Sony 7.1-Channel Home Theater Receiver - STR-DA4400ES
#88
4.4
based on 7 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.3
$949.99 - $1,299.99
from 5 stores
More Images
Pros
  • Accurate controls (4)
  • Durable (4)
  • Good power output (4)
  • Easy setup (3)
  • Great sound quality (3)
See less See more
Cons
  • Difficult to set up (1)
Best Uses
  • Home theater (4)
  • Large rooms (3)
  • Audiophiles (1)
  • Basic systems (1)
  • Smaller rooms / apartments (1)
Provided by OneCall
Want to watch your favorite HD programming in another room of your home? The STR-DA4400ES continues Sony`s heritage in providing an ES AV Receiver that will distribute high definition content to a 2nd room of the home. Its multi-room capabilities don`t stop with HD; this model also can distribute audio to up to 3 rooms!
These multi-room features are accompanied by custom control connections (i.e. RS-232C, 12 volt triggers and IR In/Out) necessary for full home integration. Now, you can start a HD movie in the living room and finish it in the bedroom or listen to your favorites songs from your iPod player, Walkman player or PC (accessories sold separately), located in the living room, on the patio in the backyard.
The STR-DA4400ES ES 7.1 Channel AV Receiver utilizes Sony`s xross media bar™ inspired GUI with Faroudja DCDi Cinema® Technology that can upscale all video sources to 1080p in an intuitive environment for even the most novice of AV enthusiast. Additionally, it will be able to reproduce the latest audio formats from Dolby® Labs (Dolby Digital +/Dolby TrueHD) and dts® (dts HD/dts High Resolution Audio). In true ES fashion, this model incorporates new audio technology by having the ability to decode Direct Stream Digital (DSD) audio sources.
So, the abundant HDMI™ connections (6 Inputs) provide ample room to incorporate a SACD Player with a HDMI output (SACD Player sold separately). It is fully compatible with 1080 60p/24p, Deep Color and x.v.Color video signals. Finally, the STR-DA4400ES features BRAVIA® Sync™ for Theater with "One Touch" control, DIGITAL MEDIA PORT input for use with MP3 portable players or personal computer (accessories sold separately) and is compatible with XM® and Sirius Satellite Radio® making this unit completely SAT Ready.
Specification Description
Model STR-DA4400ES, STRDA4400ES
UPC 027242732124
12V Trigger Yes
2:2 Pulldown Receiver Call-In Special
Analog Audio (5) Rear Output
Analog Audio (8) Rear Input
Analog Audio / Video (1) Front Input
Analog Audio / Video (3) Rear Output
Analog Audio / Video (4) Rear Input
Audio Inputs 5
Channels 7.1
Coaxial Digital Input 3
Color Black
Component Video (2) Rear Output
Component Video (3) Rear Input
Component Video Input 3
Component Video Output 2
Depth (Inches) 16.9
HDMI (1) Rear Output
HDMI (6) Rear Input
HDMI Yes
Headphone Jack Front Output
Height (Inches) 6.75
Multi-Channel 7.1 Channel Input
Multi-Channel 7.1 Channel Pre-Out
Multi-Room Rear Output
Multi-Room/Multi-Source Yes
On Screen Display Yes
Optical (5) Rear Input
Optical Digital Input Yes
Optical Digital Output 2
Phono Rear Input
Preamplifier Outputs 7.1 Channels
Radio Frequencies AM FM and Sirius or XM Option
Radio Station Programmable Memories (Presets) 30
Remote Control Included
RS-232C Rear Input
Satellite Radio Sirius Satellite Radio Ready
Satellite Radio XM Radio Ready
Speaker Switching A+B
Speaker Switching A/B
Speaker Terminals 5-Way Binding Post
Surround Modes DTS
Surround Modes DTS 96/24
Surround Modes DTS NEO:6
Surround Modes Digital Cinema Sound
Surround Modes Dolby Digital
Surround Modes Dolby Digital EX
Surround Modes Dolby Digital Plus
Surround Modes Dolby Pro Logic
Surround Modes Dolby Pro Logic IIx
Surround Power Rating 120 Watts x 7
Tuner AM
Tuner FM
Tuner Sirius Satellite Radio Ready
Tuner XM Radio Ready
Type of Receiver Home Theater Surround
Video Inputs 3
Watts per channel 120
Weight (Pounds) 33
Width (Inches) 16.9
Sony 7.1-Channel Home Theater Receiver - STR-DA4400ES Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 27, 2009
Sony 7.1-Channel Home Theater Receiver - STR-DA4400ES Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Amazing Receiver!!!
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"This is a great receiver, it was easy to setup and, with the included auto calibration, it was great to be able to plug it in and go (I always like going in afterword and fine-tuning some of the settings anyway, but it is good for ease of initial setup). I only had 2 issues with it. Every now and …"  Read Full Review »
Was this Amplifier, Receiver & Equalizer review on the Sony 7.1-Channel Home Theater Receiver - STR-DA4400ES helpful to you?
 Report Abuse  (1)  (0)  0 comments
Dec 1 2008
Evan the Tech Guru
Temple, TX
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $949.99
Simply the BEST Reciever for the money..
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
"The graphical setup was a breeze and made it simple to view and change any parameter. The unit sounds fantastic and comes with a five year warranty. This was a replacement for a STR-DA50ES that I purchased 12 years ago. Sony ROCKS! "
Nov 12 2008
Blade Runner
Redding, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $949.99
Integrates well with Sony TV & Blue Ray
4.0
    Pros
  • Accurate Controls
  • Durable
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"This receiver is a really good bang for your buck. Yes there are better ones out there, but not with the same amount of features. Plus, if you are already running Sony Gear, the single remote is nice. "
Apr 6 2009
Joshman
PDX
I am:
  • Practical
Reviewed at:
Price: $949.99
Great sound and easy connectivity
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"Just updaded all my equipment in my home theater to all use HDMI connectivity and this product makes it a breeze to set up. "
Nov 26 2008
Harley Jeff
Northbrook, IL
I am:
  • Technically Challenged
Reviewed at:
Price: $949.99
[1 of 2 customers found this review helpful]
Solid Receiver
4.0
    Pros
  • Good Power
    Cons
  • Difficult To Set Up
    Best Uses
  • Basic Systems
"A good receiver from Sony. HDMI seems to have been an afterthought--very little description of HDMI in manual. "
 Report Abuse  (1)  (1)  0 comments
Mar 8 2009
Chuck R
Houston, TX
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $949.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
