Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W
4.4
based on 91 reviews
from $254.00
Ratings Distribution
5 star
49
4 star
33
3 star
3
2 star
5
1 star
1
Category Average
4.1
$254.00 at CompSource
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great sound quality (14)
  • Easy setup (11)
  • Interfaces well with tv (9)
  • Confusing / difficult controls (5)
  • Thundering bass (5)
  • Attractive design (2)
  • Powerful (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Difficult to set up (2)
  • Unattractive design (1)
Best Uses
  • Movies (11)
  • Living room (8)
  • Surround sound solution (6)
  • Television shows (6)
  • Smaller rooms / apartments (4)
  • Basic use (2)
  • Large rooms (2)
  • Music (1)
Provided by OneCall
The Sony(R) DAV-HDX275 BRAVIA(R) Theater System includes an integrated 5 DVD/CD changer, 1000 watts of home theater power, and an included iPod(R) Dock. With the optional S-AIR(R) receiver/speakers system, you can now easily send your music wirelessly to another room in your home. Using exclusive Sony(R) Technology, S-AIR(R) brings the promise of multi room audio distribution that most anyone can set-up, it's that easy. DAV-HDX275 comes equipped with DIGITAL MEDIA PORT that works with various accessories (sold separately). The DAVHDX275 can control a select number of BRAVIA(R) televisions with BRAVIA(R) Sync via the HDMI(TM) interface. With One Touch Play, operations that took several steps have been reduced to one. Also, HDMI(TM) interface upscales DVD media up to 1080p This BRAVIA(R) System optimizes speaker placement in just 30 seconds with Digital Cinema Auto Calibration.
HDMI(TM) Output with 1080p upscaling of DVD Media
Reads the data on a standard DVD at 480p and upscales the video resolution up to 1080p resolution for your compatible HDTV. This allows for you to enjoy superb video performance while delivering digital video and audio over one simple cable.
BRAVIA(R) Sync(TM)
As a leader in products with HDMI connectivity, Sony has created BRAVIA(R) Theater Sync(TM) technology to go beyond simple audio and video transmission. When combined with a select number of BRAVIA(R) LCD televisions and other Sony audio and video products, control functions will also be transmitted via the HDMI cable. With One Touch Play operations that took several steps have been reduced to one. Press the PLAY button on the remote, watch the audio and/or the video component(s) turn on then the BRAVIA(R) television will turn on and switch to the correct video input...Simple...Easy...BRAVIA(R) Theater Sync(TM)
DIGITAL MEDIA PORT
As the demand for digital content continues to be strong, here's the challenge: how do you integrate music in various forms into a home theater system– The answer: Sony`s DIGITAL MEDIA PORT (DMP). Together with one of the DMP accessories (sold separately), this proprietary interface adds networking and connectivity to the options of home theater systems and components, connects with various devices which provide the ability to control and power devices while making set up easy and operation simple. The DMP accessories will include a PC Client device, Bluetooth(R) receiver and Audio Docking Stations compatible with Network Walkman(TM) and iPod(R) products. So regardless of how you store your music, Sony`s DIGITAL MEDIA PORT offers an access point to integrate your portable music into a traditional home theater system.
Now the optimal speaker settings for your living room are only a press of button away. Simply place the included microphone in your listening position and allow the strength of Sony`s Digital Signal Processing to take over. Speaker placement, distance, and delays are all calibrated automatically to ensure a worry free listening experience.
Portable Audio Enhancer
Simplified front audio and video connections are part of what makes the DAV-DX265 ideal for today`s portables. Beyond the simplified connection a powerful Digital Signal Processor is used to expand the quality from any device that is connected.
Multi Speaker Formation
Select from the on screen display to configure the system for different speaker layout.
Music/Movie Mode
System automatically adjusts sound characteristics to match the source (movie vs. music).
Specification Description
Model DAV-HDX275
UPC 027242727670
Analog Audio Rear Input
Built-in DVD Player Yes
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+R DL
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats DVD-VR
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats SACD
Compatible Formats VCD
Component Video Rear Input
Composite Video Rear Input
D/A Converter 12-bit/108MHz
Disc Capacity 5
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
Disc Player DVD Player - Changer
DMP (Digital Media Port) Rear Input
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Yes
DVD Dual Layer Record Compatible Does not Record
HDMI Rear Output
Headphone Jack Rear Input
Main Features DVD Player / Radio
MP3 or iPod Connectivity iPod Dock included
Multi Disc Capacity 5
Multi-Disc Resume 40
On Screen Display Yes
Optical Rear Input
Play Modes Surround (5.1 Channels)
Progressive Scan Yes
Radio Bands AM/FM
Speaker (4) Satellite
Speaker Bass Reflex
Speaker Center Channel
Speaker Subwoofer
Speakers 5 Satellites + Subwoofer
Subwoofer 8 Inch
Subwoofer Bass Reflex
Surround Modes Dolby Digital
Surround Modes Dolby Pro Logic II
Timer Modes Clock and Timer Modes
Tuner AM
Tuner FM
Type of DVD Unit Component DVD Player
Video Standard Up to 1080p High Definition
Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 5, 2009
Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[49 of 62 customers found this review helpful]
5.0
Awesome
"This product has treated me incredibly well. I have my 19" Magnavox LCD monitor (a little small, but good for this room), and a Comcast HD/DVR receiver hooked onto it. The sound on DVD's is fantastic, and is movie theater quality (well, comparatively so). It was a breeze to set up. The first time I did it, the calibration microphone was intuitive and simple to handle. I have since moved and can't find the micro..." Read Full Review »
Jul 08, 2008 by jetlite
See more positive Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W reviews
2.0
Still Undecided
"Review My son-in-law set this system up for me, and he's good at this stuff. But I can never tell if the system is on or not and having just read the manual, it appears that if I want to listen to my TV from all the speakers, I need an audio cord which was not supplied. Other things that weren't supplied are a digital optical cord, HDMI cable and a component video card. I bought this system because it was recomm..." Read Full Review »
Jul 28, 2008 by Anonymous
See more negative Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W reviews
Displaying 1 - 5 of 91 Reviews
Show
Sort by
Still Undecided
2.0
"Review
My son-in-law set this system up for me, and he's good at this stuff. But I can never tell if the system is on or not and having just read the manual, it appears that if I want to listen to my TV from all the speakers, I need an audio cord which was not supplied. Other things that weren't sup …"  Read Full Review »
Was this Home Theater review on the Sony 5-Disc DVD/CD Home Theater System with 1080p Upconversion, 1000W helpful to you?
 Report Abuse  (49)  (13)  0 comments
Jul 28 2008
San Antonio
Reviewed at:
[48 of 61 customers found this review helpful]
Still Undecided
2.0
"Additional Thoughts
My son-in-law set this system up for me, and he's good at this stuff. But I can never tell if the system is on or not and having just read the manual, it appears that if I want to listen to my TV from all the speakers, I need an audio cord which was not supplied. Other things th …"  Read Full Review »
 Report Abuse  (48)  (13)  0 comments
Jul 28 2008
San Antonio
Reviewed at:
Awesome
5.0
It was a breeze to set up. The first time I …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 8 2008
jetlite
Undisclosed
Reviewed at:
[3 of 3 customers found this review helpful]
EXCELLENT SOUND !!!!
5.0
"This system sounds fantastic.If you want something affordable and a small home theater system but want the sound of a HIGHER quality system then this is for you.The bass is unreal ! you will feel every moment of the movies and cd's/music. This sony realy sounds GREAT.To say the least i was very impr …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
May 4 2008
rockfordfosgateMAN
clearwater,florida
Reviewed at:
[4 of 4 customers found this review helpful]
Pretty good
4.0
"Pros
The Set up is pretty easy. Color Coded wires make it pretty easy to deal with. Love the Ipod Doc though It would be insanely better if it could transmit video from the IPOD. Great sound quality.
Cons
Not wireless which depending on your room configuration, can have a bad visual with wires fl …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jan 2 2009
koliver0821
NH
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
