Sony Cineza LCD Front Projectors Air Filter
#1
4.8
based on 16 reviews
from $29.99
Ratings Distribution
5 star
13
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.3
$29.99 at OneCall
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Easy setup (10)
  • Durable (4)
  • Lightweight (2)
  • Fits well (1)
  • Good focus (1)
  • Great picture quality (1)
  • Powerful (1)
  • Standard (1)
  • Traps the dust (1)
See less See more
Cons
  • High cost (1)
  • Not reusable (1)
  • Pricey (1)
Best Uses
  • Home (4)
  • Movies (4)
  • Television (4)
  • Large rooms (3)
  • Projector (1)
  • Replacement filter (1)
  • Vpl-hs10 (1)
Provided by Abt Electronics
Sony Cineza LCD Front Projectors Air Filter - PKHS10FL/ Designed To Work With The VPLHS60 VPLHS10 VPLHS20 and VPLHS51 Cineza LCD Front Projectors.
Sony Cineza LCD Front Projectors Air Filter Questions
Questions and Answers
Where to Buy
$29.99
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Oct 14, 2009
Sony Cineza LCD Front Projectors Air Filter Reviews
Most helpful positive review
Most helpful negative review
4.0
Replace often for optimum bulb life
"The replacement filter is a must have for anyone with the compatible SONY model projectors. It is extrememly easy to replace on a VPL-HS20 and seems to work well.Only downside is the relatively high cost for such a small and simple filter.I suggest you replace them more often than you think as they get dirty quickly and cause you lamp to get hotter.[...]..." Read Full Review »
Oct 29, 2007 by ukaussi
See more positive Sony Cineza LCD Front Projectors Air Filter reviews
3.0
Buy two while you are at it!
"You can't do without this filter. Clean air will keep your projector happy, cool, and running for a good long time. I looked at making my own filter, but[$] is cheap insurance to keep my projector up and running. Bought two and stocked up so I won't have to be without my projector the next time I need a filter...." Read Full Review »
Jul 19, 2008 by Trickster Tim
See more negative Sony Cineza LCD Front Projectors Air Filter reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Set Up
    Cons
  • Expensive
    Best Uses
  • Movies
"The replacement filter is a must have for anyone with the compatible SONY model projectors. It is extrememly easy to replace on a VPL-HS20 and seems to work well.Only downside is the relatively high cost for such a small and simple filter.I suggest you replace them more often than you think as they …"  Read Full Review »
Was this Video Projector Accessory review on the Sony Cineza LCD Front Projectors Air Filter helpful to you?
Oct 29 2007
ukaussi
OC, CA
I am:
  • Professional
Reviewed at:
Excellent [...] products[...]
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Lightweight
  • Powerful
    Cons
  • None
    Best Uses
  • Large Rooms
  • Movies
"The filter is exactly what we needed. It was priced well, was brand new, and cleared up our picture by replacing the filter. Best of all, the service from ABT was second to none! "
Feb 16 2008
MM
Grand Rapids, MI
I am:
  • Professional
Reviewed at:
Just what I needed
5.0
    Pros
  • Easy To Set Up
  • Lightweight
    Cons
  • None
    Best Uses
  • Television
"I didn't know I needed to replace filters, but after getting an error message from my projector, I needed a replacment filter. [...] Once I had the filter, it was wasy to replace my old filter. "
Apr 14 2009
Tuneman
Memphis, TN
I am:
  • Casual User
Reviewed at:
3.0
"You can't do without this filter. Clean air will keep your projector happy, cool, and running for a good long time. I looked at making my own filter, but[$] is cheap insurance to keep my projector up and running. Bought two and stocked up so I won't have to be without my projector the next time I ne …"  Read Full Review »
Jul 19 2008
Trickster Tim
Inland Empire, Southern California
I am:
  • Tech Savvy
Reviewed at:
As billed
5.0
"If you're lucky enough to have a projector that needs one of these puppies, you already know that if you need it, you need it. I bought two just in case! "
Oct 14 2009
Kimmy
Stockton, CA
I am:
  • Enthusiast
Reviewed at:
Price: $29.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
