Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV
4.7
based on 84 reviews
Ratings Distribution
5 star
60
4 star
22
3 star
1
2 star
0
1 star
1
Category Average
4.4
More Images
Pros
  • Fast setup (77)
  • Bright image (75)
  • High resolution (74)
  • Attractive design (72)
  • Good connection options (66)
  • Simple controls (56)
  • Reduced glare (45)
  • Durable (1)
  • Good value (1)
  • Great picture quality (1)
See less See more
Cons
  • Low resolution (3)
  • A little pricy (1)
  • Bad interface (1)
  • Because it doesn't adjust (1)
  • Black small spot (1)
  • Can't think of any cons (1)
  • Difficult to set up (1)
  • Haven't found one (1)
  • Image so-so for sports (1)
  • Lacks swivel base (1)
Best Uses
  • Home (60)
  • Movies (22)
  • Office (22)
  • Video (19)
  • Kitchen (9)
  • Bedroom (6)
  • Be great in any room (1)
  • Computer monitor (1)
  • Den/office (1)
  • Great for bedroom (1)
Provided by Beach Audio
FEATURES- 26" BRAVIA S Series LCD Flat Panel HDTV
Savor the rich colors and superb high definition picture quality of
a digital LCD and enjoy it at an incredible value. The KDL-26S3000
BRAVIA S-series digital LCD television delivers improved color
performance and several picture enhancements thanks to the BRAVIA
Engine full digital processor. And the Xross Media Bar on-screen
menu system makes is simple to quickly access setup functions and
features. For the ultimate convenience, BRAVIA Theatre Sync allows
you to control your specially-equipped Sony HDMI components with
the touch of a button.
Includes TV, Tabletop Stand, RM-YD018 Remote Control, AA x 2 Batteries,
Support belt and screws, Operation Manual.
* BRAVIA Engine Full Digital Video Processor
BRAVIA S-Series LCD televisions use Sony's BRAVIA Engine full digital
video processor for crisp and clear images. Several special picture
enhancement technologies are integrated into the processor to create
better gradations with more detail, enhance contrast, and dynamically
improve color performance. Digital Noise Reduction Circuits: Reduces
block noise and mosquito noise by using pixel-level filtering to
reproduce a clean and clear picture. And Motion Vector Noise Reduction
reduces just the noise in the video signal for video further reducing
unwanted noise and blur artifacts. Digital Contrast Enhancer circuit:
Improves contrast by enhancing all areas from dark to bright in parallel
with texture control providing a three dimensional picture. Color
Reality signal processing enables the expression of all the colors of
life in vivid detail for dark and bright scenes. Details in dark areas
of the picture are there, just like they are supposed to be.
* Live Color Creation (featuring WCG-CCFL)
Live Color Creation is a special Sony function that achieves precise,
wide color reproduction using a combination of advanced chroma signal
processing algorithms. A special wide color gamut backlight (WCG-CCFL)
is coupled with Sony's Live Color Creation circuitry. The benefit is
clear blues, natural greens and overall vibrant colors in all scenes.
* Xross Media Bar (XMB) On-Screen Menu System
Xross Media Bar is Sony's Emmy Award winning on-screen navigation that
provides quick access to various set up functions and features. For
instance selecting different types of media is made fun and easy by
scrolling horizontally across icons until you find the type of media you
are looking for. After selecting the media type, a list of its content
appears as vertical thumbnails. Key set up menus and features work the
same way. The main benefit of the XMB is that users can navigate through
on-screen menus without taking their eyes off of their TV.
* DMex Compatibility
DMex compatibility allows the connection and operation of a whole new
category of products that is being developed by Sony (sold separately).
The first of these products is the optional BRAVIA Internet Video Link
module.
* BRAVIA Theatre Sync-2
BRAVIA Theatre Sync reduces the hassle and time consuming job of
powering up, changing the signal routing, and adjusting other functions
to the simple push of one button. All you need to do is to connect
BRAVIA Theatre Sync capable products to each other via one HDMI cable.
The rest is easy. For instance, the One Push Play function activates by
touching the play button on the remote and BRAVIA Theatre Sync takes
over from there. The BRAVIA Home Theatre System and TV turn on. The DVD
input on the BRAVIA Theatre system and TV activates. The TV mutes. And
finally the DVD plays. There are two other BRAVIA Theatre Sync functions
- One-Push Theatre Settings, which provides optimal picture and sound
settings for movies and One-Push System Shut Down for turning off the
entire home entertainment system.
* BRAVIA Internet Video Link
The first DMex product to be introduced to the market is the DMX-NV1
BRAVIA Internet Video Link module (sold separately). The DMX-NV1 can
stream available Internet video from select content providers directly
to your TV with a broadband connection3 without the need for a PC.
* S-Force Front Surround
S-Force Front Surround is a virtual surround sound experience made
possible using just two front speakers in select BRAVIA models. To
accomplish this, Sony spent several years studying how our ears work. By
understanding exactly how we recognize the origin, direction, volume and
timing differences in sound right and left ear, Sony was able to create
complex audio processing that delivers dynamic virtual surround sound
without the need to bounce sound off walls and back to the listener.
* HDMI and PC Connectivity
Designed for maximum versatility, Sony's BRAVIA S-Series Digital LCD TV
line is equipped with a comprehensive range of input interfaces. The
HDMI (High-Definition Multimedia Interface) is the first industry-
supported, uncompressed, all-digital audio/video interface. HDMI
technology supports enhanced or High Definition video, together with
multi-channel digital audio to provide matchless image and sound
reproduction. The HDMI and PC inputs (HD-15-pin) offer easy connection
to your PC, allowing you to use your high resolution BRAVIA S-Series
Digital TV as a computer monitor.
* Light Sensor-2
Intelligently adjusts the screen brightness to match the ambient light
in a room, ensuring a comfortable viewing experience. In a dim room for
example the screen automatically reduces brightness making it much more
comfortable for viewing.
* Freeze Function
Sony's Freeze Function is a useful function that allows you to
temporarily freeze the picture in a separate screen while the
programming continues to display. This comes in handy when you want to
copy a recipe, phone number, etc. that flashes too quickly across your
screen. Simply touch the "Freeze" button on the remote control and copy
the details down at your convenience.
-- SPECIFICATIONs -----------------------------------
ASPECT RATIO - 16:9
SCREEN SIZE - 26 inch (measured diagonally)
TELEVISION TYPE - Flat Panel
AUDIO SAP - Yes
CLOSED CAPTION - Yes (CC)
ID1 DETECTION - Yes
VIDEO LABEL - Yes
NATIVE RESOLUTION - 720p
CONTRAST RATIO - 8,000:1 (Dynamic)
DISPLAY RESOLUTION- 1366 x 768
VIEWING ANGLE - Right/Left: 178 degrees, Up/Down: 178 degrees
RESPONSE TIME - 8ms (gray to gray)
ADVANCED VIDEO PROCESSOR-
CineMotion/Film Mode/Cinema Drive, Contrast enhancer
circuit, Green and blue enhancer, Motion and edge
adaptive I/P converter, MPEG noise reduction.
TUNER - ATSC with QAM
VIDEO PROCESSING - Yes (BRAVIA Engine System)
NOISE REDUCTION - Yes
COMB FILTER - 3D Digital Comb Filter
LIGHT SENSOR - Yes
PICTURE MODES - Vivid, Standard, Cinema
WIDE MODE - Wide Zoom/ Normal/ Full/ Zoom
DISPLAY TECHNOLOGY- LCD (178 degree wide viewing angle)
10-BIT DISPLAY PANEL-
Yes
BRAVIA THEATRE SYNC-
Yes (One-Button Home Theater Control (HDMI-CEC)
SOUND MODE - Yes
MTS STEREO DECODER- Yes (with SAP)
DIGITAL AMPLIFIER - Yes
DOLBY DIGITAL - Yes (AC3/ATSC only)
TIME CLOCK - Yes
CHANNEL LABEL - Yes
CHANNEL SKIP/ADD - Yes
FAVORITE CHANNEL - Yes
PARENTAL CONTROL - V-Chip
PROGRAMMABLE TIMER- Yes
SLEEP TIMER - 15, 30, 45, 60, 90, 120, Off
TIMER EVENTS - 1
CLOCK - Yes
POWER SAVE MODE - Standard, Reduced, Picture Off
PICTURE FREEZE - Yes
INPUT SKIP - Yes
ON-SCREEN DISPLAY - Menu
CONNECTORS - Analog Audio Input(s) : 5 (1 Side/4 Rear)
Audio Out (Variable/Fixed) : 1 (Rear)
Component Video (Y/Pb/Pr) Input(s): 2 (Rear)
Composite Video Input(s) : 3 (2 Rear/1 Side)
Digital Audio Output(s) : 1 (Rear)
RF Connection Input(s) : 1 (Rear)
S-Video Input(s) : 2 (1 Rear/1 Side)
rear input has
Auto S-Video
Input Detection.
Headphone Output(s) : 1 (Side)
PC Audio Input(s) : 1 (Rear)
PC Video Input(s) : 1 (Rear) with D-sub
15 and L/R stereo
mini plug
connection.
HDMI Connection(s) : 2 (2 Rear)
- 1 rear input has
L/R audio inputs.
1080/24p Input Capable : Yes (via HDMI)
POWER SOURCE - AC 120V, 60Hz; Consumption 105 watts; Energy Star
DIMENSIONS - 25.8"w x 19.7"h x 8.4"d WT.- 29.8 lbs.
(with pedestal)
25.8"w x 17.8"h x 3.8"d 24.3 lbs.
(without pedestal)
www.sony.com
Specification Description
Model KDL-26M3000, KDL-26S3000, KDL-26S3000/P, KDL-26S3000/R
UPC 027242714991
Screen Size 21" to 29"
Select LCD Units
Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 26" BRAVIA S-Series Black LCD Flat Panel HDTV
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 5, 2008
Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Works well as a computer monitor!
"Am I the only one who thinks the pixel size on typical computer monitors is way too small? Fortunately, one can buy HDTVs and essentially choose their pixel size, which is what I did with this 26" Sony Bravia. With my PC, I can run it at 1360 x 768 pixels, and the Bravia is smart enough not to scale it ("1:1 pixel mapping" is what it's called). In fact, no matter what resolution I send to the Bravia via my compu..." Read Full Review »
Nov 01, 2007 by jinzzc
See more positive Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV reviews
3.0
The jury is still out.
"Having a problem with the picture, which seems to break up and becomes scrambled. Haven't discovered if it is the TV or the new cable box, although the other two TV's are clear and attached to the same cable line...." Read Full Review »
Feb 05, 2008 by sassy one
See more negative Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV reviews
Displaying 1 - 5 of 84 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Speakers a bit tinny
    Best Uses
  • Home
  • Movies
  • Office
  • Video
"Am I the only one who thinks the pixel size on typical computer monitors is way too small? Fortunately, one can buy HDTVs and essentially choose their pixel size, which is what I did with this 26" Sony Bravia. With my PC, I can run it at 1360 x 768 pixels, and the Bravia is smart enough not to scale …"  Read Full Review »
Was this LCD TV review on the Sony 26" BRAVIA S-Series Black LCD Flat Panel HDTV helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 1 2007
jinzzc
Los Angeles, CA
I am:
  • Professional
Reviewed at:
Exceeds our expectations
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Office
"This set is better in every way than we expected, and we expect a lot from Sony.
We use this as a TV in my wife's study. It's size is perfect as a second set. A big part of our selection of this set was how well my wife liked its looks in the room. The bezel is matte and is very classy looking.
Apr 11 2008
Tech shopper for our house
Louisville, CA
I am:
  • Practical
Reviewed at:
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
"4/2/08 6:50 PM
Saturday night 3/29, I placed an online order for a Panasonic TC26LX70 -HDTV which was shown on Backorder and since I wasn`t in a hurry and the TV is for the bedroom I figured I`d get in line to be sure to get one when they did arrive. In checking stock Sunday morning I spotted a S …"  Read Full Review »
Apr 21 2008
H2045
Kenilworth N.J.
I am:
  • Gearhead
  • Practical
Reviewed at:
You get what you pay for with Sony.
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • A little pricy
    Best Uses
  • Bedroom
"I wanted a small(ish) HDTV for my bedroom so I ordered a 22" ViewSonic HDTV/monitor, which was well-reviewed online. Unfortunately, its picture and sound quality turned out to be awful, so I returned it.
I have a 32" Sony Bravia in my living room, and I really like it. I realized I was going …"  Read Full Review »
May 6 2008
Pensive.d
Santa Barbara, CA
I am:
  • Practical
Reviewed at:
Simply a gem
4.0
    Pros
  • Fast Setup
  • Good Resolution
    Cons
  • Limited remote use
    Best Uses
  • Home
  • Movies
  • Office
"I bought this unit to replace the 20" CRT in my bedroom. I shopped quite extensively and happened across the best deal with Abt. The total price including shipping and a 4-year extended warranty was less than any price the B&M stores could offer without a warranty.
Set up was a snap and I'm sti …"  Read Full Review »
May 17 2008
RCM999
LaVergne, TN
I am:
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
