Sony 2GB Memory Stick PRO Duo Mark 2 Media Card
#381
4.5
based on 46 reviews
Ratings Distribution
5 star
52
4 star
20
3 star
4
2 star
1
1 star
2
Category Average
4.6
$11.99 - $24.99
from 15 stores
More Images
Pros
  • Easy to use (37)
  • Reliable (34)
  • Large capacity / good size (27)
  • Good value (18)
  • Fast (11)
  • Easy setup (9)
  • Portable (8)
  • Lightweight (7)
  • Writes/reads fast (7)
  • Convenient interface (5)
See less See more
Cons
  • Capability issues (1)
  • Compatibility problem (1)
  • Flimsy (1)
  • I would have liked a case (1)
  • No case cover (1)
  • Not cheap (1)
  • Poor interface (1)
  • Pricey (1)
Best Uses
  • Portable images/multimedia (21)
  • Storing images/multimedia (14)
  • Digital capture (8)
  • Digital photography (8)
  • Image storage (8)
  • Additional storage (6)
  • Image transportation (6)
  • File transfer (4)
  • Back-up (3)
  • Cameras (2)
Provided by OneCall
The MSX-M2GS Memory Stick PRO Duo(TM) media from Sony gives you maximum storage for your compact digital camera, portable audio device, or PSP(TM) Handheld Entertainment System. With a huge total storage capacity of 2 gigabyte with 1.85 gigabytes available and an wide operating temperature range of -13 degrees F to 185 degrees Fahrenheit, the MSX-M2GS provides you with durable, high capacity storage for your digital files. With the included adaptor, the MSX-M2GS can be used in most devices that use full-sized Memory Stick PRO(TM) media, making it perfect for both your older devices and the latest electronics.
  • 2 GB storage capacity with 1.85 GB available
  • Minimum write speeds of 15 Mbps on Memory Stick PRO Duo(TM) enabled devices optimized with 4-pin parallel interface
  • Increased operating temperature range of -13 degrees F to 185 degrees F for greater durability
  • Included adapter allows compatibility with Memory Stick PRO(TM) media enabled devices
  • Backwards compatible with most devices that use Memory Stick PRO Duo(TM) media
  • Designed especially for compact digital cameras and the PSP(TM) Handheld Entertainment System
  • One of the smallest digital storage devices available
  • Specification Description
    Model 26983312, 711719859307, 98593, MS-MT2G
    UPC 027242671140
    Accessory Indicator Yes
    Benefits Enjoy increased storage and durability with this 2GB memory stick that is compatible with the PSPIdeal for storing games, videos, pho
    Capacity UOM mAh
    Compatible Platforms PlayStation Portable
    Country Of Origin Japan
    Description Header Store more.
    Display Catalog Number 55026924
    Manufacturer Labor Warranty 12
    Manufacturer Part Number 711719859307
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Model 98593
    Operating Temperature UOM ° F
    Product Type PlayStation Portable
    Supported Languages English
    Sony 2GB Memory Stick PRO Duo Mark 2 Media Card Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 27, 2009
    Sony 2GB Memory Stick PRO Duo Mark 2 Media Card Reviews
    Most helpful positive review
    Most helpful negative review
    [1 of 1 customers found this review helpful]
    5.0
    The only way to fly
    "The memory stick pro would not work in my Sony computer so I phoned customer support and after hours of being transfered from person to person, their conclusion was that my model of Sony computer was to old ( 5 yrs old ) and that is why it would not work. I was told that I would just have to use the USB cable to download . After some research on my own, turns out all I needed was to download a newer version driv..." Read Full Review »
    May 31, 2007 by NOD
    See more positive Sony 2GB Memory Stick PRO Duo Mark 2 Media Card reviews
    3.0
    Just a memory card
    "Its a straightforward standard memory stick. Too bad they don't have full size adapters for them anymore..." Read Full Review »
    Aug 12, 2009 by The wandering engineer
    See more negative Sony 2GB Memory Stick PRO Duo Mark 2 Media Card reviews
    Displaying 1 - 5 of 46 Reviews
    Show
    Sort by
    The only way to fly
    5.0
      Pros
    • Convenient Interface
    • Lightweight
    • Reliable
      Cons
      Best Uses
    • Digital Photography
    • Image Storage
    • Image Transportation
    "The memory stick pro would not work in my Sony computer so I phoned customer support and after hours of being transfered from person to person, their conclusion was that my model of Sony computer was to old ( 5 yrs old ) and that is why it would not work. I was told that I would just have to use the …"  Read Full Review »
    Was this Memory Media review on the Sony 2GB Memory Stick PRO Duo Mark 2 Media Card helpful to you?
    May 31 2007
    NOD
    Milton Fl.
    I am:
    • Hobbyist/Enthusiast
    Great for Taking You Tube Movies
    5.0
    "I bought this card last year one hour before my son's wedding. (I drove across half the country then found out I forgot my largest camera card)
    I took photos and movies all day and didn't run out of space until the end of the night. Keep in mind that I took snippet movies to put on you tube not hal …"  Read Full Review »
    Sep 11 2008
    CEParah
    Undisclosed
    Reviewed at:
    Price: $19.99
    I use several of these in my business
    5.0
      Pros
    • Easy To Use
    • Great Value
    • Large Capacity
    • Reliable Performance
    • Writes/Reads fast
      Cons
    • None
      Best Uses
    • Send large files by mail
    "Primary use is in high resolution digital cameras but the item is compact for mailing through USPS to clients and friends with numerous large files for sharing, reviewing, editing and printing. "
    Jun 16 2009
    Graphic Steve
    Morro Bay, CA
    I am:
    • Professional
    Reviewed at:
    Price: $18.95
    II would buy this product again.
    5.0
      Pros
    • Lightweight
    • Reliable
    • Strong Construction
      Cons
    • NA
      Best Uses
    • Digital Capture
    • Image Storage
    "I'm using this product with my digital sony camera, and i love it. This product is really good and is really small, it's perfect for me. I don't have nothing to say bad things about this product.
    Thank you!! "
    May 7 2008
    thigor_s
    Vallejo, Ca
    I am:
    Reviewed at:
    Price: $19.00
    Very fast read/write time
    5.0
      Pros
    • Durable construction
    • Easy To Use
    • Large Capacity
    • Writes/Reads fast
      Cons
    • None
      Best Uses
    "ABT online customer support rep recommended this product for my Sony DSCW150. My primary concern was fast read/write speed and this one seems much faster than previous memory cards for other cameras. "
    Jul 24 2008
    Sheila
    New York, NY
    I am:
    Reviewed at:
    Price: $19.00
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
