7 wide touch panel LCD display (123k pixels): The 2.7" wide touch panel LCD display provides exceptional viewing clarity with 123K pixels resolution. The display rotates up to 270 degrees for multiple viewing angles, as well as provides sharp, detailed images for monitoring or playback. The convenient touch panel allows easy access to menus and additional functionality such as spot focus and spot metering.
  • Power On by opening LCD display: Quickly power on your camcorder by simply opening the LCD display.
  • Dolby Digital 5.1ch recording with Built-in Zoom Mic: Dolby Digital 5.1 channel recording captures active sounds coming from all directions, so you can experience your home movies the way you experienced them while recording. The Built-In Zoom Mic focuses audio recording on your subjects in sync with the cameras zoom lens.
  • Includes Sony PMB (Picture Motion Browser) software: Sony Picture Motion Browser software offers a simple, intuitive way to transfer, sort, and view your video and still images on your compatible PC. In addition, multiple output options let you burn your memories to DVD (sold separately), as well as take advantage of one click upload to a number of popular video and photo sharing sites.
  • Color Viewfinder (123k pixels): The DCR-DVD850 features a 123k pixel resolution color viewfinder that lets you record and review video and still images.
  • VOne Touch Disc Burn: Easily burn a DVD copy of your footage using the supplied PMB (Picture Motion Browser) software. Simply connect the camcorder to your compatible PC via a USB cable and press the One Touch Disc Burn Button.
  • Easy Handycam Button: Using a camcorder can be intimidating for some people. With a press of the Easy Handycam Button, most of the advanced features of the camcorder are "locked out," letting you focus only the buttons essential for recording.
  • Film Roll Index: Like chapters in a book, Film Roll Index helps you easily find desired scenes in video footage. When using this feature, the camcorder previews the beginning of scenes and can create scene indexes set at specified display intervals (3, 6, or 12 seconds and 1 or 5 minutes).
  • Face Index function:VFace Index makes it easier than ever to find and play back the right video scene. Using Face Detection technology, Face Index indexes your video footage according to the faces detected in each scene. When its time to play back video, simply search for what you want by selecting from among the detected faces displayed in the index.
  • Playback Zoom: Playback Zoom lets you zoom in up to 5x closer on your videos during playback or in the playback pause mode.
  • USB 2.0 interface: A USB 2.0 interface provides an easy way to connect your camcorder to a compatible PC for fast transfer of video and still images for editing.
Specification Description
Model DCR-DVD850, DCRDVD850
UPC 027242763104
Definition Standard Definition
Recording Format Hard Drive - DVD
Select Format DVD,Memory Cards
Still Image Capability Stores still images on memory card
Video Compatibility NTSC
Sony DCR-DVD850 DVD Handycam Camcorder Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 20, 2009
Sony DCR-DVD850 DVD Handycam Camcorder Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
[14 of 14 customers found this review helpful]
Great Little Camcorder!!
5.0
"I purchased this camera after discovering my 8-year-old camcorder no longer worked three days before my vacation. I received my camcorder the day before my trip and only had time to charge the battery and read some basic information. I found the camcorder user-friendly and easy to use right out of t …"  Read Full Review »
Was this Digital Camcorder review on the Sony DCR-DVD850 DVD Handycam Camcorder helpful to you?
 Report Abuse  (14)  (0)  0 comments
Jun 15 2009
Lorraine Hornig
Bechtelsville, PA USA
Reviewed at:
Price: $429.99
[10 of 10 customers found this review helpful]
Sony Camcorder
5.0
"I am very pleased with the overall quality and functionality of this camcorder. The camera takes excellent video (action shots are great). It is very stable and I like having choices on how to save. It is also very easy to download to pc or view on pc or tv. I highly recommend this product. You cou …"  Read Full Review »
 Report Abuse  (10)  (0)  0 comments
Apr 20 2009
J. Brooks
Friendswood, TX United States
Reviewed at:
Price: $429.99
Graet camera
5.0
    Pros
  • Great Features
  • Great Picture Quality
  • Great Sound
    Cons
  • Uncomfortable
    Best Uses
  • Home Movies
  • Travel
"The 60x optical zoom is fantastic! Gets a clear picture even at ths zoom.
Focus is excellent. Camcorder holds it focus even against the sky (backlighting) and ripples on the water and on fish in shallow water even with stones in the water in the background.
The still shots - not so good, …"  Read Full Review »
Sep 29 2009
me
Ft. Myers FL
I am:
  • Video Enthusiast
Reviewed at:
Price: $359.00
Sony DCR DVD 850
5.0
    Pros
  • Comfortable to Operate
  • Durable
  • Great Features
  • Great Sound
  • More »
    Cons
    Best Uses
  • Home Movies
  • Movies/Short Films
  • Travel
"The #1 accessory to have is the AC-VQH10 fast charger/camera power supply. It's worth the expense because it can be used for both powering the camera or charging two batteries. This charger has an automatic shut off and many other features. However AC cord is polarized. Buy the ACC-FH70 accessor …"  Read Full Review »
Oct 14 2009
Guvno
Elgin IL
I am:
  • Casual User
Reviewed at:
Price: $379.00
A great camcorder with exceptional video
5.0
    Pros
  • Durable
  • Great Features
  • Great Sound
  • More »
    Cons
  • None
    Best Uses
  • Home Movies
  • Travel
"I like the ease of use-it has an easy button on it so you can use it immediately. It fits the hand very nicely. The zoom works very smooth-I have used other camcorders where the zoom was hard to control. I would recomend this unit to anyone that wants a good value at a good price. "
Oct 20 2009
Jimbo
Chippewa Falls, WI
I am:
  • Video Enthusiast
Reviewed at:
Price: $359.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
