Sony CFD-G505 Xplod CD Radio Cassette Recorder
#1
4.5
based on 116 reviews
from $97.00 - $109.99
Ratings Distribution
5 star
67
4 star
42
3 star
3
2 star
3
1 star
1
Category Average
4.0
More Images
Pros
  • Nice sound (61)
  • Powerful (58)
  • Great features (49)
  • Durable (47)
  • Great sound quality (19)
  • Simple / intuitive controls (16)
  • Attractive design (11)
  • Easy setup (11)
  • Compact (10)
  • Lightweight (9)
See less See more
Cons
  • Heavy / bulky (33)
  • Unattractive design (3)
  • Base sound kinda rattles (1)
  • Boombox is very deep (1)
  • Cd skips sometimes (1)
  • Controls (1)
  • Display is very small (1)
  • Heavy no big deal (1)
  • Lack of power (1)
  • Led display (1)
Best Uses
  • Home use (59)
  • Outdoors (35)
  • Office (25)
  • Travel (14)
  • Basic systems (12)
  • Large rooms (11)
  • Smaller rooms / apartments (11)
  • Audiophiles (5)
  • Dance class (2)
  • Anywhere (1)
Provided by OneCall
  • Aggressive Xplod Boombox Design with Power Drive
  • Larger 100mm Power Drive Woofer
  • High Power 20W Total RMS
  • PC/Audio In for Digital Music Players or PC Input
  • Illuminated PDW Indicator on Woofer Cover
  • Digital AM/FM Stereo Tuner
  • Remote Control w/10-Key Direct Access(TM) Buttons for Tuner & CD
  • 4 Preset Sound Modes
  • Power Drive Woofer Control (Off/1/2)
  • CD-R/RW Playback Capability
  • 20 Track RMS Programming
  • CD Play Modes (Program/Shuffle/Repeat)
  • 30 Station Memory presets (10AM/20FM)
  • Synchronized CD/Cassette Dubbing
    Aggressive Xplod Boombox Design with Power Drive: represents high quality and power with a new aggressive look.
    Larger 100mm Power Drive Woofer: for a greater bass response.
    High Power 20W Total RMS: provides plenty of power to drive the power drive woofer and fill any room with sound
    PC/Audio In for Digital Music Players or PC Input: An exciting new feature that takes music playback beyond tape and CD. It allows simple plug-and-play integration with a Digital music device or PC via a 2.5 mm jack.
    Illuminated PDW Indicator on Woofer Cover: gives you a visual indication that the PDW is engaged.
    Digital AM/FM Stereo Tuner: provides the most accurate drift-free tuning of AM and FM radio stations and lets you choose from the wide variety of talk shows and music programs, with the added enjoyment of stereo sound.
    Remote Control with 10-Key Direct Access(TM) Buttons: full sized Remote Control including keys to directly access tracks on a CD as well as preset stations programmed into tuner memory.
    4 Preset Sound Modes: preset EQ settings of Rock/Pop/Jazz/Vocal, allowing you to select an appropriate sound adjustment to fit the type of music you are listening to
    Power Drive Woofer Control (Off 1, 2): lets you control the level of the power drive woofer.
    CD-R/RW Playback Compatibility: Plays all CD-R/RW discs burned either in a PC or a home recording deck. Create custom mixes from your existing music collection and always have the right music at hand.
    20 Track RMS Programming: can pre-program up to 20 tracks on a CD to play back in any order.
    CD Play Modes (Program/Shuffle/Repeat): lets you hear tracks in multiple modes; in sequence as recorded, in program (RMS) order, all tracks in random (shuffle) order or a single track over and over.
    30 Station Memory presets: uses electronic settings for easy, one-button tuning of your choice of 10 AM or 20 FM stations.
    Synchronized CD/Cassette Dubbing: starts cassette recording when compact disc playback begins.
  • Specification Description
    Model CFD-G505BLACK, CFD-G505Black, CFDG505BLA, CFDG505BLACK
    UPC 027242683754
    Benefits CD-R/-RW playback allows you to listen to discs burned on your PC or home recording systemAM/FM stereo reception with 30 presets give
    Capacity UOM mAh
    Connections Headphone 1/8" (1)Line in 1/8" (1)
    Country Of Origin United States
    Description Header Big-bass sound in a compact package.
    Display Catalog Number 55020337
    Enclosure Color Silver
    End Product Indicator Yes
    Features CD modes allow you to program the order of the tracks, place them on random shuffle or repeatRemote with Direct Access buttons lets y
    Included in the Box Xplod CD radio cassette recorderRemote controlAC power adapter
    Manufacturer Labor Warranty 90
    Manufacturer Part Number CFDG505Black
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model CFDG505Black
    Operating Temperature UOM ° F
    Power Device AC power cord (included); "D" batteries (8); DC adapter
    Product Depth 12.87
    Product Dimensions UOM inches
    Product Disclaimer Labor warranty is 90 days limited. Parts warranty is 1 year limited.
    Product Height 9.5
    Product Length 20.86
    Product Type CD/cassette/radio
    Product Weight 17
    Product Weight UOM pounds
    Product Width 20.86
    Remote Control Features 10-Key Direct Access buttons
    Supported Languages English
    Technology IR
    Sony CFD-G505 Xplod CD Radio Cassette Recorder Questions
    Questions and Answers
    Where to Buy
    $99.88
    $99.95
    $97.00
    5% off orders at Abt.com
    BizRate Rating Outstanding 9.4
    Show all 11 stores
    _
    Product Reviews
    Last update: Nov 13, 2009
    Sony CFD-G505 Xplod CD Radio Cassette Recorder Reviews
    Most helpful positive review
    [5 of 5 customers found this review helpful]
    Most helpful negative review
    [6 of 8 customers found this review helpful]
    5.0
    The X-Plod only by SONY
    "the x-plod has media input & got my accurian HD radio direct connected to my X-PLOD result awsome PERFORMANCE! Before I got mine I looked at the other brands out there. Sony makes boomboxes with the features I demand. Plus their Quality! Yes, I read the previous review. thats their review. Not mine. Regardless of what media you have this sonic marvel is worth every buck. It gets a solid 5-Stars nothing less. I a..." Read Full Review »
    Feb 16, 2009 by BUCK
    See more positive Sony CFD-G505 Xplod CD Radio Cassette Recorder reviews
    1.0
    Sony Xplode is a bomb
    "Its underpowered,Sony is notoriously cheap quality from all my experiences,I remember when Radio Shack had GOOD merchandise lines such as Optimus,medium level such as Realistic,and even good quality low price such as the Radio Shack line. Radio Shack has lost alot of my business since eliminating these products and carrying cheap low quality Sony ,RCA merchandise...." Read Full Review »
    Oct 22, 2007 by TMK
    See more negative Sony CFD-G505 Xplod CD Radio Cassette Recorder reviews
    Displaying 1 - 5 of 116 Reviews
    Show
    Sort by
    5.0
      Pros
    • Attractive Design
    • Easy Controls
    • Easy To Set Up
    • Great Sound
    • X-PLod outsells all-
      Cons
    • Heavy
      Best Uses
    • Audiophiles
    • Basic Systems
    • Kicks A
    • Larger Rooms
    • Smaller Rooms
    "the x-plod has media input & got my accurian HD radio direct connected to my X-PLOD result awsome PERFORMANCE! Before I got mine I looked at the other brands out there. Sony makes boomboxes with the features I demand. Plus their Quality! Yes, I read the previous review. thats their review. Not mine. …"  Read Full Review »
    Was this CD Player review on the Sony CFD-G505 Xplod CD Radio Cassette Recorder helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Feb 16 2009
    BUCK
    MUNCIE, INDIANA
    I am:
    • Audiophile
    • Musically Inclined
    • Practical
    • Tech Geek Ret
    • Tech Savvy
    Reviewed at:
    Price: $99.99
    This Bad Boy Rocks!!!!!
    5.0
      Pros
    • Attractive Design
    • Doesn't Skip
    • Durable
    • Easy Controls
    • Excellent Battery Life
    • More »
      Cons
    • None
      Best Uses
    • Audiophiles
    • Excellent for Outdoors
    • Larger Rooms
    • Pefect For Pontoon Boats
    • Smaller Rooms
    "I consider myself to be an audio snob. This thing sounds great. Good low end is the holy grail for boomboxes and it is amazing how many suck when it comes to bass response. The Sony XPlod pumps out some serious bottom end. Don't get me wrong, it is not like the subwoofers in those hip hop dudes' car …"  Read Full Review »
    Jul 5 2009
    Psychedelic Commando
    Florida Gulf Coast
    Reviewed at:
    Price: $99.99
    [6 of 7 customers found this review helpful]
    1.0
      Pros
    • None
      Cons
    • Low Quality
      Best Uses
    • None
    "Its underpowered,Sony is notoriously cheap quality from all my experiences,I remember when Radio Shack had GOOD merchandise lines such as Optimus,medium level such as Realistic,and even good quality low price such as the Radio Shack line. Radio Shack has lost alot of my business since eliminating th …"  Read Full Review »
     Report Abuse  (6)  (1)  0 comments
    Oct 22 2007
    TMK
    Allentown ,PA
    Reviewed at:
    Price: $99.99
    The sound is great for the price!
    4.0
      Pros
    • Easy Controls
    • Great AMFM Reception
    • Great Sound
      Cons
    • Ugly as Chicken Soup
      Best Uses
    • Good For Outdoor Use
    "I really think for the money you cannot go wrong with this boombox. Very clean bass,not at all muddy. Sony balanced the midrange and highs quite nicely with the bass. Even at its loudest, the sound can be adjusted to get a good, overall clean sound. I found the AM/FM tuner remarkably sensitive, pick …"  Read Full Review »
    Jul 21 2009
    Tom
    Indiana
    I am:
    • Practical
    Reviewed at:
    Price: $97.00
    [3 of 4 customers found this review helpful]
    5.0
      Pros
    • Best for your
    • Great Sound
    • Mine kicks "A"
    • Money
    • Own one
      Cons
    • Heavy
      Best Uses
    • Audiophiles
    • Basic Systems
    • Larger Rooms
    • Out by the pool
    • Smaller Rooms
    "I read the so so review. What planet did you come dude? My x-plod on most counts outsold all other brands 4 to 1. If I'd loose my sony, its replaced imedately! Said it all. Get it here at RS! "
     Report Abuse  (3)  (1)  0 comments
    Feb 18 2009
    BUCK
    MUNCIE, INDIANA
    I am:
    • Audiophile
    • Practical
    • Tech Geek Ret
    • Tech Savvy
    Reviewed at:
    Price: $99.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
