Sony Black 4.8" Portable Satellite Navigation System
4.0
based on 28 reviews
Ratings Distribution
5 star
15
4 star
6
3 star
3
2 star
1
1 star
3
Category Average
4.1
More Images
Pros
  • Large clear lcd (15)
  • Acquires satellites quickly (12)
  • Easy to read (12)
  • Easy menus (11)
  • Easy setup (11)
  • Reliable (10)
  • Simple controls (9)
  • Compact (8)
See less See more
Cons
  • Inaccurate (3)
  • Poor battery life (3)
  • Flimsy mounting (2)
  • Acquires satellites slowly (1)
  • Bad directions (1)
  • Bluetooth is crackly (1)
  • Difficult menus (1)
  • Don't recalculate detours (1)
  • Heavy / bulky (1)
  • Lacks driving style pick (1)
Best Uses
  • Urban navigation (8)
  • Finding specific address (7)
  • Rural navigation (7)
  • Planning trips (6)
  • Faster routes (3)
  • Nearest desired location (1)
Provided by Abt Electronics
Sony Black 4.8" Portable Satellite Navigation System - NVU94T/ Anti-Glare And Anti-Fingerprint Touchscreen Display/ Pre-Installed Maps Of USA Canada And Puerto Rico/ Dual View/ Audio-Video Playback/ Bluetooth Hands-Free Calling With Built-In Microphone/ Photo Viewer/ Supports Memory Stick Duo Media/ Car Cradle/ Super Suction Cup Mount/ Black Finish
Specification Description
Model NV-U94T, NVU94T
UPC 027242740051
2D/3D view Yes
Antenna Internal
Anti-glare Yes
Auto routing/rerouting Yes
Battery Average Run Time 2
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Vibrant 4.8" touchscreen display gives you control via onscreen finger movementsDual view capability displays dynamic route informati
Cables Included USB cable
Capacity UOM mAh
Color support Yes
Connections USB (1)DC input (1)External aerial input (1)TMC aerial input (1)
Connections USB (1)External antenna (1)TMC antenna (1)
Country Of Origin China
Description Header Step away from standard GPS mapping.
Description Header Step up from standard GPS mapping.
Display Catalog Number 20-364
Display Catalog Number 20-379
Display size (diagonal) 4.8 inches
End Product Indicator Yes
Expandable Memory Memory Stick Duo
External antenna connection Yes
Features POSITION plus™ monitors your position relative to the map, so you don't worry about losing your wayRealtime traffic information
GPS type Car
Hands-free calling capability Yes
Included in the Box Sony NV-U94T navigation systemTMC car cradleTMC antennaVehicle battery adapterUSB cableQuick star
Manufacturer Labor Warranty 12
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps U.S.,Canada & Puerto Rico
Maps United States, Canada and Puerto Rico
Max Operating Temperature 113 Fahrenheit
Menu navigation Touchscreen
Min Operating Temperature 41 Fahrenheit
Model NV-U94T
Mounting options Windshield, console or dashboard
New Date Mon Jan 05 00:00:00 CST 2009
Operating Temperature UOM ° F
Other features Text-to-speech, RDS-TMC capable, dual-view 3D junction guide, Bluetooth hands-free calling
Photo viewer Yes
Power Device Vehicle adapter, USB cable
Product Depth 0.8
Product Depth 5.9
Product Dimensions UOM inches
Product Disclaimer 1.Interoperability and compatibility among Bluetooth® devices varies. 2.Subscription for traffic information is required and sold separately. Cove
Product Height 0.8
Product Height 3.4
Product Type Car
Product Weight 8.8
Product Weight UOM ounces
Product Width 3.4
Product Width 5.9
Recharge Time 3
Recharge Time UOM HOURS
Rechargeable Yes
Resolution 480x272
Size Specialty
Spoken street names Yes
Subtitle Online and in-store order only
Supported Languages English
Touchscreen Yes
Traffic/Weather Yes
Type LCD
Updatable Maps Yes
Uploadable Maps Memory Stick Duo
Voice Guidance Yes
Sony Black 4.8" Portable Satellite Navigation System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Black 4.8" Portable Satellite Navigation System
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 7, 2009
Sony Black 4.8" Portable Satellite Navigation System Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Best GPS bought so far
"HELLO; Im a profesional truck driver by trade.This is my 3rd brand gps system.And to tell you the truth,this is one of the easiest units that i used.I didnt even have to read the manual to get started.this unit is very acurate as to get you to the address your going to.very easy to program the destinations.great screen,vivid color,my sony hasnt steered me wrong yet.its easliy removed from the mount with the push..." Read Full Review »
Jan 29, 2009 by candywrapper
See more positive Sony Black 4.8" Portable Satellite Navigation System reviews
1.0
buy something else to find your way
"I bought this u94t after trying to buy the garmin 360 (when it was on sale). the garmin wound up being out of stock, so i went for this one because it was really close in price and it had the features that i wanted. I really wanted a gps that had bluetooth capability so i could use it as speaker phone in my car. the good: This unit has a large screen. I have no trouble seeing anything on the screen. It doe..." Read Full Review »
Jan 03, 2009 by drwx
See more negative Sony Black 4.8" Portable Satellite Navigation System reviews
Displaying 1 - 5 of 28 Reviews
Show
Sort by
1.0
    Pros
  • Acquires Satellites Quickly
  • Large Screen
    Cons
  • Inaccurate
  • POI system sucks
  • Poor directions
    Best Uses
  • None
"I bought this u94t after trying to buy the garmin 360 (when it was on sale). the garmin wound up being out of stock, so i went for this one because it was really close in price and it had the features that i wanted. I really wanted a gps that had bluetooth capability so i could use it as speaker p …"  Read Full Review »
Was this Car GPS review on the Sony Black 4.8" Portable Satellite Navigation System helpful to you?
Jan 3 2009
drwx
nashville, tn
I am:
  • Casual User
Reviewed at:
Great Looks, some Poor Function
3.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Inaccurate
  • Poor Route Determination
  • Short Battery Life
    Best Uses
  • Nearest Desired Location
  • Planning Trips
  • Rural Navigation
"Rural LocationsFast to find routes, accurate routes, easy to pick up new directions from missed turns.Populated locations (experienced in Minneapolis/St. Paul), directions to on-off ramps and transfers happened too slowly. More direct routes using logic was vastly superior (Eden Prairie ramps to th …"  Read Full Review »
Jan 30 2009
John the Driver
Waterloo, IA
I am:
  • Casual User
Reviewed at:
Sony GPS Is No Garmin
1.0
    Pros
  • Large Screen
    Cons
  • Difficult Menus
  • Inaccurate
    Best Uses
  • None
"I usually really like Sony products and played with this unit in the store enough to get a feel for the menues and controls. It was pricey at [$], but when it went on sale for [$] at R.S. after Christmas [...]I bought it. In actual use this unit falls way short of my expectations and lacks many of t …"  Read Full Review »
Dec 29 2008
Dont88
Kettering, OH
I am:
  • Enthusiast
Reviewed at:
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Speaker needs improvement
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"HELLO;
Im a profesional truck driver by trade.This is my 3rd brand gps system.And to tell you the truth,this is one of the easiest units that i used.I didnt even have to read the manual to get started.this unit is very acurate as to get you to the address your going to.very easy to program the dest …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 29 2009
candywrapper
Celina, Ohio
I am:
  • Power User
Reviewed at:
Great unit for the good price!!
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Flimsy Mounting
    Best Uses
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"I have looked at GPS units for a while and got NV-U94T mainly because of the screen size 4,8”; Bluetooth connection; All the play MP3; MP4; JPEG list; Memory stick slot and after all it is made by SONY and the price is [$].There is many nice GPS units on the market, I have talked to people at work a …"  Read Full Review »
Jan 8 2009
Big Bear
New York
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
