Sony BDV-E500W Blu-ray Disc Home Theater System
4.4
based on 10 reviews
Ratings Distribution
5 star
4
4 star
6
3 star
0
2 star
0
1 star
0
Category Average
4.1
$599.00 - $799.99
from 6 stores
More Images
Pros
  • Easy setup (7)
  • Clear sound (5)
  • Interfaces well with tv (4)
  • Thundering bass (4)
  • Confusing / difficult controls (3)
  • Attractive design (2)
  • Great sound (2)
  • Powerful (2)
  • Simple / intuitive controls (2)
  • Elegant (1)
See less See more
Cons
  • Unattractive design (1)
Best Uses
  • Movies (5)
  • Living room (4)
  • Surround sound solution (3)
  • Audiophiles (2)
  • Basic use (2)
  • Larger rooms (2)
  • Smaller rooms (1)
  • Television shows (1)
Provided by OneCall
Blu-ray Disc and DVD playback
Combination Blu-ray Disc and DVD playback capabilities enable you to enjoy the latest Blu-ray offerings while still enjoying your DVD collection from a single playback device. Satellite front speakers, center channel, surround speakers and a subwoofer complete the 5.1 channel surround sound home theater system.2
S-AIR™ Wireless surround sound
S-AIR Wireless surround sound is provided with the included WAHT-SA10 wireless surround receiver enables the system to deliver room-filling surround sound without the hassle of custom installation or running speaker wires across the room.5
Full HD 1080p video output
Full HD 1080p video output provides high-resolution HD image so you can take full advantage of your HDTV and the detail of Blu-ray Disc™ video content. BD/DVD/CD and AVCHD™ playback plays your favorite Blu-ray Disc™ movies, DVDs, Audio CDs, and AVCHD-format discs.2
BD-Live™
BD-Live technology brings you the next generation of interactivity, allowing you to download and stream bonus content such as additional scenes, shorts, trailers, movie-based games, and more.3
DVD upscaling via HDMI™
DVD upscaling via HDMI™ makes your existing standard DVDs look better on your HDTV by upscaling them to near HD quality.6
Dolby® TrueHD decoding and DTS®-HD master audio
The system decodes enhanced audio codecs, including Dolby® TrueHD and dts®-HD Master Audio. These high definition audio formats deliver “lossless” surround sound with up to 7.1 channels of discrete audio allowing you to enjoy excellent sound from the comfort of your living room.7
xross media bar™ menu navigation
Sony's exclusive xross media bar™ user interface offers you a simple and intuitive way to navigate your Blu-ray Disc™ player’s menus, controls, and user settings.
Easy set-up DVD : Easy set-up DVD and a one page guide, gives basic speaker set-up instructions and simple connection options.
S-AIR™ Multi-room ready
S-AIR Digital Wireless multi-room technology ready, with the addition of the S-AIR Station allows you to CD-quality audio from S-AIR capable BRAVIA® Theatre systems to up to ten compact, plug-and-play Air Station (AIR-SA10 sold separately) S-AIR receiver/speaker systems.5
iPod® Cradle included for Digital Media Port
Allows the use of an iPod® (not supplied) digital player via a built in Digital Media Port. The Digital Media Port allows you to connect compatible digital devices directly to the system so you can enjoy content stored on your Sony® Walkman® player, iPod, PC, mobile phone or other compatible digital devices. (All sold separately)4
1000 Watts of power
With 1000 watts RMS ( 143x5 +285 Subwoofer) of power you receive the most from the included speakers and subwoofer.8
Ethernet port
Ethernet port provides connectivity to a home broadband connection for network updates and BD-Live™ access. (External memory (sold separately) is required.3
BRAVIA® Sync™
BRAVIA Sync capability utilizes the HDMI™ CEC function easily turn on and control your compatible HDMI- connected components.1
Footnotes:
1. Works with other BRAVIA® Sync™ or Theatre Sync™ labeled home audio/video products when connected via HDMI cable (sold separately) .
2. Certain circumstances may limit/prevent Blu-ray Disc™ media or DVD playback. Requires HDTV for high definition playback with 1080p and HDMI cable (sold separately).
3. Requires external memory (sold separately) and internet access (broadband recommended). Firmware update may be required.
4. iPod® support is limited based upon which optional Digital Media Port is being used. The unit will support the following players: iPod® touch, iPod® classic, iPod® Nano 1st, 2nd & 3rd generation, iPod® 4th& 5th generation & iPod® Mini. The optional TDM-IP50 adds iPhone™ support as well.
5. Transmits up to 164 feet. Signal and sound quality may vary.
6. Upscaling requires HDTV with HDMI connector (sold separately) and equivalent display capability. Image quality will vary.
7. HDMI™ cable required (sold separately)
8. Measurements are at 3ohms, 20Hz-20KHz, with a THD of 10%
9. 1080p playback requires HDMI™ connector (sold separately) and compatible HDTV with 1080p display capability. Upscaled image quality will vary. Certain circumstances may limit/prevent Blu-ray Disc™ media or DVD playback.
Specification Description
Model BDV-E500W, BDVE500W
UPC 027242763623
Analog Audio (2) Rear Input
Built-in DVD Player Blu-ray Player
Compatible Formats AVCHD
Compatible Formats BD-R
Compatible Formats BD-RE
Compatible Formats BD-ROM
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+R DL
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-R DL
Compatible Formats DVD-RW
Compatible Formats JPEG
Component Video (1) Rear Output
Composite Video (1) Rear Output
Disc Player Blu-Ray Player
HDMI (1) Rear Output
Headphone Jack Yes
Magnetic Shielding Yes
Main Features Blu-Ray Player
MP3 or iPod Connectivity iPod Dock included
Optical (1) Rear Input
Play Modes Surround (5.1 Channels)
Speakers 5 Satellites + Subwoofer
Surround Modes DTS
Surround Modes DTS 96/24
Surround Modes DTS ES
Surround Modes DTS-HD
Surround Modes Dolby Digital
Surround Modes Dolby Pro Logic II
Surround Modes Dolby Pro Logic IIx
Surround Modes Dolby TrueHD
Tuner AM
Tuner FM
Sony BDV-E500W Blu-ray Disc Home Theater System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Sony BDV-E500W Blu-ray Disc Home Theater System Reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Great Blu-ray home theater
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Elegant design
  • Intuitive Controls
  • Thundering Bass
    Cons
  • No problems so far
    Best Uses
  • Living Room
  • Movies
"This system looks great in my living room. The wireless system for the rear speakers is just amazing compared to other products on the market (no background noise). I particularly liked the setup process and the calibration method for the speakers. Great product at a great price. "
Was this Home Theater review on the Sony BDV-E500W Blu-ray Disc Home Theater System helpful to you?
Nov 8 2009
Serg
New York, NY
I am:
  • Movie Enthusiast
  • Practical
Reviewed at:
Price: $599.00
Everything I expected and more
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Thundering Bass
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Surround Sound Solution
"I use the Sony system for everything, including TV, radio, movies, I-pod, and Wii. System sounds superb with movies, especially thos with ample bass. Setup was a piece of cake. "
Nov 16 2009
Special K
Greenville, SC
I am:
  • Movie Enthusiast
  • Practical
  • Professional
Reviewed at:
Price: $599.00
Nice little system for the price
4.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Movies
  • Smaller Rooms
  • Television Shows
"Using the system in a smaller room. It works very well for that purpose. The sound quality is quite acceptable. Setup was easy and having built in wireless satellite speakers was a plus. "
Sep 19 2009
EdwardL
Dallas,TX
I am:
  • Tech Savvy
Reviewed at:
Price: $629.98
[1 of 1 customers found this review helpful]
Great HTIB
4.0
"Picked this unit 4 days back, it was the only one in the store. The guy gave me a good discount. Anyway, setup was easy, I didn't even need the setup DVD. The Autocallibration works great, I had read some issues about the rear wireless S-air having problems, I did not face any. worked from the word …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 2 2009
SJMinSFO
SFO
Reviewed at:
Price: $699.99
[1 of 2 customers found this review helpful]
Love the Sound
4.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Use
  • Larger Rooms
"I use this to listen to music, TV, DVDs, BDs, etc. It was easy to set up and use. It sounds great! "
 Report Abuse  (1)  (1)  0 comments
Oct 1 2009
Elman
Atlantic City, NJ
I am:
  • Audiophile
  • Movie Enthusiast
  • Practical
Reviewed at:
Price: $599.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
