Sony BDP-S300 1080p Blu-ray Disc Player
4.1
based on 40 reviews
Ratings Distribution
5 star
21
4 star
9
3 star
5
2 star
3
1 star
2
Category Average
4.2
More Images
Pros
  • Easy setup (24)
  • High quality picture (22)
  • Easy to use (16)
  • Consistent performance (13)
  • Durable (6)
  • Great picture quality (6)
  • Dvd upconversion (4)
  • Good connections (4)
  • Backwards compatible (2)
  • Good soundtrack support (2)
See less See more
Cons
  • Inconsistent (4)
  • Slow load time (4)
  • Slow start-up (2)
  • Slow to boot up (2)
  • Difficult to use (1)
  • Disk tray a little flimsy (1)
  • Doesn't always work (1)
  • Firmware upgrade not cool (1)
  • Locks up now and then (1)
  • Long loading time (1)
Best Uses
  • Home (21)
  • Home theater (3)
  • Office (2)
  • Any (1)
  • Conferencetraining room (1)
  • Dorm room (1)
  • High volume usage (1)
  • Lcd tv (1)
  • Movies (1)
  • Plasma tv (1)
Provided by Sears
See and hear a whole new world in high-definition with the BDP-S300 from Sony. The crystalline clarity of 1080p Blu-ray Disc" movies - combined with DVD upscaling that can bring your DVDs to their highest possible quality - mean your favorite movies have never looked or sounded so good. Add to that Sony's 24p True Cinema and Cinema Tuned picture presets, and you'll be watching your favorite movies just the way the director intended - just like you were at the theater. All you'll need is a little popcorn, and you'll lose yourself in an HD world.
Specification Description
Model BDP-S300, BDPS300, BDPS300SM
UPC 027242243941
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Not Applicable
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Not Applicable
DVD Dual Layer Record Compatible Does not Record
Manufacturer’s Warranty 1 Year
Power Supply 110 Volts AC
Scanning Modes Progressive Scan
Select DVD Players
TV Broadcast Compatibility NTSC
Type of DVD Unit Blu-Ray
Video Standard Up to 480p
Sony BDP-S300 1080p Blu-ray Disc Player Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: BDP-S300 1080p Blu-ray Disc Player
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 25, 2009
Sony BDP-S300 1080p Blu-ray Disc Player Reviews
Most helpful positive review
[10 of 10 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Very Good Blu-ray Player For Money
"First thing I did before watching any dvd, I went to esupport sony and downloaded the latest firmware (a software patch...blu-ray players run Java) update for the unit. The firmware is an iso image that you burn to cd or dvd. Firmware upgrades can add additional features and improve performance of the player. Pop your new firmware cd/dvd into the player and it self-installs in about 20-30 mins. Anyway, I got the..." Read Full Review »
Nov 15, 2007 by Anonymous
See more positive Sony BDP-S300 1080p Blu-ray Disc Player reviews
2.0
VERY, VERY slow
"I work for the Computer Art Department at a large university in Manhattan. We bought this player to replace a broken DVD player in our presentation room, and have had to return it because of how SLOW it is. It takes upwards of 30 seconds for this player to start up. In that time you can't put the disc in, so you're looking at a minimum of one minute before you can get an image on screen. Compounding this problem..." Read Full Review »
Jul 14, 2008 by Chad von Nau
See more negative Sony BDP-S300 1080p Blu-ray Disc Player reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
VERY, VERY slow
2.0
    Pros
  • Easy Set-Up
    Cons
  • Slow Load Time
    Best Uses
  • Office
  • Plasma TV
"I work for the Computer Art Department at a large university in Manhattan. We bought this player to replace a broken DVD player in our presentation room, and have had to return it because of how SLOW it is. It takes upwards of 30 seconds for this player to start up. In that time you can't put the di …"  Read Full Review »
Was this Blu-Ray Player review on the Sony BDP-S300 1080p Blu-ray Disc Player helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jul 14 2008
Chad von Nau
New York, NY
I am:
  • Professional
Reviewed at:
5.0
"First thing I did before watching any dvd, I went to esupport sony and downloaded the latest firmware (a software patch...blu-ray players run Java) update for the unit. The firmware is an iso image that you burn to cd or dvd. Firmware upgrades can add additional features and improve performance of t …"  Read Full Review »
 Report Abuse  (10)  (0)  0 comments
Nov 15 2007
Undisclosed
Reviewed at:
[8 of 9 customers found this review helpful]
Excellent pictures, incredibly slow machine
2.0
"The 300 makes great pictures, if you have the patience towatch the player go through its boot-up procedure. FromPower On to Tray Open takes minutes, loading the BD-DVDtakes minutes more. Very frustrating. Another frustration isthe to-date lack of an firmware upgrade to HDMI 1.3 specs.The set-up GUI …"  Read Full Review »
 Report Abuse  (8)  (1)  0 comments
Dec 31 2007
-shs-
Los Angeles, CA
Reviewed at:
Blue Ray has sharp details!
3.0
Super Informative
Super Informative
    Pros
  • Durable
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • No memory
  • Slow power up
    Best Uses
  • Home
"Great design gives it a sleek look. When turning it on, it takes longer than a minute for the tray to open up. I have heard this before so it may be common for these types of DVDs. With the HDMI connection, the picture is very sharp! I definitely noticed a difference in DVDs to HD Blue Rays.
Disa …"  Read Full Review »
Jan 13 2008
drasticv
Toluca Lake, CA
I am:
  • Tech Savvy
Reviewed at:
[2 of 2 customers found this review helpful]
Sony Blu-Ray - worthy expense to upgrade
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Great Picture
  • Upscaling to 1080p
    Cons
  • Slow to boot up
    Best Uses
  • Movies
"After waiting out the battle over Blu-Ray vs HD-DVD I decided to take the plunge and upgrade my Sony 5-disk DVD player for Blu-Ray. My first movie was Flags of our fathers. WOW! Rocked my socks off. I still have my older 32-bit Sony 5.1 Sound system with a optical connection to my Blu-Ray - even tha …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 16 2007
RobertS
Seattle,WA
I am:
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
