Sony 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black
4.8
based on 13 reviews
from
Ratings Distribution
5 star
11
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Attractive design (5)
  • Great sound quality (5)
  • Powerful (5)
  • Easy setup (3)
  • Simple / intuitive controls (3)
  • Quality you can feel (2)
  • Best ever built (1)
  • Best for the money (1)
  • Does it all (1)
  • Huge sound (1)
See less See more
Cons
  • No surround sound ability (1)
Best Uses
  • Large rooms (5)
  • Audiophiles (4)
  • Office (3)
  • Smaller rooms / apartments (2)
  • Basic use (1)
  • Does it all (1)
  • Living room main stereo (1)
  • Main living room system (1)
Provided by Beach Audio
Big sound for any room in the house with Sonys LBT-ZX6 Mini Hi-Fi System. With 560 Watts, split between 2 channels, the LBT-ZX6 allows you to set the night to music, or entertain your guests while you reminisce about the good old days. The LBT-ZX6 features a 3-way speaker design as well as Sonys Variable Attenuation Control Design (VACS) circuitry system, which provides low midrange and bass distortion when listening at high volumes. A 5 disc changer allows you to rotate your 5 favorite CDs of the moment while the 10 Preset EQ with 2 Band Direct AV EQ lets you create the perfect acoustic environment for your listening pleasure. Other features include a color fluorescent display for function illumination and a Remote Commander remote control for convenient unit operation. And in case you still fancy a few of your old tapes, the LBT-ZX6 features dual Full Logic cassette decks.
FEATURES
  • 560 Watts Total 280 Watts Per Channel x 2 (FTC 10% THD, 120-10kHz, 6 Ohms)
  • 3 Way Main Speakers with 6-3/4" (17cm) Woofer, 6-3/4" (17cm)Mid Range and 1" (2.5cm) Horn Tweeter
  • Variable Attenuation Control System (VACS) Sony has designed an exclusive circuit that maintains bass and midrange quality in high volume listening. VACS detects frequencies and levels that may introduce distortion and adjusts them automatically to ensure consistent sound quality.
  • Mic Input with Volume Control
  • 5 Disc CD Changer with Play Exchange
  • 5 Band Spectrum Analyzer
  • Game Sync" Mixing with Front A/V INPUTS for Video Games
  • Personal EQ File (1)
  • Color Fluorescent Display
  • CD Synchro Recording
  • Remote Commander Remote Control for remote operation of the LBT-ZX6.
  • Power Save Mode
  • CD Text
  • Play Modes (Shuffle, Program, Repeat)
  • Play Exchange Mode
  • 10 Preset EQ with 2 Band Direct AV EQ
  • Surround Audio Effect
  • 320 Watts Total 280 Watts Per Channel x 2 (FTC 10% THD, 120-10kHz, 6 Ohms)
  • Tuner with 20 FM + 10 AM Station presets
  • Center Volume Knob with Illumination
  • Function: CD, Tuner, Tape A & B, Game, Video (MD)
  • Dual Well Auto Reverse Tape Deck
  • AMS Function (Tape)
  • X-Groove" Bass Enhancement
    Specifications
    FM Stereo FM/AM Superheterodyne Tuner
    Audio
    Frequency Range FM 87.5-108.0 MHz
    AM 530-1710 kHz
    Inputs and Outputs
    Analog Audio Input(s) x3
    Analog Audio Output(s) x1
    Optical Audio Output(s) x1
    Antenna Terminal(s) FM & AM Inputs
    Composite Video Input(s) x1
    Composite Video Output(s) x1
    Microphone Input x2
    Headphone output(s) x1 (Large)
    Power
    Power Requirements AC 120V, 60 Hz
    Weight
    Unit 39 lbs. 11 oz.(18 Kg)
    Speakers (2) 18 lbs. 12 oz (8.5 Kg)
    Dimensions (W x H x D)
    Unit 14-1/4" x 17-1/5" x 18-4/13" (362 x 437 x 465mm)
    Speakers (2) 9-11/13" x 20-13/15" x 14-1/4" (250 x 530 x 362mm)
    Supplied Accessories
    Items Instruction Manual
    Remote Commander for remote operation of the LBT-ZX6
  • Specification Description
    Model HSSO6, LBT-ZX6, LBTZX6
    UPC 027242680807
    Disc Player CD Player - Changer
    Main Features CD Player / Radio / Cassette
    Play Modes Stereo (2 Channels)
    Radio Bands AM/FM
    Speakers 2
    Sony 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Mar 5, 2009
    Sony 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black Reviews
    Displaying 1 - 5 of 13 Reviews
    Show
    Sort by
    [10 of 11 customers found this review helpful]
    Sound Away !
    5.0
    "Been searching for a decent shelf hi-fi stereo system since my archaic one failed to function anymore.
    Did much time on researching for certain specifications, like disc changer, cassette component, etc.
    Although, other name brands were less expensive, I decided to purchase a Sony brand due to its r …"  Read Full Review »
    Was this Shelf System review on the Sony 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black helpful to you?
     Report Abuse  (10)  (1)  0 comments
    Oct 9 2007
    b4ever
    New York, NY
    Reviewed at:
    sony zx6 mini hifi stereo
    5.0
      Pros
    • Attractive Design
    • Best ever built
    • Does it all
    • Huge Sound
    • Powerful
    • More »
      Cons
    • NONE
      Best Uses
    • Audiophiles
    • Larger Rooms
    • Offices
    • Smaller Rooms
    "excellent design powerful sound. Best in class for mony at any price, A MUST OWN! Does it all.due to replace old unit to this one. this is an awsome system considering price. This is one of four Sony stereo of this refinement. Once you see how nice it is you'll be glad you got it. but the performanc …"  Read Full Review »
    Jul 16 2008
    BUCK
    MUNCIE, INDIANA
    I am:
    • Audiophile
    • Musically Inclined
    • Practical
    • Tech geek retired
    • Tech Savvy
    Reviewed at:
    [1 of 1 customers found this review helpful]
    ZX6 Sony Stereo
    5.0
      Pros
    • Amazing Sound
    • Attractive Design
    • Powerful
    • Top notch quality
      Cons
    • NONE
      Best Uses
    • Audiophiles
    • Does it all
    • Larger Rooms
    • Offices
    "I've seen a lot of stereo systems. But a select few make the grade excellent design performance.The price may seem high but when you experiance this totally cool stereo it is a bargin. The feel and quality of this unit is above most others but a few. Its powerful sound will astound you. Simply WOW D …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jul 17 2008
    BUCK
    MUNCIE, INDIANA
    I am:
    • Audiophile
    • Practical
    • Professional
    • Tech geek retired
    • Tech Savvy
    Reviewed at:
    Kicks Butt!!!
    5.0
    "We checked out several systems b/4 we purchased this one and even bought the 360watt model first and returned it. None compared to the sound and features not to mention the options of the ports for connecting everything. We had a hard time finding a shelf system these days that has hook ups for the …"  Read Full Review »
    Sep 17 2008
    LuvIt
    Greensburg PA
    Reviewed at:
    Sony LBT-ZX6 - WOW - WOW- WOW -
    5.0
      Pros
    • Attractive Design
    • Easy Controls
    • Easy To Set Up
    • Fantastic sound
    • More »
      Cons
    • None
      Best Uses
    • Larger Rooms
    "I'm a musical purest for top quality sound. I like to listen to music loud and distortion free. The LBTZX6 provides this. Excellent system. Nothing out there in it's class compares. "
    Mar 5 2009
    Fireman Rich
    Livermore , CA.
    I am:
    • Audiophile
    • Practical
    • Professional
    • Tech Savvy
    Reviewed at:
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
