Sony 26" Bravia LCD HDTV - KDL26L5000
#9
4.8
based on 71 reviews
Ratings Distribution
5 star
56
4 star
8
3 star
1
2 star
0
1 star
0
Category Average
4.4
$389.99 - $461.70
from 16 stores
More Images
Pros
  • Fast setup (29)
  • High resolution (29)
  • Attractive design (28)
  • Great picture quality (26)
  • Good connection options (25)
  • Simple controls (22)
  • Wide viewing angle (16)
  • Very good tv (1)
See less See more
Cons
  • Poor sound quality (2)
  • Bad interface (1)
  • Difficult user interface (1)
  • Poor connection options (1)
Best Uses
  • Bedroom (21)
  • Home (14)
  • Movies (5)
  • Wall mounting (5)
  • Built-in location in den (1)
  • Kitchen (1)
  • Will use in kitchen (1)
Provided by Kmart
Vivid HD Resolution - Get vibrant 720p resolution from any HD source, including movies, sports, and HD television programming. ACE w/ Dynamic Backlight Control - Dynamic Backlight Control creates a dynamic contrast ratio of 13,000:1 by adjusting the brightness of the backlight in real time, optimizing contrast and reducing power consumption. HD Connectivity - Three HDMI inputs (up to 1080/60p input capable) transmit both uncompressed digital video and multi-channel digital audio on a single cable. Two Component YPbPr (1080/60i capable) inputs provide added HD-capable connectivity. One PC input (HD-15 pin) offers the versatility to use your HDTV as a computer monitor. BRAVIA Link Compatible - Expand your HDTV's capabilities with BRAVIA Link modules, like BRAVIA DVD Link, BRAVIA Wireless Link, and BRAVIA Input Link (all sold separately). One-Touch Control - BRAVIA Sync gives you one-touch access and control of all your compatible home theatre devices (and select Sony Handycam camcorders) from your HDTV remote. For Movie Fans - Enjoy films at their intended 24 fps (frames per second) when using a Blu-ray Disc player or other 24p-capable device (sold separately). Built-In Tuner - Get over-the-air digital TV and unencrypted HDTV broadcast signals, as well as traditional analog TV broadcasts, with the built-in ATSC /NTSC tuner with QAM. VESA Compatible - Industry-standard hole spacing takes the guesswork out of hanging your HDTV to the wall when you use VESA -compliant mounting brackets. Inputs - HDMI (3), Component (2), Composite (2), PC, RF, S-Video, USB 2.0, Analog Audio (5)Outputs - Digital Audio, Analog Audio. Includes:Remote Control (with batteries); AC Power Cord; Operating Instructions; Quick Setup Guide; Warranty Card; Pedestal (with screws)
Specification Description
Model KDL-26L5000, KDL26L5000
UPC 027242753044
color null
Dynamic Contrast Ratio 13000:1
HDTV Capable HD Tuner is included
Screen Format 16:9 Widescreen TV Imaging
Screen Size (Inches/Diagonal) 26
size null
sku 163100
skuprice 499.9900
style KDL26L5000
taxable Y
TV Manufacturer’s Warranty (Labor) 1 Year
TV Manufacturer’s Warranty (Parts) 1 Year
Sony 26" Bravia LCD HDTV - KDL26L5000 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 15, 2009
Sony 26" Bravia LCD HDTV - KDL26L5000 Reviews
Most helpful positive review
[21 of 21 customers found this review helpful]
Most helpful negative review
[0 of 2 customers found this review helpful]
5.0
Worth Waiting For!
"This is my 1st HDTV; I could not be more pleased. I've been reading reviews for 2+ years, continuing to depend on my 20 inch Sony purchased in 1988, while waiting for technology and price to be dedicated to smaller HDTVs. December 2008 Consumers Reports review of 26 inch sets indicated the predecessor, 26L4000, would have been their highest rated if the remote was more user friendly. This TV and the remote make ..." Read Full Review »
Mar 10, 2009 by Marine
See more positive Sony 26" Bravia LCD HDTV - KDL26L5000 reviews
3.0
OK for a low end TV
"Only TV that would fit Shelf..." Read Full Review »
Jun 25, 2009 by Bill
See more negative Sony 26" Bravia LCD HDTV - KDL26L5000 reviews
Displaying 1 - 5 of 71 Reviews
Show
Sort by
Worth Waiting For!
5.0
"This is my 1st HDTV; I could not be more pleased. I've been reading reviews for 2+ years, continuing to depend on my 20 inch Sony purchased in 1988, while waiting for technology and price to be dedicated to smaller HDTVs. December 2008 Consumers Reports review of 26 inch sets indicated the predecess …"  Read Full Review »
Was this LCD TV review on the Sony 26" Bravia LCD HDTV - KDL26L5000 helpful to you?
 Report Abuse  (21)  (0)  0 comments
Mar 10 2009
Marine
Saugatuck, Michigan
Great smaller LCD TV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
    Cons
  • None
    Best Uses
  • None
"We replaced another 26" HD tv with the Sony based on our positive experience with a larger model. We were restricted in size because of the cabinet opening and this fits perfectly. One confusing issue during setup was that Sony changed the interface for input to the remote instead of the screen inte …"  Read Full Review »
Nov 11 2009
don
san jose, ca
I am:
  • Casual User
Reviewed at:
Price: $404.95
[5 of 5 customers found this review helpful]
Excellent Flat Screen
5.0
"Pros:Gaming, entertainment, computer
Review
I researched this Sony 26" thoroughly prior to purchasing. It scores within the top of it's class with consumer guides and owners. It's an excellent purchase for both price and functionality.
I live in an apartment of ordinary size. This flat screen is m …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 22 2009
Lexor
Central PA
Reviewed at:
Price: $404.00
Sony L-Series if you rarely use 1080P
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Good Resolution
    Cons
  • Difficult User Interface
    Best Uses
  • Bedroom
  • Home
"Short Version: Sony L-Series is a good, midrange-quality TV for home location that does not need true 1080P, and J&R shipped it immediately at best possible pricing... I'm fixing to buy this very 26" for our Bedroom.
Long Version: I purchased this unit for Video Lab at work. The goal was to test …"  Read Full Review »
Oct 16 2009
Parkit
Austin, Texas
I am:
  • Power User
Reviewed at:
Price: $404.99
I have bought two of these televisions..
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"We would give this television the highest recommendation--we have now bought two for our beach house and we are very happy with each. "
Nov 10 2009
High on Design
Brewster, Massachusetts
I am:
  • Casual User
Reviewed at:
Price: $404.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
