Sony BRAVIA Home Theater System - DAV-HDX277WC
4.3
based on 26 reviews
Ratings Distribution
5 star
11
4 star
13
3 star
2
2 star
0
1 star
0
Category Average
4.1
Low Price:
$229.99 at Newegg
 Trusted:
$234.99 at B&H Photo Video
Find it at Amazon
$229.99 - $429.00
from 16 stores
More Images
Pros
  • Clear sound (14)
  • Easy setup (11)
  • Interfaces well with tv (11)
  • Thundering bass (9)
  • Confusing / difficult controls (7)
  • Attracts visitors (1)
  • Excellent clarity (1)
  • Good value (1)
  • Great sound (1)
  • High quality (1)
See less See more
Cons
  • Difficult to set up (2)
  • Needs better bass (1)
  • Poor interface (1)
  • Surround sound erratic (1)
Best Uses
  • Living room (9)
  • Movies (9)
  • Surround sound solution (6)
  • Television shows (3)
  • Larger rooms (2)
  • Perfect all around home (1)
  • Smaller rooms (1)
Provided by OneCall
S-AIR Technology (integrated)
Multi-room listening made easy. Free your music. From room. To room. To room. AirStation automatically syncs to allow multi-room listening through simple, wireless plug-and-play technology while letting you control what you listen to.
BRAVIA(R) Sync(TM)
As a leader in products with HDMI connectivity, Sony has created BRAVIA(R) Theater Sync(TM) technology to go beyond simple audio and video transmission. When combined with a select number of BRAVIA(R) LCD televisions and other Sony audio and video products, control functions will also be transmitted via the HDMI cable4 With One Touch Play operations that took several steps have been reduced to one. Press the PLAY button on the remote, watch the audio and/or the video component(s) turn on then the BRAVIA(R) television will turn on and switch to the correct video input...Simple...Easy...BRAVIA(R) Theater Sync(TM)
DIGITAL MEDIA PORT
As the demand for digital content continues to be strong, here's the challenge: how do you integrate music in various forms into a home theater system– The answer: Sony`s DIGITAL MEDIA PORT (DMP). Together with one of the DMP accessories (sold separately), this proprietary interface adds networking and connectivity to the options of home theater systems and components, connects with various devices which provide the ability to control and power devices while making set up easy and operation simple. The DMP accessories will include a PC Client device, Bluetooth(R) receiver and Audio Docking Stations compatible with Network Walkman(TM) and iPod(R) products. So regardless of how you store your music, Sony`s DIGITAL MEDIA PORT offers an access point to integrate your portable music into a traditional home theater system.
Digital Cinema Auto Calibration
Now the optimal speaker settings for your living room are only a press of button away. Simply place the included microphone in your listening position and allow the strength of Sony`s Digital Signal Processing to take over. Speaker placement, distance, and delays are all calibrated automatically to ensure a worry free listening experience.
Portable Audio Enhancer
Simplified front audio and video connections are part of what makes the DAV-DX277WC ideal for today`s portables. Beyond the simplified connection a powerful Digital Signal Processor is used to expand the quality from any device that is connected.
Multi Speaker Formation
Select from the on screen display to configure the system for different speaker layout.
Music/Movie Mode
System automatically adjusts sound characteristics to match the source (movie vs. music).
Specification Description
Model DAV-HDX277WC, DAVHDX277WC
UPC 027242727663
Analog Audio Yes
Built-in DVD Player Yes
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+R DL
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats DVD-VR
Compatible Formats JPEG
Compatible Formats VCD
Component Video Yes
Composite Video Yes
D/A Converter 12-bit/108MHz
Disc Player DVD Player - Changer
DMP (Digital Media Port) Rear Input
HDMI Yes
Headphone Jack Yes
Main Features DVD Player / Radio
MP3 or iPod Connectivity iPod Dock included
Multi Disc Capacity 5
Multi-Disc Resume 40
On Screen Display Yes
Optical Yes
Play Modes Surround (5.1 Channels)
Progressive Scan Yes
Radio Bands AM/FM
Remote Control Included
Speakers 5 Satellites + Subwoofer
Surround Modes Dolby Digital
Surround Modes Dolby Pro Logic II
Timer Modes Clock and Timer Modes
Tuner AM
Tuner FM
Sony BRAVIA Home Theater System - DAV-HDX277WC Questions
Questions and Answers
Where to Buy
$234.99
No Tax Outside NY
BizRate Rating Outstanding 9.7
$429.00
BizRate Rating Outstanding 9.4
$229.99
BizRate Rating Outstanding 9.2
Show all 16 stores
Product Reviews
Last update: Sep 1, 2009
Sony BRAVIA Home Theater System - DAV-HDX277WC Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
I love my Bravia S-Air theater system!!
"I have owned this product for about a month now and have no complaints!! I have it in my living room hooked up to my Bravia TV. The sound is great and the set up wasn't too difficult. Excellent product!!!!!..." Read Full Review »
May 20, 2008 by Vic in NY
See more positive Sony BRAVIA Home Theater System - DAV-HDX277WC reviews
3.0
System is ok
"I figured 1000Watt power system would blast me out of my house, but not the case. After I set everything up I went to test the system. Before I knew it I was at full volume and it didn't seem very loud. My other home theater system in the main room is much louder, but the clarity is not as good. The system is just ok in my opinion...." Read Full Review »
Aug 11, 2008 by njm1
See more negative Sony BRAVIA Home Theater System - DAV-HDX277WC reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Excellent clarity
  • Interfaces Well With TV
  • Intuitive Controls
  • More »
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
"I have owned this product for about a month now and have no complaints!! I have it in my living room hooked up to my Bravia TV. The sound is great and the set up wasn't too difficult. Excellent product!!!!! "
Was this Home Theater review on the Sony BRAVIA Home Theater System - DAV-HDX277WC helpful to you?
 Report Abuse  (4)  (0)  0 comments
May 20 2008
Vic in NY
Lockport,NY
I am:
  • Technically Challenged
Reviewed at:
Price: $234.99
Nice system, horrible instructions
4.0
    Pros
  • Clear Sound
    Cons
  • Difficult To Setup
    Best Uses
  • Living Room
  • Movies
"Thus far I have used this system solely for DVD's and it has not dissapointed. Can't wait for football season.
I bought this setup (this system and a 40' Bravia LCD) to use primarily as a secondary TV & for XBOX360 and my "play room/man land" (I'm afraid of screen burn in on my plasma TV). Game …"  Read Full Review »
Jul 3 2008
AWR
Chicagoland
I am:
  • Tech Savvy
Reviewed at:
Price: $429.00
GREAT SYSTEM!!!
4.0
    Pros
  • Clear Sound
  • Thundering Bass
    Cons
    Best Uses
  • Living Room
  • Movies
  • Surround Sound Solution
"Just got this system for Christmas. The only con was that it took approx 4hrs to set it up. However, once installed it performed as I hoped it would. Great sound - great BASS!! I LOVE the S-Air wireless. Fits perfectly on my desk and looks great. Turn on a radio channel on the TV and then turn …"  Read Full Review »
Dec 29 2008
I am:
  • Practical
Very Good Cheaper Surround Sound Option
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Thundering Bass
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Television Shows
"I havent really looked into all the features of this Surround Sound yet but so far my only complaint is that I dont think this system has any way of manually adjusting the sound levels. Would be nice to be able to turn down the Bass every now and again while watching tv. Has very good sound and is e …"  Read Full Review »
Dec 15 2008
Raptor_118
Pueblo Colorado
I am:
  • Tech Savvy
Worth the price paid
4.0
    Pros
  • Clear Sound
    Cons
  • Needs better bass
    Best Uses
  • Living Room
  • Movies
  • Television Shows
"Sound is good, only bass is weak. Surround sound doesn't work in all "decoding modes". You have to change the decoding mode depending on the source of the audio. More of an inconvenience than anything else. Otherwise the system works fine and sounds decent. Better sound will cost more. "
May 24 2009
Imagecrafter
Vernon, CT
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $234.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$234.99
No Tax Outside NY
$429.00
$229.99
$243.00
$244.99
$244.99
$248.00
$249.99
$269.98
$269.99
$271.99
BizRate Rating Outstanding 9.0
$284.99
$289.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$299.97
$299.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$299.99
Code KMART5OFF50 : Save $5 off $50 with coupon
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
