Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder
4.4
based on 17 reviews
from
Ratings Distribution
5 star
9
4 star
7
3 star
0
2 star
1
1 star
0
Category Average
4.1
More Images
Pros
  • Comfortable to operate (12)
  • Simple controls (11)
  • Great features (9)
  • Great picture quality (9)
  • Great sound quality (9)
  • Versatile (8)
  • Durable (7)
See less See more
Cons
  • Less memory options (1)
  • Short battery life (1)
Best Uses
  • Travel (8)
  • Family (5)
  • Home movies (5)
  • Special events (3)
  • Movies/short films (2)
  • Documentaries (1)
  • Editing (1)
  • Hd shooting (1)
  • Sports (1)
  • Weddings (1)
Provided by OneCall
The DCR-DVD710 delivers advanced features that let you easily capture and share crystal clear video. A professional-quality Carl Zeiss(R) Vario-Tessar(R) lens and Super SteadyShot(R) image stabilization captures sharp video and still images, even when getting in close with the 25x optical/2000x digital zoom. With Hybrid technology, you can record it all directly to either DVD or removable Memory Stick PRO Duo(TM) media for quick viewing or transfer to a PC. The built-in Zoom microphone with Dolby(R) Digital 5.1 channel recording captures realistic surround sound, recording your subjects in sync with the camera's zoom lens—helping memories ring true with clear dialogue and crisp, discrete sounds.
1/6-inch Advanced HAD CCD Imager, 680K Pixels (Gross)
1/6-inch Advanced HAD(TM) (Hole Accumulation Diode) CCD with 680K (effective) pixels provides stunning detail and clarity with exceptional video (up to 500 lines of horizontal resolution) and still image performance
25X Optical / 2000X Digital Zoom
The optical zoom helps to bring the action close up from far away. In addition, Digital Zoom Interpolation means that extreme digital zooming is clearer, with less distortion than previous types of digital zoom.
Professional Quality Carl Zeiss Vario-Tessar Lens
Carl Zeiss(R) Vario-Tessar lenses are designed specifically for compact camcorders, and utilize precision ground optics to maintain the sharpness and contrast found with larger lenses.
DVD Format Video Recording
The DVD recording format in MPEG2 (SD) delivers digital picture and sound quality comparable to that of MiniDV, but on DVD. Playback of these DVDs couldn't be simpler (depending upon the playback device used). After finalizing the disc in the camcorder, the disc can play back in most DVD Players (SD), computers, Blu-ray Disc(TM) players, and even PlayStation(R) 3 video game consoles.
DVD-R/-RW/+RW and +R DL (Dual Layer) Compatible
Compatibility with a variety of DVD formats3 allows the ease-of-use and simplicity found in DVD media. With DVD+RW media there is no need to finalize the disc (minimum recording required); simply remove the finalized disc and insert the media into a compatible DVD or Blu-ray Disc(TM) Player.
Hybrid Recording to DVD or Memory Stick Media
Hybrid recording technology delivers a new level of flexibility for transferring your video footage and digital photos from the camcorder to compatible viewing devices. Record to DVD media, or choose instead to record to removable Memory Stick Duo(TM) media or Memory Stick PRO Duo(TM) media. You can even select from various dubbing functions to easily copy video or still images from the Memory Stick media to DVD -- without using a PC. Images recorded or transferred to DVD can then be played directly most DVD Players (SD), computers, Blu-ray Disc(TM) players, and even PlayStation(R) 3 video game consoles to share your memories with friends and family.
Quick On
Missing an important scene can be frustrating, especially if the reason is because your camcorder is turned off. With the Quick On feature, the touch of a single button places that camcorder in Sleep mode. Another push instantly wakes the camcorder, so you`ll always be ready to capture special moments.
Built-in zoom microphone with 5.1 ch recording
Featuring Dolby(R) Ditigal 5.1 Creator, the built-in zoom microphone focuses audio recording on your subjects in sync with the camera`s zoom lens, helping memories ring true with clear dialogue and crisp, discrete sounds.
2.7-inch Wide (16:9) Hybrid Touch Panel Clear Photo LCD Plus Display (211K Pixels)
The 2.7-inch Wide (16:9) LCD screen provides exceptional viewing clarity with improved resolution (211K pixels). The display rotates up to 270 degrees for multiple viewing angles, as well as provides sharp, detailed images for monitoring or playback. The widescreen format makes shooting in 16:9 mode and composing shots even easier.
Memory Stick PRO Duo Media Slot
Capture still images directly onto Memory Stick PRO Duo(TM) media (sold separately) for easy transfer to PCs for emailing, printing, or sharing with other compatible Memory Stick(R) devices (sold separately).
Super SteadyShot Image Stabilization System
An advanced version of Sony's SteadyShot(R) Image Stabilization system that controls an even higher range of shake and vibration frequencies, to achieve an even higher level of smoothness without degradation of video like some other image stabilization systems.
InfoLITHIUM Battery with AccuPower Meter System
Unlike NiCad (Nickel Cadmium) batteries, Sony's rechargeable Lithium Ion batteries are not subjected to a life shortening Memory Effect, so you`re free to charge the battery at any time. Additionally, Sony's exclusive AccuPower(TM) meter displays the battery time remaining in minutes, in either the viewfinder or on the LCD screen.
Manual Focus
Manually adjust the focus of the camcorder using the touch panel. Manual focusing also allows the user to control the focus in difficult situations where either the environment or the subject does not allow the camcorder's auto focus to perform optimally, such as when shooting through a window or in a crowded environment.
Super NightShot Plus Infrared System
The Super NightShot(R) Plus Infrared System uses a slow shutter mode to let you shoot video with improved color and contrast, even in total darkness (0 lux).
Stamina Battery Power Management System
When using the Sony InfoLITHIUM(R) Battery, the Stamina(R) Battery Power Management System helps the camcorder prolong battery life for extra long continuous recording times from a single charge.
Scene Selection Modes
Scene Selection modes make recording easy even when filming in challenging situations. Choose from Auto, Twilight, Candle (move only), Sunrise & Sunset, Fireworks (move only), Landscape, Portrait, Spotlight, Sports (movie only), Beach, Snow
Picture Effects
Get creative when recording or playing back your videos with Sony's Picture Effect Modes. Effects available in Monotone, Sepia and Pastel
Fader Effects
Enhance your personal videos by adding professional looking fader effects. Choose from Black and White.
Visual Index Screen
Shows thumbnail images of video clips and still images when playing back on your camcorder or DVD player, making your selection easier.
Battery Information
At the touch of a button, battery information is displayed on the LCD screen when charging and when the camcorder is turned off. When using the LCD screen or viewfinder, the display will show how much the battery is charged -- in 10% increments -- and the recordable time left.
Easy Handycam Button
Using a camcorder can be intimidating for some people. With a press of the Easy Handycam Button, most of the advanced features of the camcorder are locked out, letting you focus only the buttons essential for recording.
Specification Description
Model DCR-DVD710, DCRDVD710
UPC 027242727694
16:9 Record Mode Yes
AC Adapter AC-L200
Accessory Shoe Active Interface Shoe
Analog Audio / Video (1) Rear Output
Aperture f/1.8-3.2
Compatible Battery NP-FH40
Definition Standard Definition
Depth (Inches) 5.12
Digital Effects Modes Yes
Digital Still/Memory Mode Yes
Digital Zoom 2000
Effective Megapixel Count 1
Eyepiece Viewfinder Color
Filter/Wide Angle Capability 30mm
Focus Control Automatic
Focus Control Manual
Height (Inches) 3.6
Image Format JPEG
Image Stabilization Sony SteadyShot
LCD Display Size (Inches) 2.7
Low Light Enhancement Mode Super NightShot Plus
Microphone Built-in
Microphone Zoom
Minimum Illumination (lux) 8
Optical Zoom 25
Recordable Media Type Memory Stick Duo
Recordable Media Type Memory Stick Pro Duo
Recordable Media Type MiniDVD+R DL
Recordable Media Type MiniDVD+RW
Recordable Media Type MiniDVD-R
Recordable Media Type MiniDVD-RW
Recording Format DVD
Remote Control Remote Commander
Resolution Standard Definition
S-Video (1) Rear Output
Scene Modes Automatic
Scene Modes Beach/Snow
Scene Modes Candle
Scene Modes Fireworks
Scene Modes Landscape
Scene Modes Portrait
Scene Modes Sports
Scene Modes SpotLight
Scene Modes Sunset
Scene Modes Twilight
Select Format DVD,Memory Cards
Shutter Speed 1/30-1/250
Still Image Capability Yes
Surround Modes Dolby Digital
USB Port (1) USB 2.0 High Speed
Video Compatibility NTSC
Weight (Pounds) .93
White Balance Auto
White Balance Indoor
White Balance Outdoor
Width (Inches) 2.25
Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 2, 2009
Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
very happy with this camcorder
"I was looking for a camcorder that i could film my girls soccer games and dance recitals. This is the perfect camcorder for that. It is very easy to use, and using the software provided, it is easy to burn on a dvd and play back on our theater dvd system. It also records in 5.1 surround, which really pulls you into the games with all of the sound. I bought a ns700 battery for extended recording, and would recomm..." Read Full Review »
Jun 11, 2008 by leatherneck
See more positive Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder reviews
2.0
Not the best!
"If you are about to buy this camera make sure you wont be using it for making movies, connecting it to the computer... i waited an hour to connect it and still wouldnt connect!..." Read Full Review »
Dec 18, 2008 by Kj222222222
See more negative Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
5.0
    Pros
  • Comfortable to Operate
  • Great Features
  • Great Picture Quality
  • Great Sound
  • Simple Controls
  • More »
    Cons
  • None
    Best Uses
  • Family
  • Special Events
  • Sports
  • Travel
  • Weddings
"I was looking for a camcorder that i could film my girls soccer games and dance recitals. This is the perfect camcorder for that. It is very easy to use, and using the software provided, it is easy to burn on a dvd and play back on our theater dvd system. It also records in 5.1 surround, which reall …"  Read Full Review »
Was this Digital Camcorder review on the Sony DCR-DVD710 Hybrid DVD/Memory Stick Standard Definition Camcorder helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jun 11 2008
leatherneck
longview, washington
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Happy with the product but expect more
4.0
    Pros
  • Durable
  • Great Sound
  • Simple Controls
    Cons
    Best Uses
  • Documentaries
  • Editing
  • Home Movies
  • Travel
"I am regular visitor of different places along with friends and the family. Even though i already had camera i feel that it is better to have a camcorder to take some of the incidents as videos rather than a photo so that i can capture people expressions also at that time and also to cover the whole …"  Read Full Review »
Apr 28 2009
Anil
San jose, CA
I am:
  • Casual User
Reviewed at:
Great little camcorder
5.0
    Pros
  • Durable
  • Great Sound
  • Simple Controls
  • Versatile
    Cons
  • None
    Best Uses
  • Home Movies
  • Travel
"This is the first camcorder I have ever bought. I wanted something that would be easy to use, yet I wanted some good quality taping too. This was sort of a last minute decision, but I will say I was not disappointed at all with the purchase. It's a great camera, good size, pretty good quality pictur …"  Read Full Review »
Jan 7 2009
The girl behind the camera
Auburn, MA
I am:
  • Video Enthusiast
Reviewed at:
I would buy this product again
5.0
    Pros
  • Durable
  • Great Features
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home Movies
  • Travel
"I loved how easy it was to set up. I spent the extra money and got the memory stick in addition to the DVD's. I was glad I had done so, when I needed to switch in the middle of a performance to the memory stick I was able to do so in less than 2 minutes - therefore not missing hardly any time record …"  Read Full Review »
Apr 23 2009
Melissa the Scrapbooker
Gladewater, TX
I am:
  • Video Enthusiast
Reviewed at:
Sony DCR-DVD710 camcorder
5.0
    Pros
  • Durable
  • Great Features
  • Great Sound
  • More »
    Cons
  • NO CONS
    Best Uses
  • HD Shooting
  • Home Movies
  • Movies/Short Films
  • Travel
"The Sony handycam hybrid is very easy to use, the touch screen is self explanatory and makes it simple to record, take pictures & finalize. I love the light weight and easy, no manual needed camcorder. I would recommend this to any body who wants a camcorder that records perfect videos, is user frie …"  Read Full Review »
May 24 2009
P_GONZALEZ
DALLAS, TX
I am:
  • Video Enthusiast
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
