Sony 26" BRAVIA M-Series LCD Flat Panel HDTV
#215
4.6
based on 16 reviews
from $449.99
Ratings Distribution
5 star
11
4 star
4
3 star
1
2 star
0
1 star
0
Category Average
4.4
$449.99 at J&R Electronics
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great picture quality (16)
  • Attractive design (15)
  • Fast setup (15)
  • Good connection options (15)
  • Simple controls (15)
  • High resolution (14)
  • Wide viewing angle (10)
  • Simple elegant design (1)
See less See more
Cons
  • Poor sound quality (2)
  • Opening screen advertisem (1)
  • Poor image quality (1)
  • Poor reception / weak antenna (1)
Best Uses
  • Home (10)
  • Movies (6)
  • Bedroom (5)
  • Office (2)
  • Wall mounting (2)
  • Home theater (1)
  • Kitchen (1)
  • Video (1)
Provided by OneCall
Advanced Contrast Enhancer (ACE)
Part of the cinematic drama in film-making comes from details found in shadows and dark areas of the picture. Sony`s Advanced Contrast Enhancer (ACE) uses real-time image processing to dynamically adjust backlight levels for improved Contrast without masking details the filmmaker intended you to see. ACE delivers deep blacks in darker scenes, as well as fine details in shadows and other dark areas of the picture for a difference you can truly see.
BRAVIA® Engine™ Technology
The latest version of Sony`s respected BRAVIA Engine fully Digital video processor uses a collection of unique SONY algorithms to significantly reduce noise and produce sharp, vibrant, life-like images...
  • Dynamic Noise Reduction: Intelligently identifies and dramatically reduces noise in the signal according to the motion and Brightness of each scene for clearer, crisper images.
  • Detail Enhancement: Improved image enhancement algorithms render greater overall detail.
  • Contrast Enhancement: Works with the Advanced Contrast Enhancer circuit to optimize the Contrast for every scene to create better depth and reality.
  • BRAVIA® Theater Sync™
    BRAVIA Theater Sync is based on the industry standard HDMI™-CEC function and allows your HDMI cable to do more than just transmit pure Digital audio and video signals by allowing one-touch control of compatible A/V components. Functions include: ONE-PUSH PLAY, ONE-PUSH Theater SETTINGS and ONE-PUSH SYSTEM POWER OFF
    Specification Description
    Model KDL-26M4000W, KDL26M4000/W, KDL26M4000W
    UPC 027242739734
    Analog Audio (1) Side Input
    Analog Audio (4) Rear Input
    Analog Audio Rear Output
    Aspect Ratio 16:9
    Component Video (2) Rear Input
    Composite Video Rear Input
    Composite Video Side Input
    Contrast Ratio 2,500:1
    DB15 (PC Video) Rear Input
    Depth (Inches) 9.6
    Dynamic Contrast Ratio 2500:1
    HDMI (2) Rear Input
    HDTV HDTV Tuner Built In
    HDTV Capable HD Tuner is included
    HDTV Native Resolution 720p
    Headphone Jack Side Output
    Height (Inches) 20.1
    PC Audio Rear Input
    Refresh Frequency 60 Hz
    Remote Control Included
    Resolution 1366 x 768
    RF Rear Input
    RS-232C Yes
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size (inches) 26
    Screen Size (Inches/Diagonal) 26
    Speakers 10 Watts x 2
    Speakers Built-in
    Tuner ATSC
    Tuner NTSC
    Tuner QAM
    Wall Mountable VESA Compliant
    Wall Mountable Yes
    Weight (Pounds) 26.5
    Width (Inches) 26.6
    Sony 26" BRAVIA M-Series LCD Flat Panel HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Jul 10, 2009
    Sony 26" BRAVIA M-Series LCD Flat Panel HDTV Reviews
    Most helpful positive review
    [9 of 9 customers found this review helpful]
    Most helpful negative review
    [2 of 2 customers found this review helpful]
    5.0
    Good picture and inputs
    "I use this TV predominately as a monitor connected to a Linksys Microsoft Media Center Extender for live and recorded HDTV, a Sony DVD player, and a PC. This product works very well for all of these devices. The picture quality, picture adjustments, input selection/labeling, and overall build quality are excellent.I use the VGA port (WXGA 1360x768) for the PC, and HDMI for Media Center and DVD player (consuming..." Read Full Review »
    Aug 21, 2008 by golfgeek
    See more positive Sony 26" BRAVIA M-Series LCD Flat Panel HDTV reviews
    3.0
    Not Great when viewing from an angle.
    "Image is washed out when viewed from an angle. Seems worse than other LCDs..." Read Full Review »
    Oct 08, 2008 by JC
    See more negative Sony 26" BRAVIA M-Series LCD Flat Panel HDTV reviews
    Displaying 1 - 5 of 16 Reviews
    Show
    Sort by
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Home
    • Kitchen
    • Movies
    • Office
    • Video
    "I use this TV predominately as a monitor connected to a Linksys Microsoft Media Center Extender for live and recorded HDTV, a Sony DVD player, and a PC. This product works very well for all of these devices. The picture quality, picture adjustments, input selection/labeling, and overall build quali …"  Read Full Review »
    Was this LCD TV review on the Sony 26" BRAVIA M-Series LCD Flat Panel HDTV helpful to you?
     Report Abuse  (9)  (0)  0 comments
    Aug 21 2008
    golfgeek
    Houston, TX
    I am:
    • Practical
    • Professional
    • Tech Savvy
    Reviewed at:
    [4 of 5 customers found this review helpful]
    Sony KDL-26M4000W 26
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Bedroom
    • Home
    • Movies
    • Wall Mounting
    "This HDTV is great for bedrooms and small rooms around the house. We all know Sony has great looks when it comes to design, and this 26 inch TV complements any room decor. It has great picture quality as well a great sound. Put it in your kitchen, childrens room, or your own for pure entertainment. "
     Report Abuse  (4)  (1)  0 comments
    Jun 18 2009
    Tony
    Maspeth
    I am:
    • Enthusiast
    Reviewed at:
    Price: $449.99
    An Unpretentious Class Act!
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • No reception wo antenna
      Best Uses
    • Home
    • Movies
    "We just happen to reside on the only block in the entire city without cable service ~ no Cox, no Time-Warner, and no AT&T. Not wishing to make a long-term commitment with a semi-sleazy, without-local-programing satellite company, we soon realized that purchasing an HD receiver was our only choice, …"  Read Full Review »
    Apr 2 2009
    texbuckner
    San Diego, CA
    I am:
    • Casual User
    Reviewed at:
    [3 of 3 customers found this review helpful]
    WOW!
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Bedroom
    "This is one of the best Sony HDTV that I have purchased (this is number 3). This is the first 720p, but with this size, it is as good as any 1080p! I highly recommend it! "
     Report Abuse  (3)  (0)  0 comments
    Oct 27 2008
    LANYCJOE
    Alison Viejo, CA
    I am:
    • Enthusiast
    Reviewed at:
    Great Sony Tv
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • None
    "I watch a lot of television in the evening in the bedroom. This tv is a pleasure to set up and If I can do it anyone can. I love it in white although there is still more black on it than I would like. I do love this tv[...] "
     Report Abuse  (2)  (0)  0 comments
    Sep 18 2008
    LoDo
    Cedar Rapids, Iowa
    I am:
    • Enthusiast
    Reviewed at:
    pages: 1 2 3 4 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
