Sony 2GB Walkman MP3 Player (NWZ-B105F)
4.0
based on 10 reviews
Ratings Distribution
5 star
7
4 star
12
3 star
2
2 star
1
1 star
1
Category Average
4.1
More Images
Pros
  • Easy setup (20)
  • Sleek/compact (19)
  • Great sound (17)
  • Reliable (17)
  • Simple controls (15)
  • Lots of storage (11)
  • Tough (5)
  • Easy to use (2)
  • Quality construction (2)
  • Amfm tuner (1)
See less See more
Cons
  • Awkward design (1)
  • Confusing / difficult controls (1)
  • Didn't come with laynard (1)
  • Features don't work (1)
  • Freezes up (1)
  • Holds 212 songs (1)
  • Insufficient storage (1)
  • Needs a case for the gym (1)
  • Needs more storage (1)
  • Permanent failure (1)
Best Uses
  • Travel (17)
  • Gym / working out (15)
  • Work (11)
  • Good for commuting (9)
  • Sports (8)
  • Upgrade (2)
  • All purpose (1)
  • Look professional (1)
  • School (1)
Provided by Staples
2GB plays up to 1,000 songs in WMA, 500 songs in MP3 3-line color LCD Connect device directly to your PC and easily transfer your music and charge your device Record your favorite broadcasts using the built-in FM tuner with record function Built-in microphone with voice recorder function Up to 12 hours of battery life Compatible with Windows Media PlaysForSure music services Note: Song estimations may vary depending upon song length and encryption technology Lightweight and packed with clever features that make it easy to manage and enjoy your music.
Specification Description
Model NW-ZB105FBLK, NW-ZB105FWHI, NWZ-B105FBLK, NWZ-B105FWHI
UPC 027242723009
Color Black
Color White
Product Type Flash MP3 Player
Select Capacity 2 GB Memory
Sony 2GB Walkman MP3 Player (NWZ-B105F) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 2GB Walkman MP3 Player (NWZ-B105F)
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 19, 2009
Sony 2GB Walkman MP3 Player (NWZ-B105F) Reviews
Most helpful positive review
[5 of 6 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
All you need is this!!!
"My friends all have IPODS with 8 Gigs of storage space and I have the previous version of this Sony MP3 player with 1 gigs of storage space. They tell me they have x amounts of songs and they are almost full. I tell them that I have music that will lest me an entire month if I played it continuously without stopping and I have only managed to fill up 490 megs of storage space. Now, my friends tell me that the..." Read Full Review »
Jan 09, 2008 by Tech_Wiz
See more positive Sony 2GB Walkman MP3 Player (NWZ-B105F) reviews
3.0
a little disappointed
"I loaded about 300 songs on this unit and set it on shuffle for the workday. About an hour or so into it, it began repeating songs, which was a little irritating because I knew it had a lot more to play. So I would hit the forward button to skip to the next, but it would often just forward through the track, requiring pressing the button multiple times. Sort of distracting. You'd think it would just do what it's..." Read Full Review »
Mar 13, 2008 by romo
See more negative Sony 2GB Walkman MP3 Player (NWZ-B105F) reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Great player
4.0
    Pros
  • Easy To Set Up
  • Great Sound
  • Reliable Performance
  • Simple Controls
  • Sleek/Compact
  • More »
    Cons
  • None
    Best Uses
  • At Work
  • Gym / Working Out
"this player is extremely easy to use and features superb functionality and amazing sound quality even with the relatively cheap stock headphones. the 2GB storage is sufficient but could be better and the battery life is only ok. however the fact you can plug it into a usb port to charge it offsets …"  Read Full Review »
Was this MP3 Player & iPod review on the Sony 2GB Walkman MP3 Player (NWZ-B105F) helpful to you?
May 17 2008
MAV
Meridian, ID
I am:
  • Casual Listener
Reviewed at:
Good design, features & ease of use
4.0
    Pros
  • Easy To Set Up
  • Lots of Storage
  • Simple Controls
  • Sleek/Compact
    Cons
  • None
    Best Uses
  • Gym / Working Out
  • Travel
"This little MP3 player is exactly what I was looking for at a reasonable price. Charges rapidly from laptop (or any) USB port, easy to setup, simple controls, no HDD to crash if dropped. Bass is a little weak unless the EQ is used. Has a lot of storage and the features I wanted w/o being overly com …"  Read Full Review »
Oct 2 2007
fredmartens
Seattle
I am:
  • Casual Listener
Reviewed at:
Easy to use
4.0
    Pros
  • Easy To Set Up
  • Lots of Storage
  • Sleek/Compact
    Cons
  • None
    Best Uses
  • At Work
  • Commuting
  • Travel
"Overall, it's a nice mp3 player, especially with the ability to just drag your mp3 over to the file like a flashdrive. The only downfall is that whenever you restart your player, it will start again from the beginning of the last song you listened to instead of at the exactly min/sec of the last son …"  Read Full Review »
Apr 16 2008
Mp3 player
San Francisco, CA
I am:
  • Casual Listener
Reviewed at:
Easy to use and reliable
3.0
    Pros
  • Easy To Set Up
  • Simple Controls
  • Sleek/Compact
    Cons
  • Controls too close
    Best Uses
  • ALl Purpose
  • At Work
  • Commuting
  • Gym / Working Out
  • Sports
  • More »
"Nice for the money. Easy to use, reliable. Controls are kinda close together tho...there is no place to grab the darned thing and no one seems to carry cases for it, so there is nowhere to hang it.
But hey...as a pure mp3 player, it fits the bill. "
Jan 16 2008
oksurb
PA
I am:
  • Casual Listener
Reviewed at:
simple, cheap, works great
5.0
    Pros
  • Easy To Set Up
  • Great Sound
  • Simple Controls
  • Sleek/Compact
    Cons
  • None
    Best Uses
  • Commuting
  • Travel
"The best part about this device is that it requires absolutely no software to work. Simply plug it in and drag/drop files unto it. Sound quality is great for the price and UI is good. Only complaint is that "shuffle" feature could use some work (repeats songs). "
Oct 25 2007
Alex
Maryland
I am:
  • Casual Listener
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
