Sony BDP-S5000ES Blu-ray Disc Player
#20
4.6
based on 8 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.2
$1,179.00 - $1,599.00
from 7 stores
More Images
Pros
  • Build quality (2)
  • Dvd upconversion (2)
  • Good connections (2)
  • Good soundtrack support (2)
  • Great picture quality (2)
  • Upgradeable (2)
See less See more
Cons
  • Limited remote (2)
  • Slow load time (2)
  • Power select 220v110v (1)
  • Usb to a pc (1)
Best Uses
  • Home theater (2)
Provided by OneCall
HD Reality Enhancer/ Super Bit Mapping®
By analyzing every pixel of the video coming off the disc the player can automatically adjust the picture and enhance it to provide the optimum Image Quality. These two components of This player’s chipset allows for reference quality video playback and quality.
Isolated Audio Circuit Board and High Quality Parts
By keeping the Audio Circuit Board separate from other circuitry interference from the video processor and other components is mitigated and can be kept clean. The high quality parts of the player allows for uncompromising performance.
Rigid Beam Chassis & Dual Shield Construction
The combination of Frame and Beam increases rigidity and controls the fundamental resonant frequency of the frame panels.
Dolby TrueHD® and dts® HD- 7.1 Analog output & bitsteam out over HDMI™
In the past most audio codecs used compression that actually removes some sound data to transmit audio from the disc to the audio circuitry. This means that what you hear is a subset of the original audio. While this was very good we still lost some of the audio. Newer formats allow the Audio to be compressed but not discarded. This means that once the audio is decoded the original audio can come through. This player allows you to stream the audio out via HDMI(tm) to a Capable receiver or through analog 7.1 outputs for maximum compatibility with high end receivers.
RS-232C & IR Input for Flexible Custom Installation
By having an RS-232C and IR Inputs this player can work with a wide range of Sony and other third party custom integration solutions.
R-Core Transformer
Because of the unique design of this transformer it has an inherently low radiated hum and noise ratio as compared to other types of transformers. This translates to a better power supply for creating cleaner and better sound.
Specification Description
Model BDP-S5000ES, BDPS5000ES
UPC 027242745513
Analog Audio Rear Output
Compatible Formats BD
Compatible Formats BD-R
Compatible Formats BD-ROM
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats JPEG
Component Video Rear Output
Composite Video Rear Output
Depth (Inches) 14.4
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
HDMI Rear Output
Height (Inches) 4.9
Multi-Channel 7.1 Channel Output
Optical Rear Output
Remote Control Included
RJ45 Ethernet Yes
RS-232C Yes
S-Video Rear Output
Surround Modes DTS
Surround Modes DTS-HD
Surround Modes Dolby Digital
Surround Modes Dolby Digital Plus
Surround Modes Dolby TrueHD
Type of DVD Unit Blu-Ray
Video Standard Up to 1080p High Definition
Weight (Pounds) 22
Width (Inches) 17
Sony BDP-S5000ES Blu-ray Disc Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 21, 2009
Sony BDP-S5000ES Blu-ray Disc Player Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
[237 of 245 customers found this review helpful]
Finally!
5.0
"Finally a blueray player that feels like a finished product. Stellar video performance was a given before and still is a hallmark. Finally Sony has gotten around to include all the high definition audio codecs. The previous BDPs2000es was deceptive in their marketing regarding high definition audio …"  Read Full Review »
Was this Blu-Ray Player review on the Sony BDP-S5000ES Blu-ray Disc Player helpful to you?
 Report Abuse  (237)  (8)  0 comments
Nov 26 2008
WISED
Wisconsin
Reviewed at:
Price: $1,499.99
[25 of 30 customers found this review helpful]
Best Blu Ray player...period!
5.0
"I just got my BDP-S5000es yesterday. I had been using Sony's original BDP-S1 in our home theater and have enjoyed its picture and audio quality for the past 2 years. I have auditioned other Blu-ray players including the Pioneer Elite series, but never really saw or heard any clear cut reason to spe …"  Read Full Review »
 Report Abuse  (25)  (5)  0 comments
Nov 21 2008
M. Skop
Norcross, GA United States
Reviewed at:
Price: $1,499.99
[14 of 14 customers found this review helpful]
Finally a Bluray player that meets the hype
5.0
"This player is the promise of Bluray fully delivered. As before, video is spectacular. Audio is spectacular in every codec as well. DTS master audio (not included in previous sony products except PS3)and Dolby HD are fantastic. The internal decoding and full bandwith 7.1 PCM output is a great plus f …"  Read Full Review »
 Report Abuse  (14)  (0)  0 comments
Nov 26 2008
Edgar Betancourt
WI
Reviewed at:
Price: $1,499.99
Blu-ray technology, Sony ES style
5.0
    Pros
  • Build quality
  • DVD Upconversion
  • Excellent Image Quality
  • Good Connections
  • Good Soundtrack Support
  • More »
    Cons
  • Limited remote
  • Slow Load Time
    Best Uses
  • Home Theater
"I've been waiting a long time for Sony to build a truly high-end ES Blu-ray deck to add to my existing Sony ES stack (scd-xa777es, dvp-s9000es, str-da777es), and they finally did it.
I've only had this deck for a few weeks at this point, but so far my wife and I are really loving it! The video/a …"  Read Full Review »
Jul 21 2009
slingshot
Silicon Valley, CA
I am:
  • Enthusiast
5.0
    Pros
  • Build quality
  • DVD Upconversion
  • Good Connections
  • More »
    Cons
  • Limited remote
  • Slow Load Time
    Best Uses
  • Home Theater
"I've been waiting a long time for Sony to build a truly high-end ES Blu-ray deck worthy of being added to my existing Sony ES stack (scd-xa777es, dvp-s9000es, str-da777es), and they finally did it.
I've only had this deck for a few weeks at this point, but so far my wife and I are loving it! The …"  Read Full Review »
Jul 20 2009
slingshot
silicon valley, CA
I am:
  • Enthusiast
Reviewed at:
Price: $1,499.00
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
