Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black
4.8
based on 30 reviews
Ratings Distribution
5 star
27
4 star
2
3 star
0
2 star
1
1 star
0
Category Average
4.4
More Images
Pros
  • High resolution (28)
  • Attractive design (27)
  • Good connection options (27)
  • Fast setup (26)
  • Bright image (25)
  • Reduced glare (23)
  • Simple controls (21)
  • High quality (2)
  • Amazing color (1)
  • Easy setup (1)
See less See more
Cons
  • Pricey (3)
  • Non hd channels only ok (1)
  • Zero (1)
Best Uses
  • Home (24)
  • Movies (21)
  • Video (13)
  • Basement theater room (1)
  • Blu-ray (1)
  • Gaming (1)
  • Tv (1)
  • Watching football (1)
  • Watching ice hockey (1)
Provided by OneCall
Over the years XBR has stood for the best consumer TVs Sony has to offer and this year's line up is no exception. The XBR line of Full HD 1080p televisions incorporate all of Sony's latest technologies (including HDMI v1.3 features such as x.v.Color and Deep Color). Additional features like Motionflow(TM) 120Hz enable smoother motion when viewing movies or fast-action sports. BRAVIA Engine PRO with Digital Reality Creation upconverts all interlaced and progressive video signals including HD signals directly to 1080p for amazing detail and sharpness. And it's only fitting that your XBR make a statement not only through breathtaking picture quality, but by taking your breath away with optional color bezels. Now your LCD TV can be as distinct as your own personal style.
Full HD 1080
There are a lot of ways to define high-definition but BRAVIA(R) Full HD means you`re getting the best resolution that high-definition has to offer consumers. With Sony BRAVIA XBR HDTVs, Full HD 1080 means 1920 x 1080 pixels5 and 1080p video inputs. Your lifestyle demands the best in high-definition and with BRAVIA Full HD 1080 products you get it.
1920 x 1080 Panel Resolution
When it comes to high-definition TV the pinnacle of performance is achieved by using 1920 x 1080 display panels. And BRAVIA XBR televisions have them. Full HD 1920 x 1080 panel resolution with over 2 million pixels 5(more than twice that of 720p HDTV) is exactly what you need to reproduce the 1080p content that can be delivered by our cutting edge 1080p Blu-ray disc(TM) player. And working with BRAVIA Engine(TM) PRO everything from standard definition and high definition is upconverted to 1080p for a picture so real it`s like you`re actually there.
10-bit Processing and 10-bit Display
While it's great to state that a TV is capable of creating billions of colors it's a whole lot better when you have a display that can actually display them. That's the logic behind Sony's 10-bit processor and 10-bit display. Sony follows 10-bit processing with a 10-bit panel, allowing 64 times the levels of color expression than an 8-bit panel. What that translates to is smoother transitions from color to color and subtle color changes faithfully reproduced. (Found on select Sony BRAVIA televisions.)
Motionflow 120 Hz with Full HD high frame rate capability
Achieving smoother, natural motion reproduction starts with the right performance characteristics such as the ultra fast panel response times our BRAVIA(R) HD LCD TVs have. Taking motion performance to the next level requires innovation and expertise. Enter Sony's Motionflow(TM) High Frame Rate technology. Motionflow doubles the amount of frames from 60fps to 120fps and does it the right way by using real-time calculation of every single frame of video to create entire new frames of information. The results are spectacular and unlock a new level of motion reproduction. Motion performance is smooth and natural.
BRAVIA Engine PRO Full Digital Video Processor
Presenting the next evolution of the BRAVIA Engine(TM) BRAVIA Engine(TM) PRO. Sony improved on the great benefits of the BRAVIA Engine(TM) by adding a picture quality enhancement circuit called Digital Reality Creation Multi-function v2.5. DRC-MFv2.5 now has the added ability to process interlace and progressive video signals and because it has twice the processing power of previous DRC-MF circuits, it can do its processing and output them to 1080p. (Native 1080p input signals are not processed through DRC-MFv2.5.) Add to this the crisp details, outstanding contrast, eye popping colors, and dramatically reduced digital artifacts that DRC-MF circuitry is known for. And the best part of all is that DRC-MFv2.5 is user adjustable according to the video source. All of this helps define the reason why people want Sony TVs to begin with unparalleled picture quality.
Live Color Creation System featuring WCG-CCFL
Decades of television know how allow us to realize that an LCD TV is more than just the panel; it`s actually a system. Uncompromised picture quality starts with combining carefully chosen components and circuits to optimize system quality, among these are the color creation and processing functions. That`s what Live Color Creation is all about. It starts with the BRAVIA Engine(TM) PRO video processing system, which enhances primary colors and corrects half-tone colors for natural overall color. Next, a WCG-CCFL backlight using Sony`s phosphor formula delivers a specific spectrum of lightdesigned to work with our specially formulated color filters. The combination of these three components creates deep, deep blues and natural greens for overall colors that draw you right into the picture.
Advanced Contrast Enhancer (ACE) Function
Sony`s Advanced Contrast Enhancer (ACE) builds on our excellent on-contrast ratio performance of 2000:11. A Dynamic Contrast Ratio of up to 18,000:12 is achieved by using real-time image processing to adjust the contrast along with optimizing backlight levels. But rather than focus on the numbers, Sony focuses on actual picture performance avoiding exaggerated blacks where detail can be lost. ACE translates to blacker blacks in darker scenes, as well as better shadow detail in other scenes for a difference that you can see.
x.v.Color technology
BRAVIA(R) HDTV's performance has now advanced to the point that the color range can be defined by limitations in the original video source, rather than the TV. Thanks to the adoption of a newly approved international color standard called xvYCC (an option in the HDMI v1.3 spec and which Sony participated in creating), the color space has been greatly expanded. 1.8 times as many natural colors as existing HDTV signals will now be faithfully reproduced. x.v.Color(TM) is the name Sony has chosen to promote video products that include xvYCC capability. x.v.Color enabled products can now offer more accurate color reproduction and natural colors.
24p True Cinema (24p Input Capability)
Many movies are filmed at 24 frames per second (fps) and prime time TV programs are video taped at 24p. Seizing on an opportunity, some studios are taking a purist approach and encoding high definition video content such as Blu-ray Disc(TM) in 24p. Sony wisely takes advantage of this by including 24p output capability on their BDP-S1 Blu-ray Disc player. It makes sense that select 2007 BRAVIA TVs will include 24p input capability. The benefit? Images are smooth and natural looking. Once you experience 24p video it will be hard to view video without it.
DMex - Ready (Digital Module Extender)
Sony's Digital Media Extender (DMex) ready televisions offer a digital connection path for the addition of the optional modules like the new BRAVIA Internet Video Link. 6 With innovative DMex expansion capabilities featuring the Emmy(R) award winning XMB user interface, select 2007 models are not merely TVs, but powerful entertainment platforms that not only meet your needs today, but expand easily to meet tomorrow's needs as well.
Xross Media Bar(R) (XMB) interface
When was the last time you saw an on-screen display that was fast, fun and easy to use? Sony's award-winning Xross Media Bar(TM) (pronounced Cross) provides a logical and fast way to access set up menus, user controls, and more. The on-screen display comes to life by pushing the XMB menu button on the remote. Navigation through the menus is smooth and fast.
Specification Description
Model KDL-52XBR4, KDL52XBR4
UPC 027242717404
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (4) Rear Input
Aspect Ratio 16:9
Compatible Furniture or Stand RHT-G800
Compatible Furniture or Stand SU-FL300L
Component Video (2) Rear Input
Composite Video (1) Side Input
Composite Video (2) Rear Input
Contrast Ratio 2,000:1
Contrast Ratio 2000:1
DB15 (PC Video) (1) Rear Input
Depth (Inches) 4.92
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Headphone Jack (1) Side Output
Height (Inches) 32.56
Optical (1) Rear Output
PC Audio (1) Rear Input
Refresh Frequency 120 Hz
Remote Control Illuminated Full Function
Resolution 1920 x 1080
S-Video (1) Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 50" to 60"
Screen Size (inches) 52
Screen Size (Inches/Diagonal) 52
Select LCD Units
Speakers Built-in
Stand Pedestal
Stereo Modes MTS Stereo with SAP
Surround Modes Dolby Digital
Surround Modes S-Force Front Surround
Tuner ATSC
Tuner NTSC
Tuner QAM
TV Manufacturer’s Warranty (Labor) 1 Year
TV Manufacturer’s Warranty (Parts) 1 Year
Viewing Angle 178 degrees Horizontal
Wall Mountable VESA Compliant
Weight (Pounds) 93
Width (Inches) 55.71
Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 52" BRAVIA XBR LCD Flat Panel HDTV In Black
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 2, 2008
Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Great Choice for Flatscreen
"I purchased the Sony KDL-52XBR4 approximately one month ago. It is a phenomenal set and I highly recommend it. The TV is connected to a DirectTV HD satellite receiver as well as a Sony Blu Ray DVD player. The picture is clear and crisp with an HD source. I watched the Masters and it was better than being there. The HD picture is so sharp that you can see the slope, contours and grain of the putting green. Watchi..." Read Full Review »
May 20, 2008 by John
See more positive Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black reviews
2.0
Could be better!
"The picture is great when the full screen is bright and there aren't any dark scenes. However, the picture seems to have some bright lights (clouds coming from all corners) when viewing dark scenes or wathcing movies with widescreen bars at top and bottom. I have tried 2 now, and neither one of them has meet my expectations. ABT has been great to deal with and I would recommend them for sure when looking to buy ..." Read Full Review »
Dec 27, 2007 by Sean
See more negative Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black reviews
Displaying 1 - 5 of 30 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"I purchased the Sony KDL-52XBR4 approximately one month ago. It is a phenomenal set and I highly recommend it. The TV is connected to a DirectTV HD satellite receiver as well as a Sony Blu Ray DVD player. The picture is clear and crisp with an HD source. I watched the Masters and it was better than …"  Read Full Review »
Was this LCD TV review on the Sony 52" BRAVIA XBR LCD Flat Panel HDTV In Black helpful to you?
 Report Abuse  (2)  (0)  0 comments
May 20 2008
John
Wisconsin
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
No regrets, would do it again
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"I had done some serious in store and online shopping for flat screen tv's. Soon it became apparent some features were more important to me than price. I quickly concluded the flat screen needed to be LCD vs plasma due to possibility of screen reflections. 1080p and 120hz refresh rates became importa …"  Read Full Review »
Sep 1 2008
Tom
Moses Lake, WA
I am:
  • Practical
Reviewed at:
Best Purchase i have made in a long time
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Movies
"I can't think of anything bad about the product. I went back and forth between plasma and LCD for months and the 2 things that swayed me was 1) the LCD picture was brighter and better and 2) LCDs use approximately 1/2 the electricity that plasmas use which in my case was a difference of around $100 …"  Read Full Review »
May 19 2008
Bruce
Houston, TX
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Could be better!
2.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"The picture is great when the full screen is bright and there aren't any dark scenes. However, the picture seems to have some bright lights (clouds coming from all corners) when viewing dark scenes or wathcing movies with widescreen bars at top and bottom. I have tried 2 now, and neither one of them …"  Read Full Review »
Dec 27 2007
Sean
Memphis, TN
I am:
  • Tech Savvy
Reviewed at:
Premium LCD TV
5.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Great Picture
    Cons
  • ZERO
    Best Uses
  • Home
  • Movies
  • TV
"Wasn't too sure about buying a demo unit from anywhere. Let alone having it shipped from 3000 miles away. But alas, what a fabulous TV. Arrived in like new condition. I already have a kdl 40XBR4 here at home and was so impressed, thought I'd find out if bigger really is better. In this case it i …"  Read Full Review »
Jul 29 2008
BossHammer
Great Pacific Northwest
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
