Sony 7.1 Channels 100 watt per channel - STRDA4300ES
4.0
based on 3 reviews
Ratings Distribution
5 star
0
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.3
More Images
Pros
  • Good power (3)
  • Accurate controls (2)
  • Clean sound (2)
  • Durable (2)
  • Easy setup (1)
See less See more
Cons
  • Difficult to set up (2)
Best Uses
  • Home theater (3)
  • Smaller rooms (1)
Provided by OneCall
The STR-DA4300ES 7.1 A/V receiver will accept 1080/60p and 24p HD video formats, x.v.Color(TM) (xvYCC) and Deep Color while providing 3 HDMI(TM) connections. Sony's Digital MEDIA Port makes this model iPod(R) Ready (accessory sold separately) and features BRAVIA(R) Theater Sync technology for One-Touch Play. Don't worry, we haven't forgotten about audio; the receiver is also capable of reproducing the latest audio formats from Dolby Labs(R) (Dolby Digital +/Dolby TruHD) and dts(R) (dts(R) High Resolution Audio and dts(R) HD Master Audio).
Optimized for Blu-ray Disc and Other HD Sources
The STR-DA4300ES is engineered to be the ideal Blu-ray Disc(R) A/V receiver, fully compatible with Sony(R) family of Blu-ray Disc Players. Superior video switching and audio performance ensure seamless compatibility with today's demanding HD sources. The STR-DA4300ES features up to three High Definition Multimedia Interface (HDMI(TM)) inputs which are capable of accepting resolutions up to 1080p, offering the full video quality that Blu-ray Disc(R) format can deliver.
Up to 8 channels of Linear PCM audio plus Dolby TruHD and dts HD
The STR-DA4300ES will offer full compatibility with Blu-ray Disc(R) format's linear PCM (uncompressed) output, producing up to eight channels of high quality audio reproduction. The STR-DA4300ES will also have the ability to support the latest audio formats from Dolby Labs(R) (Dolby Digital Plus/Dolby TruHD) and dts(R)(dts HD).
HDMI Active Intelligence
The receiver can detect and receive the best possible video and audio signals from all connected devices-making connection and performance as simple as plugging in a single wire. Sony's HDMI Active Intelligence, produces both audio and video through one HDMI cable.
Faroudja DCDi CINEMA Chipset for Up Scaling to 1080p
IC processor developed by Faroudja(R), and first used by Sony, which will up scale and up convert all video signals (less than 1080p) to 1080p via HDMI3. This chipset corrects image jaggedness; reduces block noise and reproduces true to original colors. The end result is a beautiful and smooth High Definition image.
Cross Media Bar Inspired Graphic User Interface
An on-screen menu system that simplifies the most complex operations of an A/V receiver for home theater applications. This advanced menu system incorporates icons, an easy to follow tree system and a blending technique so users know exactly where they are amongst the various settings while still watching their main video source (up to 1080i). Enhancements made to this year's menu include access to Digital MEDIA Port accessories, the ability to assign HDMI inputs and independent A/V Sync control for each input. It's simple. Just pick up the remote and whole new experience will be revealed.
HDMI Up Scaling
Video sources connected via composite and component cables can not only be up converted to a HDMI(TM) video output but can also be up scaled from its native signal to 1080p (i.e. 480i to 1080p) thus minimizing the number of connections needed from the receiver to the television Display. HDMI supports resolutions up to 1080p and enables both HD video and uncompressed streaming audio to be transmitted through a single cable.
Digital Cinema Auto Calibration
An ideal listening experience is only a button away. Simply place the included microphone in your listening position, push a single button and speaker position, distance and delays are automatically calibrated. Sony's Digital Signal Processing uses feedback between the microphone and receiver to optimize sound settings.
Sirius and XM Connect-and-Play Ready with Neural Surround
A world of Digital radio at your fingertips. Connect the optional antenna for either Sirius and/or XM subscription service and enjoy the variety and quality of Digital radio with the superior sound quality of an A/V receiver. In addition to stereo, you can enjoy 5.1 surround broadcasting. XM radio is a satellite radio service that provides pay-for-service radio, analogous to cable television.
Portable Audio Enhancer
The ES 7.1 A/V Receivers are ideal for today's portables. A powerful Digital Signal Processor expands the quality of sound from any connected device. Simplified front-side audio and video connections make it easy to play portables through the receiver.
HDMI Output with 720P/1080i and 1080p upscaling of DVD Media
Reads the data on a standard DVD at 480P and maximizes the video Resolution to best fit your HDMI compatible TV. The STR-DA4300ES takes it a step further and allows for DVD Media to be upscaled to 1080p. Overall, this allows for you to enjoy the best in video performance while delivering Digital video and audio over one simple cable.
Precision Cinema Progressive Technology
Many other DVD players detect image changes at the Scan line level-Sony's Precision Cinema Progressive (PCP) system detects them at the Pixel level. The picture is more faithful to the source-whether film or video-because separate, optimized algorithms are used to handle the differing Pixel behavior. Separate algorithms are also used to process the moving and still parts of an image, resulting in sharp backgrounds with moving objects that are virtually free from motion artifacts.
Specification Description
Model STR-DA4300ES, STRDA4300ES
UPC 027242715127
12V Trigger (1) Rear Output
12V Trigger (3) Rear Input
Analog Audio (2) Rear Output
Analog Audio (5) Rear Input
Coaxial (3) Rear Input
Color Black
Command / Control (1) IR Output
Command / Control (2) IR Input
Component Video (1) Rear Output
Component Video (3) Rear Input
Composite Video (1) Front Input
Composite Video (2) Rear Output
Composite Video (4) Rear Input
Depth (Inches) 17
DMP (Digital Media Port) (1) Rear Input
Frequency Response 20 - 20,000 Hz
HDMI (1) Rear Output
HDMI (3) Rear Input
HDMI Version 1.3
Headphone Jack (1) Front Output
Height (Inches) 7
iPod Integration Yes
Monitor Output (1) Composite Video
Monitor Output (1) S-Video
Multi-Channel (1) 7.1 Channel Input
Multi-Room/Multi-Source Yes
Optical (1) Front Input
Optical (2) Rear Output
Optical (4) Rear Input
Remote Control Full Function Remote Control
Remote Control Remote Commander
RS-232C (1) Rear In/Out
Speaker Switching A+B
Speaker Switching A/B
Stereo Power Rating 100 Watts x 2
Subwoofer Preamplifier (1) Rear Output
Surround Modes DTS
Surround Modes DTS 96/24
Surround Modes DTS ES
Surround Modes DTS NEO:6
Surround Modes DTS-HD
Surround Modes Digital Cinema Sound
Surround Modes Dolby Digital
Surround Modes Dolby Digital EX
Surround Modes Dolby Pro Logic
Surround Modes Dolby Pro Logic II
Surround Modes Dolby Pro Logic IIx
Surround Modes Dolby TrueHD
Surround Power Rating 100 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
Video Conversion to HDMI
Weight (Pounds) 34.18
Width (Inches) 17
Sony 7.1 Channels 100 watt per channel - STRDA4300ES Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 7.1 Channels 100 watt per channel - STRDA4300ES
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 14, 2008
Sony 7.1 Channels 100 watt per channel - STRDA4300ES Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Very Impressed wMy Upgrade to 4300ES
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Smaller Rooms
"This amp is an upgrade to my previous mid-level ES Sony amp (I don't have the model #), same wattage, only up to 7 channels. Overall, I am pleased with the upgrade, which I did to accommodate an HDMI connection to my new projector.
The bass response is much better than the previous amp ,which te …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sony 7.1 Channels 100 watt per channel - STRDA4300ES helpful to you?
Oct 14 2008
Mighty Jack
San Francisco, CA
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Performs all tasks as advertised
4.0
    Pros
  • Durable
  • Good Power
    Cons
  • Difficult To Set Up
    Best Uses
  • Home Theater
"Performs everything very well, though the volume display is hard to see when you are more than 5 feet away. One thing, which may be true with other HDMI receivers is that when you have HDMI connected and you turn on another HDMI device the sound cuts out for 5 - 10 seconds as the unit "recognizes" …"  Read Full Review »
Oct 13 2008
Pete
Ohio
I am:
  • Tech Savvy
Reviewed at:
Nice receiver
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Good Power
    Cons
    Best Uses
  • Home Theater
"I purchased this receiver because most of the other components I had were already Sony and wanted to keep everything consistent. My previous receiver was an Onkyo which I still feel was a bit higher-end than Sony's are. That being said, this receiver does produce nice sound. My only negative is t …"  Read Full Review »
Oct 7 2008
JZ
Phoenix, AZ
I am:
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
