Sony BDP-S500 Blu-ray Disc Player
4.6
based on 182 reviews
from $144.99 - $199.99
Ratings Distribution
5 star
137
4 star
32
3 star
5
2 star
5
1 star
3
Category Average
4.2
More Images
Pros
  • Easy setup (106)
  • Great picture quality (96)
  • Good connections (83)
  • Dvd upconversion (76)
  • Good soundtrack support (67)
  • Backwards compatible (51)
  • Upgradeable (40)
  • High quality picture (20)
  • Easy to use (16)
  • Consistent performance (14)
See less See more
Cons
  • Slow load time (28)
  • Difficult set-up (2)
  • Difficult to use (2)
  • Cost (1)
  • Does not load vcd (1)
  • Doesn't come w hdmi cable (1)
  • Flimsy (1)
  • Horrendous load time (1)
  • I like it (1)
  • Inconsistent (1)
Best Uses
  • Home theater (73)
  • Lcd tv (64)
  • Home (63)
  • Plasma tv (25)
  • Dlp tv (12)
  • Office (3)
  • Dorm room (2)
  • High volume usage (2)
  • Any tv (1)
  • Great for bravia lcd (1)
Provided by OneCall
Full HD 1080p
Full HD 1080p video output1 provides high-resolution HD image, so you can take full advantage of the superior detail of Blu-ray Disc™ video content.
DVD Upscaling
DVD Upscaling via HDMI™ gets the most out of your existing DVD collection by upscaling standard definition video to near HD 1080p resolution.
7.1 channel analog output
7.1 channel analog output provides connectivity to older receivers, making the player compatible with your existing audio system with 7.1 analog inputs.
Dolby® TrueHD internal decoding
Dolby® TrueHD internal decoding and bitstream output via HDMI™ for the Dolby TrueHD and dts®-HD (Master Audio and High Resolution Audio) codes delivers studio quality audio designed specifically for high definition entertainment like Blu-ray Disc™ movies, with up to 7.1 channels of surround sound that is virtually indistinguishable from the original studio version.
Design
Slim chassis with a gloss black finish fits elegantly with your home theater system and décor, and the included backlit remote helps give you total control of the movie-watching experience.
Ethernet port
Ethernet port provides connectivity to a home network with broadband connection so you can download network updates and bonus content.
BD-Live
BD-Live technology allows you to download and stream bonus content such as additional scenes, shorts, trailers, movie-based games, and more.
24p True Cinema
24p True Cinema capable4 provides a direct connection to 24p video display devices so you can avoid conversions and enjoy films at their intended 24 fps (frames per second) cinematic picture quality.
BRAVIA® Sync for Theatre
BRAVIA® Sync for Theatre technology utilizes the industry-standard HDMI™ CEC function to provide one button access and control of the appropriate inputs for your BRAVIA HDTV and HDMI-connected A/V components.
Precision Cinema
Precision Cinema HD Upscale circuitry uses high bandwidth digital-to-analog conversion and processing to detect image changes at the pixel level, rather than at the level of whole scan lines. Additionally, separate algorithms are used to process the moving and still parts of an image, resulting in sharper backgrounds with moving objects that are nearly free from motion artifacts.
Specification Description
Model BDP-S500, BDP-S550, BDPS500, BDPS550
UPC 027242723788
Analog Audio (1) Rear Output
Analog Audio / Video Rear Output
Coaxial (1) Rear Output
Color Blue
Compatible Formats BD
Compatible Formats BD-R
Compatible Formats BD-RE
Compatible Formats BD-ROM
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats JPEG
Component Video (1) Rear Output
Composite Video (1) Rear Output
D/A Converter 24-bit/192kHz
Depth (Inches) 14.2
Depth (Inches) 8.75
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Not Applicable
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Not Applicable
DVD Dual Layer Play Compatible Yes
DVD Dual Layer Record Compatible Does not Record
HDMI (1) Rear Output
Height (Inches) 2.75
Height (Inches) 3.9
Manufacturer’s Warranty 1 Year
Multi-Channel (1) 5.1 Channel Output
Multi-Channel 7.1 Channel Output
Optical (1) Rear Output
Power Supply 110 Volts AC
Remote Control Included
RJ45 Ethernet Rear Output
S-Video (1) Rear Output
S-Video Rear Output
Scanning Modes Progressive Scan
Select DVD Players
Surround Modes DTS
Surround Modes DTS-HD High Resolution
Surround Modes Dolby Digital
Surround Modes Dolby Digital Plus
Surround Modes Dolby TrueHD
TV Broadcast Compatibility NTSC
Type of DVD Unit Blu-Ray
Video Conversion to HDMI (1080p)
Video Standard Up to 1080p High Definition
Weight (Pounds) 10.5
Weight (Pounds) 7.25
Width (Inches) 16.9
Width (Inches) 17
Sony BDP-S500 Blu-ray Disc Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 10, 2009
Sony BDP-S500 Blu-ray Disc Player Reviews
Most helpful positive review
[18 of 18 customers found this review helpful]
Most helpful negative review
[5 of 9 customers found this review helpful]
4.0
BDP-S550 Pros & Cons
"Pros My Sony BDP-S550 Blu-Ray Disk player from Dell arrived last night, and I had it connected via HDMI to my Sony STR-G720 AV Receiver in less than 5 minutes after taking the player out of the box. My receiver then connects via HDMI to my Sony 52 inch LCD TV. The Sony AV receiver has "active" HDMI ports so it can act on the signals coming in. I then popped in my fist Blu-Ray disk - Miami Vice - and started enj..." Read Full Review »
Jan 22, 2009 by MysteryWriter
See more positive Sony BDP-S500 Blu-ray Disc Player reviews
2.0
How is Bluray Winning?
"I just need to first say this: How is it that BluRay is winning the format war? I understand that they have most of the major Hollywood studios under their belt, but their technology seems so far behind HD-DVD. I proudly express myself as a gadget guru, and have to have all the new technology as it comes out. Because of this, I own an Integra DHS 8.8 HD-DVD player, and this, Sony BDP-S500. What really kills..." Read Full Review »
Feb 01, 2008 by Appelguy
See more negative Sony BDP-S500 Blu-ray Disc Player reviews
Displaying 1 - 5 of 182 Reviews
Show
Sort by
4.0
"Pros
My Sony BDP-S550 Blu-Ray Disk player from Dell arrived last night, and I had it connected via HDMI to my Sony STR-G720 AV Receiver in less than 5 minutes after taking the player out of the box. My receiver then connects via HDMI to my Sony 52 inch LCD TV. The Sony AV receiver has "active" HDMI …"  Read Full Review »
Was this Blu-Ray Player review on the Sony BDP-S500 Blu-ray Disc Player helpful to you?
 Report Abuse  (18)  (0)  0 comments
Jan 22 2009
MysteryWriter
New Jersey
Reviewed at:
Price: $179.99
[27 of 27 customers found this review helpful]
Excellent but one glitch
4.0
"I've really enjoyed the incredible picture produced by this player both with Blu-ray and DVD media. The player itself is rock solid. Menus and navigation are easy. I have made some button errors on the remote because of the double-ring layout - hitting the outer ring instead of the inner - but this …"  Read Full Review »
 Report Abuse  (27)  (0)  0 comments
Jan 13 2009
JKirk
Undisclosed
[24 of 28 customers found this review helpful]
Sony BDP-S550 Blue Ray Disc Player
5.0
"Pros
Beautiful picture. This player also upgrades picture quality of regular DVDs much more than I had anticipated. Set up was easy and we have had no problems understanding controls, etc.
Cons
Sony includes only a RCA cable in the box. (this provides the lowest grade of picture.) Think they coul …"  Read Full Review »
 Report Abuse  (24)  (4)  0 comments
Jan 6 2009
JudiM
Chicago, IL
Reviewed at:
Price: $179.99
2.0
    Pros
  • Contemporary Design
  • High Quality Picture
    Cons
  • Difficult To Use
  • Flimsy Construction
  • Horrendous Load Time
  • Inconsistent
    Best Uses
  • Home
"I just need to first say this: How is it that BluRay is winning the format war? I understand that they have most of the major Hollywood studios under their belt, but their technology seems so far behind HD-DVD. I proudly express myself as a gadget guru, and have to have all the new technology as …"  Read Full Review »
 Report Abuse  (5)  (4)  0 comments
Feb 1 2008
Appelguy
Lake Geneva, Wisconsin
I am:
  • CEDIA Certified
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
Price: $169.00
[16 of 17 customers found this review helpful]
Great Player at a Premium price
5.0
"This player is terrific, even though some of the advanced features (such as BD LIve) are kind of pointless and shouldn't factor into your decision, the quality of the player is impeccable (as expected from a Sony product). Setup was a breeze with all menus and options being very intuitive and easy t …"  Read Full Review »
 Report Abuse  (16)  (1)  0 comments
Dec 14 2008
Tshirt
Columbus, OH
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
